![]() Join Date: Apr 2012 Location: Dominican Republic
Rep Power: 0 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 262
(Thread Starter) | Not Ranked : 0 score Have you had any Issues with It because of the divorced DP? Thanks.
__________________ [B]06 Speed6 Prosport Boost,Oil Tem.,Oil Press Gauge/Corksport DP/Corksport Catless RP/ITV22/Autotech Internals/Cobb AP/Corksport SRI (Stage 2)/JBR RMM/TWM stage2/CPE Safe Seal. GT3071 EWG Kit on stand by.... Waiting for more funds for suporting mod... |
| rabble rabble ![]() Join Date: Aug 2008 Location: Delawhere
Rep Power: 3167 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 9,400
Groans: 221
| Not Ranked : 0 score I dunno about the speed6, but the ATP wastegate flapper most definitely does not work with the MS3 corksport downpipe. It doesn't fit inside of the divorced section so its unable to open fully.
__________________ '08 CWP MS3 w/ T3 3071r |
| The Following 2 Users Say Thank You to 802MS3 For This Useful Post: | helmetface (06-09-2013), rfinkle2 (06-14-2013) |
(Thread Starter) | Not Ranked : 0 score Thanks for the response 802MS3. I already have the CS DP (First purchase with little knowledge of the platform and future plans with the car). The question Is because I'm planning on going big (GT30) and want to know what problems will I face with this DP. Will I have to change the CS DP or can I avoid spending more money on another DP and just go EWG GT30. I hope some of the MS6 guys can comment on this. Thanks anyway.
![]() Join Date: Jun 2011 Location: Norfolk, VA
| Not Ranked : 0 score I just purchased a GT3076 about a week ago from import image and they told me that my CS DP would not bolt about properly. Had to go with a whole with a complete bolt on turbo kit with a DP. That's my experience in the matter. Don't know to much but every little bit helps. |
@CorkSport;
__________________ 2006 Mazdaspeed6 FreekTune | 91 | JBR 3", PMM & RMM | CS Racepipe, TMIC & TMM Inserts | Autotechs ![]() | |
![]() Join Date: Jul 2011 Location: Fayetteville, NC
Rep Power: 0 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 1,655
| Not Ranked : 0 score You could just sell the dp, then buy a ebay v band dp.
__________________ [SIGPIC][/SIGPIC] |
| The Following User Says Thank You to StayBroke For This Useful Post: | SLOWHATCH (06-10-2013) |
(Thread Starter) | Not Ranked : 0 score I'll probably end up doing that but I want to se If I can avoid that and use It with a EWG If possible (Still researching). If I sell It I'll be shipping from Dom. Rep. because here I have not seen another speed 6 yet.
![]() Join Date: Nov 2012 Location: Milwaukee, WI
Rep Power: 0 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 1,192
Groans: 33
This makes me a sad panda as I had plans to go BT as well. Hopefully Corksport pops in and clarifies.
__________________ 2012 Velocity Red Mica Fast: COBB AP | Autotechs | JBR 3'' WP | CS DP | CS ABE | MDM RMM | JBR RSB | NGK Plugs | JBR SSP | ETS TMIC Rice: Aeroforce Interceptor | AEM M 35psi | Konig Milligrams 18x8.5 + 35 | Z1 Star Specs | JBR Mudflaps ![]() | |
![]() Join Date: Jun 2010 Location: Howell, NJ
Rep Power: 0 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 6,749
Groans: 124
__________________ 1995 Miata 1.8 2006 MS6 Sold |
![]() Join Date: Jan 2011 Location: Midlothian, Va
Rep Power: 0 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 12,042
Groans: 274
| Not Ranked : 0 score Even if it does "work" with BT, even if going EWG, it's still a restriction IMO. I would sell it and get something else. Definitely a great DP for stock frame turbos though. Curious if it works with the GTX2867. Last edited by SLOWHATCH; 06-10-2013 at 02:41 PM. |
| The Following User Says Thank You to SLOWHATCH For This Useful Post: | breakfstincluded (01-11-2014) |
Rep Power: 3747 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 8,744
| If you're looking to sell, I could be interested!
| Approved MSF Vendor ![]() ![]() Join Date: Mar 2008 Location: Vancouver, WA
Rep Power: 4731 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 1,820
| Not Ranked : 0 score The flapper design with the ATP versions we have seen the door hits the divider due to the different design they used. The downpipe does bolt up which means you would have to do some work to get the clearance needed to run it. -Derrick |
| The Following 2 Users Say Thank You to CorkSport For This Useful Post: | breakfstincluded (01-11-2014), rfinkle2 (06-14-2013) |
![]() Join Date: Jan 2012 Location: westland , mi
Rep Power: 0 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 517
| Not Ranked : 0 score I have it on my3 running the 3076 I have never seen any signs that the flapper is hitting the pipe when I have had it off but I do get creep above 22psi
__________________ 2012 Cadillac CTS-V ![]() 2014 focus st ![]() 2010 Taurus sho- sold 2009 speed 3 gt cwp -was once a monster -sold |
![]() Join Date: Sep 2011 Location: Charlotte NC
Rep Power: 0 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 3
| Not Ranked : 0 score Not sure if im beating a dead horse but I just put my 3076 on last night with the CS divorced DP and I had not issues BUT im running EWG so no flapper in the way
__________________ GT30R | Tial 38mm wastegate | HTP 3.5" intake | Corksport DP | BC Coilovers | JBR Camber Arms |JBR Trillogy Mounts | JBR OCC | Turbosmart Dual Port | Treadstone TR11 FMIC | Autotech HPFP Internals | NGK 2 stage colder plugs | Custom Straight Pipe | EVO X wheels TUNED BY LEX BROLO IS THE MOTTO BRO Movement |
Groans: 33
| Not Ranked : 0 score I'm very curious of this as well. I would run this or a BNR.
Groans: 370
| Not Ranked : 0 score Who cares if you can't control the boost, run ALL OF IT!!! |
| The Following User Says Thank You to aaronc7 For This Useful Post: | rigor (06-10-2013) |
| Not Ranked : 0 score Don't buy the ebay DP unless you want to deal with cracks.
| Not Ranked : 0 score Had one on my 3 and now the 6....no problems sent to you from me
| Corksport Downpipe speed6 | boosted_speed6 | MazdaSpeed 3/6 - Turbo Induction | 2 | 04-03-2011 11:11 PM |
