Like Tree5Likes
 Old 01-14-2011, 05:49 PM   #881
driver311's Avatar
Posts: 1,769   (View Stats)
omg its been WAYYYYYYY to long since i seen one of these from you buddy haha
for the record, dustin is the BEST MSPaint painter ive ever seen.
and jesus fucking christ stop puttin springs on your dipsticks you fucks. DONT YOU THINK ITS POPPING OUT FOR A REASON!?!?!?!?! stop bandaid-ing the problem and fix it for good.
i blocked off my stock PCV box on the block and drilled and tapped my VC.
added more holes to the baffle for better airflow out of the VC.
then you add a 100 PSI CHECKVALVE inline with your OCC.
JEGS Performance Products 52211 JEGS Crankcase Evacuation Kit
the stock PCV valve has been proven by scott to let in between 5 and 10 psi of boost into the crankcase. hmmm last time i checked the CC is supposed to be vacuum 100% of the time. before i added this CV i was popping my dipstick almost every day. since ive had it i have yet to have one occurrence of a blown dipstick. not even a little bit popped out but always snug in there.
This is great. This is my next mod. So You just capped the pcv on the block and did this? I wonder if a pcv off an srt would work, paired with a ptp check valve. I have both laying around.
Mazdaspeed
 Old 01-14-2011, 07:29 PM   #882
Must Have Teh 10's!
superskaterxes's Avatar
Posts: 10,442   (View Stats)
i replaced the whole black PCV box on the block with a metal plate and RTV
First K04 in the 12's
First MS6 in the 11's
Certified RichTune E-Tuner
 Old 01-14-2011, 07:54 PM   #883
cpolly69's Avatar
Posts: 2,116   (View Stats)
Groans: 27
subaru's run a valve cover breather like ours, but T the crankcase with a check valve such that when in vacuum... IM sucks air in from the VC (like ours). And when in boost, the crank case vents to the TIP in conjunction with the VC (not like ours).
I'd like to see someone try a setup similar to this.
Our system already does this. It just takes more time for the pressure to travel up the timing chain are and thru the vc baffles (guess not as much if you drill a bunch of holes in them - Anthony) into the intake. What you propose might make it more efficient, but it wouldn't' be doing anything new.
08 CB MS3 Sport
Sold
01 MX-5 (Project)
03 P5 (DD)
 Old 01-14-2011, 10:58 PM   #884
driver311's Avatar
I plan on the same now that I look at it. Thanks for clearing shit up. This setup is how it should have come. Just like the srt4s.
Mazdaspeed
 Old 01-15-2011, 09:28 AM   #885
Captain
djuosnteisn's Avatar
Posts: 11,480   (View Stats)
Yeah, i know how ours works lol. The subie's end up with 2 evacuation ports while under boost instead of 1 like us (just the valve cover). With a setup like theirs, the pressure doesn't have to travel anywhere, i just blows out the CC port.
500awhp 440awtq uncorrected
Check out the hair Salon:
www.permtuning.com
 Old 01-15-2011, 09:56 AM   #886
Trail of Fail
Dano's Avatar
Posts: 9,484   (View Stats)
seems to me you want to evac direct from the CC port and not wait till it works its way to the VC but what do I know.
edit: maybe less particulate if you wait to vent in the VC?
 Old 01-15-2011, 10:15 AM   #887
Fuck sushi rolls
rodrigo's Avatar
Posts: 18,719   (View Stats)
Groans: 356
the crankcase gets pressurized , once u allow a spot of relief it doesnt matter too much if its at the bottom , top or middle.... the relief will help move shit along. my only experience in this is running 13:1 compression motors and running dual evacs one in each valve cover to each header collector and it always worked like a charm, fuckers that tried without always had front or rear main seal leaks.....
its hard to say how much more pressurized the crankcase of a turbo car is compared to a high compression NA motorbut regardless if there is an outlet the pressurized gas moves naturally to the less pressurized spot, so VC vents and evacs should do nicely
Dano (01-15-2011)
 Old 01-15-2011, 10:21 AM   #888
Fuck sushi rolls
rodrigo's Avatar
Groans: 356
oh and here s a thread I made about year and 8 months ago.
