Like Tree118Likes
 Old 09-20-2013, 02:04 PM   #1
mazdafreak's Avatar
Posts: 2,610   (View Stats)
Groans: 124
Default Billet k04 Comp wheel upgrade!
Well I took the plunge after talking to my turbo guy thats local to me and who also assembled my bottom end for my ms3 and said this would be a nice lil upgrade for the k04 to make just a lil bit more power for me. Its a billet comp wheel, 50x65mm.....Says its good for 350-375 hp.
I have pushed my stock turbo to ~25lbs with timing maxed out on the dyno on 100% E85 with the help of clint tuning it for me last yr.....Had the car dynode @ 332whp and 390wtq.
So we'll see if I can push it over 350whp this time around with a built 11:1 CR bottom end now........I am sending the turbo out to my guy for the machine work which will also get a full rebuild/rebalance with a upgraded 360 degree thrust bearing and step gap piston ring.....All in all, this 'reworked k04' as you will, is costing me give or take $300, I have a hook up on machine work.
Juyoung and Hoyoman like this.
713whp/569wtq!
10.72 @ 139.44! (10/1/2015)
10.43 @ 140.95! 10/9/2015
10.35 @ 140.86 (10/30/2015)
The Following 22 Users Say Thank You to mazdafreak For This Useful Post:
BigRedSpecial (09-27-2013), Bolted6 (09-21-2013), Boosted Beluga (09-28-2013), btstarcher (09-26-2013), dead-zone (09-20-2013), Easter Bunny (10-07-2013), El_Diablo (09-25-2013), jack_hammer (10-11-2013), Juyoung (09-27-2013), lilred (09-25-2013), Mazdazilla6 (09-21-2013), Micha (09-26-2013), ms3blackmica (10-24-2013), redboat (04-08-2014), Roddiy (09-28-2013), sadak (11-04-2013), siegsuwa (09-20-2013), SLOWHATCH (09-20-2013), speed3sailor (09-20-2013), SPEED6 KILLAH (10-12-2013), Tomas (10-19-2013), torquemaniac (10-10-2013)
 Old 09-20-2013, 02:13 PM   #2
Police - Grammarhead
Vansquish's Avatar
Which one did you get? I've been thinking about doing turbo build based on the OE K04 as well, and this would be a pretty easy (and super cheap) way to go.
 Old 09-20-2013, 02:15 PM   #3
mazdafreak's Avatar
Groans: 124
50x65mm billet wheel.
713whp/569wtq!
The Following User Says Thank You to mazdafreak For This Useful Post:
Vansquish (09-20-2013)
 Old 09-20-2013, 02:17 PM   #4
dale_gribble's Avatar
Posts: 4,720   (View Stats)
Looks like a ninja star. Sub'd.
MINI H1 6.0 - CAR LED TAILS
chaser27 (10-15-2013), Juyoung (09-27-2013), lilred (09-25-2013), mazdafreak (09-20-2013), Rich990 (09-25-2013), silvapain (09-27-2013), Vansquish (09-20-2013)
 Old 09-20-2013, 02:23 PM   #5
Can't wait to see the results.
Juyoung (09-27-2013), mazdafreak (09-20-2013)
 Old 09-20-2013, 02:27 PM   #6
Are the dimensions any different from stock? The OEM housing limits the inducer dimensions.
The design of the wheel also looks the same as OEM so if the size is also identical flow will be the same given the machining is good. Billet wheels will be lighter and promote spool but this is less so on the already light compressor wheel and more so on the exhaust turbine wheel.
EDIT: Looks like the wheel is bigger and you're machining the compressor housing to accept it. You will see gains here. Hope it won't surge
 Old 09-20-2013, 02:27 PM   #7
mazdafreak's Avatar
Groans: 124
And this is what the turbo will be mounted too.....Fully bolted, built 11:1CR bottom end...((Don't mind the stock bpv, I have a synapse bpv going on as we speak))
713whp/569wtq!
The Following 4 Users Say Thank You to mazdafreak For This Useful Post:
El_Diablo (09-25-2013), Juyoung (09-27-2013), sadak (11-04-2013), SLOWHATCH (09-20-2013)
 Old 09-20-2013, 02:28 PM   #8
manila's Avatar
Posts: 1,767   (View Stats)
SUBB'D
What are your thoughts on running this with a stock block?
