UR V2.0 Downpipe Upon receiving the standard metal core catted downpipe and mocking it up to an ATP turbine housing noticed that the flapper would contact the DP flange after opening. To a certain degree, that is also the case on the K04 housing but since the flapper is smaller it has more travel. Many running this DP with the K04 so I suppose it's not a problem. Contacted Ultimate Racing to point out the issue thinking they would probably just brush me off and not address the problem. To my pleasant surprise they immediately asked that I ship the DP back to them with both the K04 and and the ATP turbine housings so they could take a look. A week or two later they had fixed the issue by increasing the size of the bellmouth and revising the flange. Those shmexy canucs are solid people. They sent the DP back to me and it works like a charm. No contact of the flapper against the flange anymore. Dealt with a dood named Daryl. He says UR will call the revised DP the "version 2" and that it will retail for slightly more than the standard DP. Welds look high quality just like the overall construction of the unit. K04 turbine housing http://i1211.photobucket.com/albums/...IMG_0035-1.jpg ATP turbine housing http://i1211.photobucket.com/albums/...h_IMG_0007.jpg Ebay uncatted turbine housing for comparison http://i1211.photobucket.com/albums/...h_IMG_0011.jpg Tried removing material from the flange to increase flapper range. Results unsatisfactory http://i1211.photobucket.com/albums/...zt/photo-4.jpg Flapper respective to the flange of the DP. http://i1211.photobucket.com/albums/...t/photo-10.jpg And the V2.0 downpipe. http://i1211.photobucket.com/albums/...t/photo-23.jpg http://i1211.photobucket.com/albums/...t/photo-22.jpg http://i1211.photobucket.com/albums/...t/photo-21.jpg |
Seen this DP in person and I like it but I must admit I'm not a fan of how this DP uses nuts in place of actual bungs for the O2 sensors. |
| All times are GMT -7. The time now is 02:24 AM. |
