![]() Join Date: Feb 2009 Location: Chambersburg, PA
Rep Power: 0 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 7,921
Groans: 338
(Thread Starter) | Neutral : -1 score Was going to originally go with a gtx with atp hotside. But work bonuses are no longer that big at work. So bought the turbo used (buyer said roughly 5k miles) and jewed out on other things to save money. All in all all parts were bought for under 1500 total. I figured if I went the route i was going (gtx with ATP hotside) would have been closer to 2300. 800 dollars that can be spent on hookers and blow. Would have been cheaper if I decided to stay stock intake. But decided to open that up. Parts: GT3076 ATP IWG hotside (came with: Coolant in line, low profile oil feed banjo, coolant return barbed banjo fitting) Treadstone 3" maf Treadstone 2" silicon hose and 2" coupler (will be coupled to ets tmic) 2x Treadstone garrett/efr 10an drain flanges (much cheaper then ATP with integrated gasket and no need for step down studs) 10an drain line lubed with doubleflusher's man juice Silicon intakes 3" 45 degree elbow HTP 3" turbo inlet with 3" to 4" reducer (not picture being fabbed) Various tbolt and worm clamps, new crush washers, studs Hallman Pro RX boost controller in homo purple 3 bar map still needs to be ordered Everything GT3076 Decided to do a little porting to the flapper area with a dynafile and some rotary grinding stones. Inside the turbine housing Flapper side with half moon bit of metal taken out and smoothed the transition greatly Once I get my TIP in I'll start getting ready for the build and snapping some pics along the way to hopefully help anybody else going the bolt on route. Not that it hasn't been done before.
__________________ Current: N54 135i DCI, DP's, Exhaust, FMIC 12.3@122 2009 Mazdaspeed 3: GT3076 - Corkey tuned Treadstone 3" MAF, HTP 3" turbo inlet, MSCBE, Turbo XS FMIC, CNT catted DP, CP-E HPFP, Tial QR BPV, SURE TIG's, ITV24's, CP-E Stage 2 RMM, Medefail Tranny mount, 18x8 245/40's 390whp/400wtq 12.8@114 Sold Last edited by 86AmishMs3; 02-03-2012 at 07:01 PM. Reason: MSF Database - Automerged Doublepost |
| The Following 15 Users Say Thank You to 86AmishMs3 For This Useful Post: | AZSPEED3 (11-26-2011), breakfstincluded (11-26-2011), Broxer (03-17-2012), Dahouse702 (12-16-2011), Darksun280 (11-26-2011), doubleflusher (11-26-2011), Frequentflyer (12-19-2011), Hamilton69 (11-26-2011), jracer (11-26-2011), kritz (11-26-2011), mzr0818 (11-26-2011), rtabagaboy (11-26-2011), Scribbles (11-26-2011), uncorked11 (11-26-2011), wankular (12-12-2011) |
| The Following User Says NO Thank You to 86AmishMs3 For This Un-useful Post: | Vansquish (11-26-2011) |
![]() Join Date: Nov 2010 Location: Lido Beach,NY
Rep Power: 8624 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 17,845
Groans: 95
| Not Ranked : 0 score In for build pics.
__________________ Nator is what it does. |
| The Following User Says Thank You to kritz For This Useful Post: | 86AmishMs3 (11-26-2011) |
Groans: 433
| Not Ranked : 0 score you say you're staying TMIC? i'd use that $800 put aside for hookers and blow and get fmic.
| The Following 2 Users Say Thank You to Chimmike For This Useful Post: | 86AmishMs3 (11-26-2011), ZoomByU (12-22-2011) |
![]() ![]() Join Date: Apr 2011 Location: Winston-Salem, NC
Rep Power: 3104 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 7,046
Groans: 221
| Looks good.