I see that your motor is built.
'12 MS3 Black Mica w/ Tech
 Old 09-20-2013, 02:32 PM   #9
mazdafreak's Avatar
Groans: 124
Its a k04 billet wheel.....Buts its a 50x65mm wheel......Comp housing obv has to get machined.....But the stock turbo comp wheel is 43m by 56mm....So its a slightly bigger upgraded wheel.....Even if I only make like 5-10hp, that's alright, cost me less than $300 for a lil more power and torque. If I was spending $500+, itd be a different story lol
713whp/569wtq!
The Following 3 Users Say Thank You to mazdafreak For This Useful Post:
Juyoung (09-27-2013), manila (09-20-2013), SLOWHATCH (09-20-2013)
 Old 09-20-2013, 02:34 PM   #10
Who makes that wheel? It doesn't quite look like the Turbolabs wheel. Kinda looks like a GTX wheel, but I can't tell.
 Old 09-20-2013, 02:34 PM   #11
mazdafreak's Avatar
Groans: 124
SUBB'D
I don't see a problem, just all depends how the tune is, how much torque, are u running e85, meth etc.
I have already maxed the k04 out at 332whp and 390wtq on stock block, which is a lot of torque for a stock bottom end.......but tune was set up to not have like full boost at such low rpms...... I rebuilt bottom end for I don't blow it up with all the torque just to be safe cause I planned on going BT later down the road.
713whp/569wtq!
The Following 2 Users Say Thank You to mazdafreak For This Useful Post:
 Old 09-20-2013, 02:36 PM   #12
With that size difference you will see more power than that. Only thing to watch for is surge since the comp wheel will now deliver more air at the same rotational speed as before.
helmetface (09-20-2013), mazdafreak (09-20-2013), redboat (04-08-2014)
 Old 09-20-2013, 02:38 PM   #13
mazdafreak's Avatar
Groans: 124
I got the wheel through turbolab, but I wasn't having them do the work cause they are super sketchy when I called them and talked about it all. I have my guy to do it and will be cheaper....They didn't say anything about a warranty, did say anything about rebuilding the turbo or anything....All they were telling me was $350 to install the wheel, that was it. I got the wheel, rebuild kit with upgraded thrust washer etc and having machine work for right around $300.
Only different is for some reason they sent me this wheel with the back cut flat. which sucks. but its w.e
Is there anything I can do to prevent the surge?
713whp/569wtq!
Last edited by mazdafreak; 09-20-2013 at 02:41 PM. Reason: MSF Database - Automerged Doublepost
 Old 09-20-2013, 02:45 PM   #14
manila's Avatar
Thanks for the input.
The Following 2 Users Say Thank You to manila For This Useful Post:
mazdafreak (09-20-2013), tbcota25 (04-19-2016)
 Old 09-20-2013, 02:58 PM   #15
mazdafreak's Avatar
Groans: 124
Yeah, I already want to go bigger, but I built the bottom end this yr, not looking to spend more money cause my setup will be a precision turbo.
713whp/569wtq!
 Old 09-20-2013, 03:01 PM   #16
dead-zone's Avatar
Posts: 442   (View Stats)
dead-zone is the leader of the worlddead-zone is the leader of the worlddead-zone is the leader of the worlddead-zone is the leader of the worlddead-zone is the leader of the worlddead-zone is the leader of the worlddead-zone is the leader of the worlddead-zone is the leader of the worlddead-zone is the leader of the worlddead-zone is the leader of the worlddead-zone is the leader of the world
Groaned at 53 Times in 17 Posts
Cool Shawn, let me know how it works out so i can do the same with my turbo :-) :-) :-)
mazdafreak likes this.
dead-zone is offline   Reply With Quote
The Following User Says Thank You to dead-zone For This Useful Post:
 Old 09-20-2013, 03:06 PM   #17
For surge, you will hear it if it's the case and if you do you might have to limit boost in those RPM regions.
mazdafreak (09-20-2013), snailD (11-02-2013)
 Old 09-20-2013, 03:16 PM   #18
helmetface's Avatar
Posts: 5,685   (View Stats)
Groans: 219
Listen for this, if you hear it..you'll know...