i see some people from this thread posted shit there ....hmmmmmmm
evac
Dano (01-15-2011)
 Old 01-15-2011, 12:50 PM   #889
rigor's Avatar
Posts: 2,399   (View Stats)
Groans: 40
i think the only benefit to drawing from below the pistons is the unburnt fuel gets drawn out before it mixes with the oil just my .02
at 104000 2 bent rods
tuned by nishan
 Old 01-15-2011, 12:54 PM   #890
ILL3ST
xcoldricex's Avatar
Posts: 2,777   (View Stats)
did cosworth or someone make pcv block off plates? i vaguely remember something of the sort - or did you just fab your own?
i think i'm going to try the mann provent setup for vc->intake
 Old 01-15-2011, 01:25 PM   #891
Trail of Fail
Dano's Avatar
ok VC it is...plus it looks way cooler having the Russell ano fittings up top...i think I'll go SS lines on my system if/when I ever do it LOL
could even get away with the knock-off SS hose covers for that application.
I actually like trying to use the venturi effect Lenny and spnkr mentioned off the DP...always something else to do the the car....where does it end?
in either case this should totally prevent any gunk buildup in the IM and head. Right?
 Old 01-17-2011, 07:36 PM   #892
Fuck sushi rolls
rodrigo's Avatar
Groans: 356
im too lazy to take the IM off the car....i wanna do more shit but fuck i wanna chill for a while.
most of my efforts now will be concentrated on making the car stick and go quick in the 1/4
djuosnteisn (01-18-2011)
 Old 01-17-2011, 07:43 PM   #893
Must Have Teh 10's!
i thought you were were done big guy? lol
aaronc7 (01-17-2011)
 Old 01-17-2011, 07:46 PM   #894
Fuck sushi rolls
rodrigo's Avatar
Groans: 356
i am...mostly. but u know the pcv shit this and that,..... then of course if i take the fucken IM off to re do pcv might as well clean it up and take a looksy inside the intake runners of the head etc etc... then might as well get a thermal spacer lol
it never ends man
NEVER ENDING STOOOOORY.........LALAL ALALALLALALA NEVER ENDING STOOOOORY
ahhh here it is
The Following 3 Users Say Thank You to rodrigo For This Useful Post:
ANMSPD3 (01-20-2011), djuosnteisn (01-18-2011), kgb (01-17-2011)
 Old 01-17-2011, 07:51 PM   #895
Must Have Teh 10's!
lol its better to be honest and accept the truth now then deny it and face the fail later
rodrigo (01-17-2011)
 Old 01-17-2011, 07:55 PM   #896
Fuck sushi rolls
rodrigo's Avatar
Groans: 356
unless soemthign happens again with flying dipsticks iu am leaving the car alone. just gonna practice my 60ft with sicks.....
the rest is out of my hands
 Old 01-17-2011, 07:57 PM   #897
bmylez's Avatar
Posts: 3,197   (View Stats)
Groans: 31
Wow...I had never seen that music video before (the movie, of course). I want that guy's hair...and facial expressions, holy shit.
2007 CTS-V - Trying to sell
 Old 01-18-2011, 10:44 AM   #898
Captain
If you take the IM off... might as well put inj seals in....
www.permtuning.com
rigor (01-19-2011), rodrigo (01-18-2011)
 Old 01-18-2011, 10:54 AM   #899
Trail of Fail
Dano's Avatar
it never ends man
ahhh here it is
I could have gone my entire life without seeing that video...
 Old 01-19-2011, 07:06 AM   #900
rigor's Avatar
Groans: 40
do they make such an animal?
tuned by nishan
 Old 01-19-2011, 09:02 AM   #901
Captain
2 weeks lol.
www.permtuning.com
The Following 4 Users Say Thank You to djuosnteisn For This Useful Post:
cld12pk2go (01-19-2011), Dano (01-19-2011), FreeFlyFreak (01-19-2011), rigor (01-20-2011)
 Old 01-19-2011, 09:11 AM   #902
Trail of Fail
Dano's Avatar
2 weeks lol.
x2 weeks...x2 weeks...right?