__________________ EMWNM 2013 Beating Black women one 5.0 at a time... ![]() 2008 mazdaspeed 3 true red Tuned by Nishan , 33% E85, GTX3067r Boost?, Yeah I got some., Port and polish manifold, XS power Tubular Exhaust Manifold, Wiesco pistons, K1 rods, L19 head studs, ARP crank studs, Cobb three port EBCS, Forge BPV, CXRacing FMIC with TR8 core, cobb AP V2, EBC redstuff full, DBA 4000 rotors 6x6 slotted, HTP 3" full intake, JBR 88d rmm, JBR 80d pmm, JBR 80d tmm, CNT catted DP, Magnaflow CBE, KMD internals, Koni Yellows, Moog endlinks, Moog lower control arms, OZ ultraleggera 18x8, Mich Pilot Super Sports 235/40/18, Hotchkis RSB, NGK step colder plugs.![]() Build in progress. Track whore in the making. |
| The Following User Says Thank You to mzr0818 For This Useful Post: | 86AmishMs3 (11-26-2011) |
![]() Join Date: Feb 2010 Location: Philadelphia, PA
Rep Power: 0 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 323
| Not Ranked : 0 score 3076 should put you in the 450 range shouldnt it.
__________________ 2009 Metro Grey Numbers Fully Bolted. Nator Pa Dyno Day: 311HP 328TQ Pump 93 Nator Pa Dyno Day: 310HP 329TQ Pump 93 End of Drive 9/24/2013 2012 Liquid Silver Cobb AP |
| The Following User Says Thank You to irishking03 For This Useful Post: | 86AmishMs3 (11-26-2011) |
![]() Join Date: Jul 2011 Location: Santa Fe, NM
Rep Power: 0 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 9
| Not Ranked : 0 score Your gunna need a 21/2 to 2in reducer piece of silicone for the inter cooler hot pipe from your Turbo
__________________ [SIGPIC][/SIGPIC] 1992 miata, track beast here I come with 2 bride seats!! (current)3076r speed6 owner (traded) 2000 camaro 415rwhp thru midwest chassis fab (sold) |
| The Following User Says Thank You to ColonR For This Useful Post: | 86AmishMs3 (11-26-2011) |
Groans: 338
Negative, tmic is a 2" coupler.
__________________ Current: N54 135i DCI, DP's, Exhaust, FMIC 12.3@122 2009 Mazdaspeed 3: GT3076 - Corkey tuned Treadstone 3" MAF, HTP 3" turbo inlet, MSCBE, Turbo XS FMIC, CNT catted DP, CP-E HPFP, Tial QR BPV, SURE TIG's, ITV24's, CP-E Stage 2 RMM, Medefail Tranny mount, 18x8 245/40's 390whp/400wtq 12.8@114 Sold Last edited by 86AmishMs3; 11-26-2011 at 10:09 AM. Reason: MSF Database - Automerged Doublepost | |
| The Following User Says Thank You to 86AmishMs3 For This Useful Post: | m249saw (12-21-2011) |
![]() Join Date: Nov 2010 Location: AZ
Rep Power: 0 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 432
| Not Ranked : 0 score Shit, finally. You've been talking about this forever. We also have the exact same carpet O.o Congrats on finally getting everything together, 76 wont disappoint you. Let us know if you need help installing this
__________________ 07 MS3 Built motor with K1 rods/wesico pistons, ATP 3076r, SS Mani, ATP DP, Cobb FMIC V2, CPE FP, TurboSmart MBC, TurboSmart Dual Port BOV, Hotchkis RSB FSB, BC Coilovers, AP, Dashhawk, Trilogy JBR 88 duro's, JBR catch can, Guardian Angel Perm |
| The Following User Says Thank You to Scribbles For This Useful Post: | 86AmishMs3 (11-26-2011) |
![]() Join Date: Nov 2010 Location: Westminster, CO.
Rep Power: 0 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 66
| Not Ranked : 0 score Has anyone really successfully run a TMIC on a BT build? I know I was having major heat soak issues on mine before I even went BT. My tuner told me to not even bother. Oh well, FMIC look sick anyways! Good luck with the build, man!