The Following 5 Users Say Thank You to helmetface For This Useful Post:
atvfreek (09-27-2013), Juyoung (09-27-2013), mazdafreak (09-20-2013), Micha (09-26-2013), redboat (04-08-2014)
 Old 09-20-2013, 11:53 PM   #19
mazdafreak's Avatar
Groans: 124
I guess we will see what happens! Sending turbo out to my guy for machine work tomorrow, so probably won't have it installed till late the following week week or so.
713whp/569wtq!
 Old 09-25-2013, 11:21 AM   #20
Rich990's Avatar
Posts: 274   (View Stats)
Rich990 is the leader of the worldRich990 is the leader of the worldRich990 is the leader of the worldRich990 is the leader of the worldRich990 is the leader of the worldRich990 is the leader of the worldRich990 is the leader of the worldRich990 is the leader of the worldRich990 is the leader of the worldRich990 is the leader of the worldRich990 is the leader of the world
in for good results.
got a link for that comp wheel?
2007 Velocity Red MS6
Go... BNR S3v2 / COBB APv3 / Snow Performance WMI + DO7 / nator'd DP / test pipe / HTP 3" SRI & TIP / 3 bar MAP / Autotech HPFP / NGK LTR7 / Stratified 3 port / Custom 3" TMIC / EGR delete / CP-E RMM / Turbine Tech FDM / CP-E RDM / Whiteline RSB / H&R springs / Powerbrake GT rotors / Endless MX72 Brakepads
Parts stockpile... Wiseco 88mm's / Manley H beams
Turbo stockpile... Borg Warner S200SX 7670 / GTX3071 / K04
Ex: 2007 Black Mica MS3 - stage 2 mods - 280 whp, 306 tq (321 whp / 358 tq before "stockout", on BNR S2 + meth)
Ex: 2010 Velocity Red MS3 - Stage 1 mods + Meth... 260 whp, 306 tq, stock exhaust
5500 ft altitude FTL
MSF in South Africa
Rich990 is offline   Reply With Quote
The Following User Says Thank You to Rich990 For This Useful Post:
mazdafreak (09-25-2013)
 Old 09-25-2013, 04:57 PM   #21
mazdafreak's Avatar
Groans: 124
I got the wheel through turbo lab. They also had it on ebay.
713whp/569wtq!
Rich990 (09-26-2013)
 Old 09-26-2013, 09:30 PM   #22
mazdafreak's Avatar
Groans: 124
Well i sent the turbo out to my guy....So im hoping to have it late next week or early the following week.
@rfinkle2; is going to be tuning the car!! We're gonna finalize it on the dyno, so we'll see what i can finally push out of the turbo now! My last dyno tune i had i made on 100% E85 was 332whp;390wtq.... So we shall see
WetzMS3 likes this.
713whp/569wtq!
rfinkle2 (09-28-2013)
 Old 09-26-2013, 09:43 PM   #23
Voltwings's Avatar
Posts: 3,713   (View Stats)
Really wanting to see before / after dyno's. We have a local turbo shop thats been pushing billit wheel upgrades, and the prices arent far off what you've been mentioning.
Past:
-Sold-
-Sold-
Current:
2012 Loaded Speed3 - Stock
2001 Miata - Basically stock
Juyoung (09-27-2013), mazdafreak (09-26-2013)
 Old 09-26-2013, 10:04 PM   #24
mazdafreak's Avatar
Groans: 124
Hmmm, I def would, but don't have extra money for more dyno time........ if rob wants to spend the extra time, just incase the billet wheel k04 needs retuning for some reason, ill do a before/after results. That's up to him. Myself would rather just have it all done at one time. Either way works tho.
I have my before results on dyno. Only difference now is 11:1CR bottom end and 3.5" intake w/ 3 port ebcs.
713whp/569wtq!
Koke382 (09-26-2013), Micha (09-27-2013)
 Old 09-26-2013, 10:56 PM   #25
Voltwings's Avatar
I'll take some Decent Vd's / logs with a grain of salt too I suppose, its all the same. Although I suppose that compression change is going to throw a wrench in things ... oh wells.
Koke382 likes this.
