![]() | | #401 | ![]() |
Groans: 31
| Not Ranked : 0 score What do you mean by EM? Engine management? You need a fuggin tune if you're upgrading a turbo!
![]() | | #402 | ![]() |
![]() Join Date: May 2011 Location: Orlando, Florida
Rep Power: 0 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 1,305
Groans: 386
| Not Ranked : 0 score Okay, thanks for the quick response. I have my eye on one of these right now.
__________________ BNR3-FREEK-PU-398HP I lost track of the mods in my car. |
![]() | | #403 | ![]() |
![]() Join Date: Jul 2008 Location: Syracuse, NY
Rep Power: 2506 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 2,527
| Not Ranked : 0 score I think you can run a TMIC with a larger core, but a HPFP is definitely strongly suggested. Really to get the most out of it you should upgrade certain components.
__________________ ![]() Anthony D. Christiano - Co-Owner at Inspiration Studios Photography 2008 CosmicBlue Mazdaspeed3 294whp/335wtq - Stock K04 370whp/370wtq - BNR stage 3 FreekTuned, BNR Stage 3, Cobb AccessPort, HTP tray and 3" intake, Devil's Own Meth Injection D10 Nozzle, 3-Bar Map & Plug & Play Connector, PTP Injector Seals & Studs, KritzSpeed 3-Port BCS, Sure Return, UR Downpipe, CorkSport Race Pipe, Magnaflow Cat-back, CP-E FMIC, TWM STS, TWM A6 Leopard Shift Knob, TWM Leather Shift Boot, AutoTech Fuel Pump Internals, JBR trinity, Forge Version 2 BPV, Koni Yellows, H&R's, Sonic Tuning ST100's 18x8.5 + 5/16" spacer (ET40), SPC camber arms, Cobb Rear Sway Bar, Nitto NT05 235/40/18 (front) BF Goodrich g-Force Sport 235/40/18 (rear), MSD DashHawk, 35% tint, Semi-debadged ...Unicorn Jizz |
![]() | | #404 | ![]() |
Groans: 31
dereeek, you could drop a BNR3 right in and start tuning. Car will be pretty fast.
__________________ 2007 CTS-V - Trying to sell 2009 CTS-V - Not getting a cam. Ever. | |
| The Following User Says Thank You to bmylez For This Useful Post: | dereeek (12-17-2011) |
![]() | | #405 | ![]() |
| Not Ranked : 0 score Missed that, sorry, d00d.
![]() | | #406 | ![]() |
![]() Join Date: Feb 2012 Location: Richmond, VA
Rep Power: 0 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 3,815
Groans: 255
| Not Ranked : 0 score Subbed for Research
__________________ "Stockish" Black Mica 2010 MS3 Genpu Pickles Tune in progress |
![]() | | #407 | ![]() |
![]() Join Date: Jan 2011 Location: Vancouver, WA
Rep Power: 0 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 4
| Not Ranked : 0 score still no solid side by side numbers?..?..?.. |
![]() | | #408 | ![]() |
Groans: 31
| Not Ranked : 0 score Side by side numbers between k04 and BNR? No need. Ziggo is making about 390whp with a few gallons of e85. When I had one on my car with 93 oct and a little meth, traction was hard to come by. It kicks the k04's ass, no debate.
![]() | | #409 | ![]() |
![]() Join Date: Jul 2010 Location: Little Rock, AR
Rep Power: 0 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 1,444
| Not Ranked : 0 score I made the numbers in my sig with minimal supporting mods. I'm still on 22psi because no 3 bar map yet like Ziggo. So 380, 390 is definitely possible with this turbo.
__________________ BNR S3 // E85 Mix // Freektune 348tq/367whp -21.5 psi Now - 25-26 psi + JBR 3.5 Intake |
| The Following User Says Thank You to ckMS3 For This Useful Post: | atvfreek (07-05-2012) |
![]() | | #410 | ![]() |
Groans: 255
Here is what I believe is the bare minimum equipment to get the most out of your BNR Stage 3. Cobb AP Upgraded Fuel Pump Internals EBCS or MBCS (You could technically use the oem EBCS and a Restrictor Pill, but it is slower to react) 3 BAR MAP sensor and Harness One Step Colder Plugs E-Tuner Highly suggested upgrades: Guardian Angel Upgraded Intercooler Upgraded Intake and TIP Upgraded Exhaust (Downpipe and or Test Pipe) Aftermarket Exhaust Manifold Upgraded Motor Mounts Stainless Steel Braided Brake Lines One more thing, I noticed that certain TIPs, such as the CP-E one, might have a hard time connecting to the BNR Stage 3 since the part where the TIP clamps too is a bit wider than the Stock K04. I had to use a larger clamp to get my CS TIP to fit.