__________________ 2010 Mazdaspeed3 - Garrett GT3076R Turbo, SteedSpeed Manifold, Tial 38mm External Wastegate w/ Dump Tube, ATP Big MAF Housing, ATP 3" TIP/Intake, HKS SSQV BOV, Ultimate Racing FMIC, Ultimate Racing Catless DP, CS Test pipe, CS Catback Exhaust, Autotech HPFP Internals, Hallman Pro Boost Controller, Cobb AccessPORT, BC Coilovers, DDM 8000k HID's, Red Brake Calipers w/ Decals, Custom Smoked Headlights, Smoked Taillights, 18% Window Tint. 2011 Mazda2 Sport - OEM Fog Lights, OEM Touring Rear Spoiler, Sport Edition F2 Silver Wheels, Green Brake Calipers, 18% Window Tint, Social Engineering - Because there is no patch for human stupidity. |
| The Following User Says Thank You to spoof3r For This Useful Post: | 86AmishMs3 (11-26-2011) |
![]() Join Date: Jun 2011 Location: Union City, CA
Rep Power: 0 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 137
| Not Ranked : 0 score Looks like my turbo went into the right hands. good luck with the build! Did you get a tap for the boost source?
__________________ 2006 Mazdaspeed6 GT GTX3582 T3 .82 A/R // Wiseco Pistons // K1 Rods // H11 Head Studs// Steedspeed Top Mount Manifold // TiAL MVR // TiAL MVS // PERM Top Mount Kit // NGK plugs // Custom FMIC // Cobb AP // Bosch 3 Bar MAP// Magnaflow Exhaust // MSD Dashhawk // RPM Springs //JBR STG 2 OCC // JBR EGR Delete //Autotech Fuel Pump Internals // SU Motor Mount // Prosport Boost Guage // ACT 6 Puck //Fiber Images Carbon Fiber Hood // Snow Performance Stage 2 WMI, d10 & d12 nozzles // Corn Fed 516whp/476tq - Mega Meat 2013 [SIGPIC][/SIGPIC] |
| The Following User Says Thank You to 6oost3d For This Useful Post: | 86AmishMs3 (11-26-2011) |
Groans: 433
| Not Ranked : 0 score I'm not concerned about the core size on the ETS, the heatsoak is the problem. FMIC will never heatsoak as much as a TMIC will and will constantly see better flow. anywho, good luck
| The Following User Says Thank You to Chimmike For This Useful Post: | 86AmishMs3 (11-26-2011) |
Rep Power: 3747 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 8,744
| You'll have to excuse me for this. I may be putting myself directly in the line of fire for a bunch of flaming, but just how offensive are you trying to be? Your build looks like it could be a lot of fun, and I'm glad for the info and pictures, but the way you titled this thread, and the way you're talking about this is incredibly racist, anti-semitic and offensive. I normally don't take offense to this sort of thing, but I can't understand why you'd even say that you're "Jewing" your way to something (and yes, I do understand what the phrase means). I hope you can change the title and your post, but if you can't, I hope you at least change the language you use in the future. |
| The Following User Says Thank You to Vansquish For This Useful Post: | free_refil (01-09-2012) |
| The Following 12 Users Say NO Thank You to Vansquish For This Un-useful Post: | 86AmishMs3 (11-26-2011), Danish (12-20-2011), Easter Bunny (12-18-2011), jracer (12-10-2011), jroc (11-26-2011), Mac21 (12-21-2011), psychophyr (12-09-2011), Realgib3 (11-27-2011), Roddiy (12-18-2011), rtabagaboy (11-26-2011), sheldonross (12-21-2011), ZoomByU (12-22-2011) |
| COOL STORY BRO ![]() Join Date: Nov 2010 Location: Cape Girardeau Mo/San Diego CA
Rep Power: 2238 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 1,863
Groans: 179
Groaned at 179 Times in 30 Posts
| Neutral : 0 score slang term....i found it humorous
__________________ ![]() JBR 3.5" WHALE PENIS-su tmic- sure track urethane rmm- corksport catless 3" downpipe- ultimate racing tp-OBX 3" cat back -rally armor urethane flaps-Cobb Accessport FINKLE TUNED-sure shift anchors-autotech hpfp internals-HKS BOV VTA -jbr heavy shift knob- 245-40-r18 Falken 329's-paint matched uber smiley ZOOM ZOOM BOOM |
| The Following 5 Users Say Thank You to Hamilton69 For This Useful Post: | 86AmishMs3 (11-26-2011), Danish (12-20-2011), jracer (11-26-2011), jroc (11-26-2011), TriO (04-11-2012) |
Groans: 31
| Neutral : -1 score
Good luck to ya, OP. Car will be beast mode.