rigor (01-20-2011)
 Old 01-19-2011, 11:15 AM   #903
Fuck sushi rolls
rodrigo's Avatar
Groans: 356
oh man i just had a chance to watch the video.....holy shit this guy looks like hes taking one in the ass everytime he sings a high note....and loving life too i bet.
what a homo lol
 Old 01-19-2011, 07:47 PM   #904
socks's Avatar
Posts: 3,250   (View Stats)
Groans: 125
lenny, i saw the rabit go that way ------------------->
The Following User Says Thank You to socks For This Useful Post:
Dano (01-19-2011)
 Old 01-20-2011, 12:31 AM   #905
peruspeed3's Avatar
Posts: 326   (View Stats)
peruspeed3 has much to be proud ofperuspeed3 has much to be proud ofperuspeed3 has much to be proud ofperuspeed3 has much to be proud ofperuspeed3 has much to be proud ofperuspeed3 has much to be proud ofperuspeed3 has much to be proud ofperuspeed3 has much to be proud ofperuspeed3 has much to be proud of
dont pusss out lenny. turn the boost uo and ziptide that dipstick like i do lol
peruspeed3 is offline   Reply With Quote
 Old 01-20-2011, 01:22 AM   #906
Fuck sushi rolls
rodrigo's Avatar
Groans: 356
franco........ my shits old man.........remember......i still have the same motor from when u had an ms3 with a hood scoop on hahahahahahhahaha
hows the evo coming along????
i have the rabbit sean. its a lil guy but i got him
Last edited by rodrigo; 01-20-2011 at 01:22 AM. Reason: MSF Database - Automerged Doublepost
danesti (01-20-2011)
 Old 01-22-2011, 12:41 AM   #907
peruspeed3's Avatar
i hate u lol. just finish putting some miles on the carr and got tuned yesterday made 457whp 400tq 19 psi .. u should sell the ms3 man..
The Following User Says Thank You to peruspeed3 For This Useful Post:
FreeFlyFreak (01-22-2011)
The Following User Says NO Thank You to peruspeed3 For This Un-useful Post:
NJSPEED3 (01-22-2011)
 Old 01-22-2011, 01:02 AM   #908
Fuck sushi rolls
rodrigo's Avatar
Groans: 356
u made that at churchs??? damn son, whos gonna drive your car now? cuz last time i checked u couldnt handle 350whp...lol
congrats man, cant wait to see that car we r planning on taking a trip to bakersfield march 5th ...good track, lets go man!! y u always hiding
 Old 01-22-2011, 04:20 AM   #909
peruspeed3's Avatar
ya man will se man i beeen working a lot a going offshore. hopefully i will be back in march. i was thinking on going to the cobb openning shitt but is all crap haha dont like cobb but o well man im sure u will get to race me soon. probably gona take it to irwindale just to see what i trap
 Old 01-27-2011, 01:00 AM   #910
SgtP's Avatar
Posts: 2,130   (View Stats)
SgtP is the leader of the worldSgtP is the leader of the worldSgtP is the leader of the worldSgtP is the leader of the worldSgtP is the leader of the worldSgtP is the leader of the worldSgtP is the leader of the worldSgtP is the leader of the worldSgtP is the leader of the worldSgtP is the leader of the worldSgtP is the leader of the world
Groans: 106
poop
13.2@111
CP-E Nano, CP-E Inlet, CP-E catless DP, CP-E Standback V2, CPE FullThrottle/No Cut Flash, CP-E FMIC, CP-E CDFP, CP-E HKS BPV, TRZ Poly MM, E4P Shifter, Denso Iridium ITV22 plugs, CP-E Towplate, PG V3 Manifold w/EGT bung, Saikou Michi OCC, EGR delete, BSD w/oil baffle, BC Coilovers w/front camber adjustment, SPC rear arms, 17x8 Anthracite O.Z. Alleggerita's wrapped in Nitto NT01's
damn josh u are pretty.... i swear if tina hadnt taken you id so rail u
Certified Personal Trainer/Nutritional Consultant - I can cure Skinny, Fat and Weak
http://jpnutritionandfitness.blogspot.com/
Sponsored By: CP-E
SgtP is offline   Reply With Quote
 Old 01-27-2011, 02:36 AM   #911
Fuck sushi rolls
rodrigo's Avatar
Groans: 356
hey josh!!!! when we gonna see u???? and yeah, u getting a BT too man, u got a fast ms3 shit..... let me know when you are in town after u get settled in with the fmly man.