Past:
-Sold-
-Sold-
Current:
The Following 3 Users Say Thank You to Voltwings For This Useful Post:
Koke382 (09-26-2013), mazdafreak (09-26-2013), Micha (09-27-2013)
 Old 09-26-2013, 11:24 PM   #26
mazdafreak's Avatar
Groans: 124
Like I said, all up to rfrinkle if he doesn't mind having to tweak map/start all over incase the k04 with billet wheel changes stuff.
I don't mind before and after. We'll let rob answer if he wants too lol
713whp/569wtq!
 Old 09-27-2013, 08:52 PM   #27
Jeff23spl's Avatar
Posts: 2,233   (View Stats)
Do you expect it could surge because of the small size of the turbine wheel vs this new large compressor wheel
by the way the stock inducer size was looking more close to 45mm on my speed3 and 42mm for the cx7. But 5mm in and 9mm out is a huge change !
I'm in a hurry to read about the results!
11:1 CR for a turbo engine isn't a little bit abusive ? Is it a dayly drive ?
1993 Ford Probe KLZE 143dB
1989 GM 6.2 diesel pickup
Wife drive 2010 CX7
...Because French Canadian...
 Old 09-27-2013, 09:19 PM   #28
mazdafreak's Avatar
Groans: 124
No, I don't think its abusive. And no, its not daily driven and doesn't see rain or snow.
Plus I run 100% E85.
I'm gonna have a 100% E tune and Racegas dyno results if rfrinkle loves me enough to do two tunes lol.
713whp/569wtq!
 Old 09-27-2013, 10:39 PM   #29
Eth Fiend
phate's Avatar
Posts: 6,947   (View Stats)
Low compression is low
-06 MS6
-Corn fed 07 MS3 - Sold
The Following 6 Users Say Thank You to phate For This Useful Post:
btstarcher (09-28-2013), Little John (09-27-2013), mazdafreak (09-27-2013), rfinkle2 (09-28-2013), Roddiy (09-28-2013), Speed_j23 (10-09-2013)
 Old 09-27-2013, 10:48 PM   #30
Micha's Avatar
Posts: 3,436   (View Stats)
Showoff.
The Following 5 Users Say Thank You to Micha For This Useful Post:
Little John (09-27-2013), mazdafreak (09-27-2013), phate (09-27-2013), rfinkle2 (09-28-2013), Roddiy (09-28-2013)
 Old 09-27-2013, 10:57 PM   #31
mazdafreak's Avatar
Groans: 124
Well lower than yours but higher than most!
713whp/569wtq!
 Old 09-28-2013, 03:07 PM   #32
Jeff23spl's Avatar
Yes very low CR is slow and higher CR is good for efficiency but above 10 it is usually for low stroke high rev engine or at least for cam with higher duration and lift...Do you plan something it this area ?
In a long stroke like ours, the torque you get with 11:1 CR shoud be awesome? But what about at higher rpm ? With the stock K04 does it fell like a Turbo Diesel ?
Probably no lag at all? but you would always need high octane gaz and maybe limit your max boost level ?
very low CR sucks like i used to drive a 7.8:1 2.0l (4G63T) Talon awd and you almost need boost to move the car. Without, it fell like 25hp and die when you release the clutch too fast...
Wife drive 2010 CX7
 Old 09-28-2013, 03:09 PM   #33
Snyeed's Avatar
Posts: 743   (View Stats)
Groaned at 8 Times in 4 Posts
subbed for results, go ewg!
417whp 428tq 12.037@117.2mph
mazdafreak (09-28-2013)
 Old 10-06-2013, 11:44 PM   #34
mazdafreak's Avatar
Groans: 124
Still waiting on turbo to be done.
Looks like we may be going with an ewg on this k04 and run a 4-port ebcs.
713whp/569wtq!
rfinkle2 (10-07-2013)
 Old 10-07-2013, 06:58 AM   #35
Eth Fiend
phate's Avatar
Your comparison of wheels is essentially invalidated if you switch to an EWG. It should allow for more top end power, because you are able to bleed off some of that backpressure that I'm sure the K04 creates.
-06 MS6
mazdafreak (10-07-2013), rfinkle2 (10-07-2013), Voltwings (10-07-2013), wolly6973 (10-07-2013)
 Old 10-07-2013, 07:52 AM   #36
Jeff23spl's Avatar
I was curious about 1 thing and if i didn't switch to GT28, i would have installed something to read the wastegate actuator rod position during WOT conditions when i call 100% of WG duty to see if the WG is still completly closed or open because of exaust gaz pressure on the flap...