__________________ 2007 CTS-V - Trying to sell 2009 CTS-V - Not getting a cam. Ever. | |
| The Following 3 Users Say Thank You to bmylez For This Useful Post: |
| Not Ranked : 0 score looks like fun....if you are going MBC why get an upgraded MAP?
| The Following User Says Thank You to Dano For This Useful Post: | 86AmishMs3 (11-26-2011) |
![]() Join Date: May 2009 Location: Clw/ NPR Florida
Rep Power: 0 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 10,516
Groans: 89
| Neutral : 0 score Good build ! No offended taken . Other dude needs to chill. We all are Jews when buying parts when money is tight ! Lol
__________________ [SIGPIC][/SIGPIC] 2013 EVO X GSR Wicked White w/Areo H&R springs/H&R 15mm spacers MAP modified 3" Magna Flow cat back MAP catless testpipe MAP UICP Grimmspeed 3 port Cosworth filter SSP relay kit TWM Desert Eagle shift knob AEM wideband gauge Prosport boost gauge EvoX piller pod 30%Tint Slowpoke Tuned 339hp/336tq **** SOLD ***** 2006 speed6 " A woman's asshole is like a 9-volt battery..U know its wrong, but sooner or later ur gonna put ur tongue on it !! " |
| The Following 7 Users Say Thank You to jracer For This Useful Post: | 86AmishMs3 (11-26-2011), dougefresh_ (12-09-2011), jayspeed3 (11-27-2011), jroc (11-26-2011), memin (12-18-2011), speedyspaghetti (12-07-2011), TriO (04-11-2012) |
Groans: 31
| Not Ranked : 0 score So he can log boost?
| The Following User Says Thank You to bmylez For This Useful Post: | 86AmishMs3 (11-26-2011) |
![]() Join Date: Jun 2010 Location: corpus christ, tx
Rep Power: 0 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 1,316
Groans: 68
| Not Ranked : 0 score agreed, I felt like I was adjusting MBC blind once I went over 23 psi. I dont trust my boost guage really lol
__________________ 2006 MS6 -GTX3076 .82 AR-Steedspeed Topmount mani-DJ/PERM Top mount Kit with PERM tune-CXracing FMIC-Tial .44mm WG - KMD Internals- Sure RDM, Turbine tech FDM and FMM=JBR trilogy MM- Whiteline rear sway- eibach prosport springs-jbarone SSP-COBB AP-ACT 6PUCK- ITV22-Prosport Spin On Conversion-Snow Performance stg 2 Meth-CPE Injector seals-Matt Damon OCC |
| The Following User Says Thank You to crazyp For This Useful Post: | 86AmishMs3 (11-26-2011) |
![]() | | #19 | ![]() |
Groans: 338
(Thread Starter) | Neutral : 0 score
MAP sensor is cheaper then boost gauge haha. Plus one day i might try ebcs. But for ease of tuning mbc.
__________________ Current: N54 135i DCI, DP's, Exhaust, FMIC 12.3@122 2009 Mazdaspeed 3: GT3076 - Corkey tuned Treadstone 3" MAF, HTP 3" turbo inlet, MSCBE, Turbo XS FMIC, CNT catted DP, CP-E HPFP, Tial QR BPV, SURE TIG's, ITV24's, CP-E Stage 2 RMM, Medefail Tranny mount, 18x8 245/40's 390whp/400wtq 12.8@114 Sold Last edited by 86AmishMs3; 11-26-2011 at 05:14 PM. Reason: MSF Database - Automerged Doublepost | ||
![]() | | #20 | ![]() |
Back to it, your build looks like it's going to be pretty baller. I hope it turns out well, I'll be watching so I can figure out how I can do my own "cheap" build. Cheers man. | |
| The Following 4 Users Say Thank You to Vansquish For This Useful Post: |
![]() | | #21 | ![]() |
![]() Join Date: Jul 2009 Location: South Florida
Rep Power: 0 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 9,578
| Not Ranked : 0 score Could be good for boost limits fuel cut too.... not that I'd know, lol ![]() Mazel Tov
__________________ 2012 BMW 535i Alpine White/Beige (30K miles) N55 Dinan Stage 1 w/ Intake. Tech package w/ Bluetooth audio/streaming, SAT Radio, & 12.5G HD, Navi Sys Pro w/ Back-up Cam/sensors & Park Distant Control; Auto-Trunk, TPC, LED lighting interior (doors) and exterior (door handles), & tint. [SIGPIC][/SIGPIC] |
| The Following 3 Users Say Thank You to dougefresh_ For This Useful Post: |
![]() | | #22 | ![]() |
Groans: 338
(Thread Starter) | Not Ranked : 0 score Got dissasembled today. Obigatory pics of turbo comparo and then pics of ma intake for the turbo. Acually turbo install is going smooth. Have the 3076 already on the car to the manifold.