 Old 01-31-2011, 02:34 PM   #912
aaronc7's Avatar
Posts: 8,057   (View Stats)
Groans: 370
Blown up yet?? About to unsubscribe.
Sent from my Droid using Tapatalk
The Following 2 Users Say Thank You to aaronc7 For This Useful Post:
FreeFlyFreak (01-31-2011), thanox2 (01-31-2011)
 Old 01-31-2011, 03:06 PM   #913
Fuck sushi rolls
rodrigo's Avatar
Groans: 356
I could ask you the exact question aaron.... u can haz bodyparts everywhere in the sand???
aaronc7 (01-31-2011)
 Old 01-31-2011, 04:57 PM   #914
Trail of Fail
Dano's Avatar
don't know if I should thank that or not....def don't wish aaron to be blown to bits....stay safe counting those grains of sand man.
 Old 01-31-2011, 06:17 PM   #915
Fuck sushi rolls
rodrigo's Avatar
Groans: 356
did u not watch the video???
how the fuck is aaron gonna be in danger, when all this niggah is doing is fetching coffee for the colonel in charge of counting the grains of sand in the generals boots?
The Following 2 Users Say Thank You to rodrigo For This Useful Post:
aaronc7 (01-31-2011), FreeFlyFreak (01-31-2011)
 Old 01-31-2011, 06:57 PM   #916
Must Have Teh 10's!
mods?
 Old 01-31-2011, 07:01 PM   #917
Fuck sushi rolls
rodrigo's Avatar
Groans: 356
mods?
he drives an evo x with HTA 35r anthony lol.....
 Old 01-31-2011, 07:47 PM   #918
Trail of Fail
Dano's Avatar
yes I saw the vid did you not read my post...here let me highlight the important part/dig.
BTW when does the next vid drop?
overpriced winged boxes
hahahahaha
Last edited by Dano; 01-31-2011 at 07:47 PM. Reason: MSF Database - Automerged Doublepost
 Old 01-31-2011, 07:48 PM   #919
atvfreek's Avatar
Posts: 7,787   (View Stats)
Well I made it to page 7 looking for my answer. Wanted to know if you could get started with a k04 map on BT. Apparently you can. Sounds like your car was running good too...Fuck my eyes hurt. I'll continue reading later.
2010 Speed3-PTE5858
Freek built/Freektuned
510hp420tq
11.321@129.93
 Old 01-31-2011, 07:56 PM   #920
Fuck sushi rolls
rodrigo's Avatar
Groans: 356
i ran my tweaked OTS map from ko4 and no issues
PLEASE DO NOT ASSUME THIS WILL BE THE CASE WITH YOU!!!!! IF YOU HAVE AN mbc GO LOW BOOST AND SEE HOW EVERYTHING REACTS........TAKE YOUR TIME, NOT WORTH BLOWING UP FROM IMPATIENCE.
AJ713 (03-01-2011), cld12pk2go (01-31-2011), dougefresh_ (05-03-2011)
LinkBack to this Thread: http://www.mazdaspeedforum.org/forum/forum/f498/atp-3071r-swap-how-lenny-gets-bt-63559/
Boost Tapering Suggestions (GT3071R - Stock Block) This thread Refback 06-15-2011 04:10 AM
Turbo upgrade? This thread Refback 03-31-2011 01:44 PM
Turboaufladung » Internes Wastegate This thread Refback 01-31-2011 11:05 AM
APT 3071R ANMSPD3 MazdaSpeed 3/6 - Big Turbo Builds 47 04-16-2014 11:51 AM
Toyota exec tries to cool plug-in fever Haltech Automotive News 0 06-12-2008 07:20 AM
Toyota exec tries to cool plug-in fever Haltech Automotive News 0 06-11-2008 05:50 PM
Page generated in 0.59034 seconds with 34 queries