In the case where the WGA remain closed, having an internal or external WG wouldn't make any difference?
If it opens a little, the external WG could help or maybe a 3 way EBC to unload the WG spring completly....
I was about to install a linear potentiometer on the WGA rod to transmit a voltage signal according to the rod position but i switched to GT28 first...
By the way, every turbo create exaust restriction, it is the reason why 15psi with a K04 make less flow than a 15psi with a GT3582r....But i don't think the top end power is only a small turbo related issue. If you look at manny dyno graph of BT users, even if boost remain constant to redline, the power drop at almost the same RPM level as it doest with K04...
Wife drive 2010 CX7
 Old 10-07-2013, 08:05 AM   #37
StayBroke's Avatar
Posts: 2,075   (View Stats)
Really cant wait to see this.
When i spoke to turbolab they said they where rebuilding my k04, machine the housing, install the wheel, and then balance the center section.
The Following User Says Thank You to StayBroke For This Useful Post:
 Old 10-07-2013, 08:07 AM   #38
amoosenamedhank's Avatar
Posts: 1,368   (View Stats)
amoosenamedhank is the leader of the worldamoosenamedhank is the leader of the worldamoosenamedhank is the leader of the worldamoosenamedhank is the leader of the worldamoosenamedhank is the leader of the worldamoosenamedhank is the leader of the worldamoosenamedhank is the leader of the worldamoosenamedhank is the leader of the worldamoosenamedhank is the leader of the worldamoosenamedhank is the leader of the worldamoosenamedhank is the leader of the world
Groans: 53
Groaned at 31 Times in 22 Posts
If he shows appreciable gains, at least we'll know his solution as a whole works. You might not know what was the compressor wheel, and what effects the EWG had.... but it's a low cost solution overall.
You know.... Moose stuff
amoosenamedhank is offline   Reply With Quote
The Following 2 Users Say Thank You to amoosenamedhank For This Useful Post:
mazdafreak (10-07-2013), memin (10-08-2013)
 Old 10-07-2013, 06:08 PM   #39
mazdafreak's Avatar
Groans: 124
Well we/or u kno that my car was done at 332whp. I don't see any k04 ever going over 340whp, unless happy dyno.
All I'm looking at is if I can make over what I did last yr with billet wheel, ewg will just hopefully help up top like u said. Results should give a good idea what turbo is capable of. Just trying to get it all done before all this cold weather moves in!
I just don't kno what wastegate @rfinkle2; wants me to run, since he doesnt like messaging me back through email haha , so I can order all those parts
713whp/569wtq!
Elvisrosales88 (10-29-2013)
 Old 10-08-2013, 07:16 AM   #40
lilred's Avatar
Posts: 5,792   (View Stats)
Busy man is busy, man. Lol
tapafuck
2010 velocity red mica ms3
AP/AT internals
JBR SSP/bushings
JBR RMM
JBR stage 2 OCC
CS test pipe
The Following 6 Users Say Thank You to lilred For This Useful Post:
09Speed3Z (10-25-2013), Easter Bunny (10-08-2013), Elvisrosales88 (10-29-2013), mazdafreak (10-08-2013), StayBroke (10-08-2013), Tokay444 (10-08-2013)
LinkBack to this Thread: http://www.mazdaspeedforum.org/forum/forum/f498/billet-k04-comp-wheel-upgrade-155583/
Mps 3 and cx7 question - Page 3 This thread Refback 08-18-2014 06:27 AM
Custom Billet Wheel Spacers hnda etr MazdaSpeed 3/6 - Wheels & Tires 9 01-10-2011 11:45 PM
Extreme wheel Upgrade DIY ... Feels faster ;-) jamesthebikeguy MazdaSpeed 3/6 - Wheels & Tires 15 07-28-2009 01:37 PM
Billet compressor wheel upgrade for the stock turbo!!!! ptperformance Mazdaspeed3/6 General Discussion 52 05-13-2009 05:20 PM
endlink upgrade needed w/ ASB upgrade? red07 MazdaSpeed 3/6 - Suspension & Brakes 12 11-26-2008 01:34 AM
Page generated in 0.60041 seconds with 37 queries