__________________ Current: N54 135i DCI, DP's, Exhaust, FMIC 12.3@122 2009 Mazdaspeed 3: GT3076 - Corkey tuned Treadstone 3" MAF, HTP 3" turbo inlet, MSCBE, Turbo XS FMIC, CNT catted DP, CP-E HPFP, Tial QR BPV, SURE TIG's, ITV24's, CP-E Stage 2 RMM, Medefail Tranny mount, 18x8 245/40's 390whp/400wtq 12.8@114 Sold |
| The Following 5 Users Say Thank You to 86AmishMs3 For This Useful Post: | Broxer (03-17-2012), dougefresh_ (12-16-2011), jracer (12-16-2011), Ms3_Miami (12-24-2011), rfinkle2 (07-06-2012) |
![]() | | #23 | ![]() |
| The Following 3 Users Say Thank You to For This Useful Post: |
![]() | | #24 | ![]() |
Groans: 338
(Thread Starter) | Not Ranked : 0 score Hahah yeah. But i would call it a fairly cheap build. I mean everything else I saved a lot of money on, and I wanted a quality turbo, not so much on an ebay turbo.
![]() | | #25 | ![]() |
| 2zz mr-s ![]() Join Date: Nov 2010 Location: katy, tx
Rep Power: 3483 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 0
Groans: 239
| Not Ranked : 0 score lol cheap
__________________ [07:25 PM] Pu Manchu: the second rule is "don't tell anyone" [07:25 PM] Pu Manchu: the first rule of tranny fucking is "don't do it" |
| The Following User Says Thank You to dooderek For This Useful Post: | 86AmishMs3 (12-17-2011) |
![]() | | #26 | ![]() |
![]() Join Date: Mar 2009 Location: Broomfield CO
Rep Power: 0 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 823
Groans: 60
| Not Ranked : 0 score You don't need a FMIC. If I was building a speed again I would go TMIC and Meth. You can still heat soak the pipes on a FMIC so its not immune to engine heat. TMIC is easier to keep from getting boost leaks and its a much shorter path. I ran a CX core with a 50\50 meth setup and the FMIC would heat soak in the summer but as soon as I was in boost the BATs would drop to below ambient. This was on the 3076. I fucking hated the FMIC and would have gladly traded it for a good aftermarket TMIC.
__________________ 2003 Lancer Evolution VIII - FIC 1120cc/Walbro 255/E85/Pure Drive Performance Tune 1990 Talon TSI AWD: Evo III 16g/E85/Exhaust/PTE 1000cc's/2g Maf/ECMLink *Wrecked* 2012 WRX: TD05 20g/E85/FIC 900cc's/Walbro 255 *SOLD* 12.8@110mph 2009 MS3: GT3076r/(75/25) E85/Bolt-ons *SOLD* 13.6@112mph |
![]() | | #27 | ![]() |
Groans: 338
(Thread Starter) | Not Ranked : 0 score Ok so turbo installed. A little bit of a bitch, new tune loaded. Running completely off of manual boost control. Having issues building boost, it's tough just to get to 5psi under 5500rpm's, but it starts creeping exponentially at redline, any thoughts. I need to get a log going probably for more assistance, but wonering if any thoughts. Wastegate is preloaded, and hooked up properly. Acts as if it's open always....
![]() | | #28 | ![]() |
Groans: 338
(Thread Starter) | Not Ranked : 0 score Just me or does that actuater arm look all the way open
![]() | | #29 | ![]() |
Groans: 31
| Not Ranked : 0 score Unless you have a massive boost leak that somehow fixes itself near redline, I agree with WGA is stuck. I sure hope you don't have to pull the whole turbo to fix that...