__________________ "Stockish" Black Mica 2010 MS3 Genpu Pickles Tune in progress Last edited by himurax13; 07-05-2012 at 05:55 PM. | |
| The Following User Says Thank You to himurax13 For This Useful Post: | ckMS3 (07-05-2012) |
![]() | | #411 | ![]() |
| Not Ranked : 0 score I have a cnt tbe, cobb sri/inlet, cx racing/pg fmic, forge v1, grimmspeed 3-port, and 3 gallons of e85 with a great tune by atvfreek and made 367. Now with a JBR full 3.5 intake and a 3 bar map to up the boost to 24-25psi 380whp is definitely within reach.
![]() | | #412 | ![]() |
Groans: 255
| Not Ranked : 0 score That should be attainable. I am also looking for a similar goal.
![]() | | #413 | ![]() |
| Not Ranked : 0 score I think it's plenty of power and safe too.
![]() | | #414 | ![]() |
Groans: 255
| Not Ranked : 0 score And the best part is, I still won't be fully bolted and practically emmissions legal.
![]() | | #415 | ![]() |
Groans: 31
Also, braided brake lines? No.
| The Following User Says Thank You to bmylez For This Useful Post: | breakfstincluded (07-06-2012) |
![]() | | #416 | ![]() |
Groans: 255
Braided Brake Lines and switching over to DOT4 made a night and day difference over the stock lines.
__________________ "Stockish" Black Mica 2010 MS3 Genpu Pickles Tune in progress | |
![]() | | #417 | ![]() |
![]() Join Date: May 2011 Location: Portland OR
Rep Power: 0 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 6,451
I dont see why an upgraded k04 would call for brake parts lol
__________________ Genwin Individual Throttle Body Webers 20B Swapped 1UZ w/ Hi-Cap Purple Loush and Trigonometric Valve Tumblers. Thetan Core Fogger System. P1@n0 Tuned to Load Burst Limit. Glacier Red '07. | |
![]() | | #418 | ![]() |
Groans: 255
![]() For about $105 worth of stuff and 1.5 hours worth of time, it is an upgrade that may save your arse.
![]() | | #419 | ![]() |
| Not Ranked : 0 score I still don't see how this advice to applies universally to anyone doing a bnr lol
![]() | | #420 | ![]() |
Groans: 255
![]() | | #421 | ![]() |
| Not Ranked : 0 score ah then you should also change oil too then, you don't want bad oil on a new turbo, if you do balance shaft delete you can have even more oil capacity too I would also clean my floor mats, you dont want your feet to be slipping around with more power on your car
![]() | | #422 | ![]() |
Groans: 255
I am on the fence about the balance shaft delete. I had to clean my rubber floor mats after we spilled quite a bit of coolant during the turbo install. ![]() In all honesty, I don't think the valve cleaning was beneficial.
LinkBack to this Thread: http://www.mazdaspeedforum.org/forum/forum/f498/bnr-stage-3-turbo-51531/ | ||||
| Flip UltraHD Camcorder, 120 Minutes (Black) | This thread | Refback | 06-25-2012 04:08 PM | |
| 404 Not Found | This thread | Refback | 06-15-2012 05:23 AM | |
| FS: Cooling mist Meth kit with m10 nozzle | This thread | Refback | 05-15-2012 12:41 PM | |
| 318racing.org • View topic - FS: Cooling mist Meth kit with m10 nozzle | This thread | Refback | 02-25-2011 09:47 PM | |
| Geneva Preview: Techart to debut 911 Turbo, Turbo S | Haltech | Automotive News | 0 | 02-16-2010 03:20 PM |
| Interesting look at Stage 1 + SF vs. Stage 1 + MSCAI2 maps, similarities and differences | bast525 | Cobb ATR Support | 4 | 05-24-2009 07:52 PM |