![]() | | #30 | ![]() |
| Not Ranked : 0 score nator az fail. lol jking. but yea, the arm does look open. Why stock mani? ffffuuuuuu
![]() | | #31 | ![]() |
Groans: 31
| Not Ranked : 0 score Stock manifold is fine, man. When I finally go gt3076, I'm keeping stock manifold. Make sure you have some sort of turbo bracket or it will stress the manifold too much.
![]() | | #32 | ![]() |
Groans: 338
(Thread Starter) | Not Ranked : 0 score The big heavy cast son of a bitch, i think it should be able to handle the weight of the guy. Well time will tell at least.
![]() | | #33 | ![]() |
Groans: 31
| Not Ranked : 0 score Yes, but what about the flexible portion in the middle? I wouldn't want to put much weight on that. I'm not afraid with stock turbo 'cause it's such a little guy, but a gt3076 weighs a lot more.
![]() | | #34 | ![]() |
Groans: 338
(Thread Starter) | Not Ranked : 0 score meh it breaks it breaks, i can have another stocker for cheap. But when you get yours i'll let you know how mine has been holding up .
![]() | | #35 | ![]() |
Groans: 338
(Thread Starter) | Not Ranked : 0 score Once i get this actuator issue figured out i will start posting logs. But mandatory engine bay shot (no cover on at the moment, and mbc is sitting on the engine) Oh and not pictured chisel in the recirc tube until i get a longer line. Only big issues I had were removing the manifold, again to get the oil feed on. Too difficult to put the oil feed on the turbo when bolted to the mani. Didn't want to take a chance of crossthreading. Also the atp supplied oil drain, is far too long. Cut about an inch and a half off. No big deal. Used a banjo nipple bold on coolant out instead of bending the stock line. And also extended the heater hose to get the turbo inlet pipe in.
![]() | | #36 | ![]() |
Groans: 338
__________________ Current: N54 135i DCI, DP's, Exhaust, FMIC 12.3@122 2009 Mazdaspeed 3: GT3076 - Corkey tuned Treadstone 3" MAF, HTP 3" turbo inlet, MSCBE, Turbo XS FMIC, CNT catted DP, CP-E HPFP, Tial QR BPV, SURE TIG's, ITV24's, CP-E Stage 2 RMM, Medefail Tranny mount, 18x8 245/40's 390whp/400wtq 12.8@114 Sold Last edited by 86AmishMs3; 12-20-2011 at 03:24 PM. | |
| The Following 2 Users Say Thank You to 86AmishMs3 For This Useful Post: | JacksonMS30 (12-20-2011), rfinkle2 (12-20-2011) |
![]() | | #37 | ![]() |
| Not Ranked : 0 score Curious how your logs will look. You going part e85?
![]() | | #38 | ![]() |
Groans: 338
(Thread Starter) | Not Ranked : 0 score Yep, we'll see how she does on 2.5g and then maybe i'll bump up to 5g. This should help me get a little more agressive. So far this turbo is awesome.
![]() | | #39 | ![]() |
Groans: 31
| Not Ranked : 0 score So if you read Anthony's (driver311) thread, he is a firm believer that using the smallest amount of e85 necessary to get all the KR-prevention benefits is optimal. I know, just someone's opinion, but his car is going nuts with just 4 gal and he never ever has knock. I think his 1/4 mile times speak for themselves
| The Following User Says Thank You to bmylez For This Useful Post: | 86AmishMs3 (12-21-2011) |
![]() | | #40 | ![]() |
Groans: 338
__________________ Current: N54 135i DCI, DP's, Exhaust, FMIC 12.3@122 2009 Mazdaspeed 3: GT3076 - Corkey tuned Treadstone 3" MAF, HTP 3" turbo inlet, MSCBE, Turbo XS FMIC, CNT catted DP, CP-E HPFP, Tial QR BPV, SURE TIG's, ITV24's, CP-E Stage 2 RMM, Medefail Tranny mount, 18x8 245/40's 390whp/400wtq 12.8@114 Sold | |
