 Old 07-21-2010, 12:27 PM   #1
Deadman's Avatar
Posts: 868   (View Stats)
Default GT35r - Blow through MAF!!
Dude i know has 35r on his speed6 running blow-through maf... well car hits 8psi and thats it any suggestions? Solenoid? thanks guys
Deadman is offline   Reply With Quote
 Old 07-21-2010, 12:36 PM   #2
H3llfir3's Avatar
Posts: 255   (View Stats)
H3llfir3 is the leader of the worldH3llfir3 is the leader of the worldH3llfir3 is the leader of the worldH3llfir3 is the leader of the worldH3llfir3 is the leader of the worldH3llfir3 is the leader of the worldH3llfir3 is the leader of the worldH3llfir3 is the leader of the worldH3llfir3 is the leader of the worldH3llfir3 is the leader of the worldH3llfir3 is the leader of the world
Ive been running blow thru maf for the past 6 months, no boost problems.
Check solenoid and all lines/boost tubes.
2006 black Mica MS6 GT- It has tons of shit on it and it's still slow.
NATOR of Florida
H3llfir3 is offline   Reply With Quote
The Following User Says Thank You to H3llfir3 For This Useful Post:
Deadman (07-21-2010)
 Old 07-21-2010, 01:19 PM   #3
Deadman's Avatar
kk will do! See if thats the problem..
 Old 07-21-2010, 03:06 PM   #4
AmillieMS6's Avatar
Posts: 1,700   (View Stats)
AmillieMS6 is the leader of the worldAmillieMS6 is the leader of the worldAmillieMS6 is the leader of the worldAmillieMS6 is the leader of the worldAmillieMS6 is the leader of the worldAmillieMS6 is the leader of the worldAmillieMS6 is the leader of the worldAmillieMS6 is the leader of the worldAmillieMS6 is the leader of the worldAmillieMS6 is the leader of the worldAmillieMS6 is the leader of the world
Groans: 365
Groaned at 594 Times in 575 Posts
some proper grammer would be nice
Mazdaspeed
AmillieMS6 is offline   Reply With Quote
 Old 07-21-2010, 05:22 PM   #5
Deadman's Avatar
My internet lingo is short but sweet... how about you relax buddy?!
It was a simple question, and usually that carries simple answers along with it.
Your answer however has nothing to do with the question so why even respond?
back on topic:
He is running a Perrin MBC, but to me it sounds like it is running of EWG spring pressure...hrmmm
 Old 07-21-2010, 05:35 PM   #6
madvillain's Avatar
Posts: 4,160   (View Stats)
Groans: 78
wait, whoa, whoa. what the hell is a blow through maf?
 Old 07-21-2010, 05:41 PM   #7
AmillieMS6's Avatar
Groans: 365
back on topic:
lawl
Mazdaspeed
 Old 07-21-2010, 05:45 PM   #8
Deadman's Avatar
lawl.
seriously though, if anyone has any info or possibilities that would help! Thanks
 Old 07-21-2010, 07:42 PM   #9
ms3guy22's Avatar
Posts: 530   (View Stats)
ms3guy22 has a reputation beyond reputems3guy22 has a reputation beyond reputems3guy22 has a reputation beyond reputems3guy22 has a reputation beyond reputems3guy22 has a reputation beyond reputems3guy22 has a reputation beyond reputems3guy22 has a reputation beyond reputems3guy22 has a reputation beyond reputems3guy22 has a reputation beyond reputems3guy22 has a reputation beyond reputems3guy22 has a reputation beyond repute
blow thru has the maf right before the tb(after the turbo), instead of before the turbo. The reason why people do this is it creates a more accurate signal for the ecu because it knows exactly how much air it is getting. As opposed to suck through which for al essential purposes the ecu is guess on the air based on what its seen before the turbo.
Most people don't run them because it maxes out the maf entirely way to fast. The last time i checked was still a issue on these cars even with the big maf. I'd be interested to see how this guy is running blow through, what are your mods and tuning?
I hate my mazdaspeed3 more than anything else in this world!
ms3guy22 is offline   Reply With Quote
The Following User Says Thank You to ms3guy22 For This Useful Post:
madvillain (07-21-2010)
 Old 07-21-2010, 08:44 PM   #10
SSinstaller's Avatar
Posts: 3,989   (View Stats)
Groans: 60
You didn't give much info, but...
Take the boost controller off, and run directly from the wastegate...
If he has an ATP fail gt35 they probably sent him the 8psi wastegate...
If he's got an external gate he just needs to chage the springs, most Tial's come with .6 bar springs preinstalled, that would net him about 8 psi..
If it's a boost leak, it's fucking massive---a gt35 could be leaking like crazy and still hit 10~15psi if that was the wastegate pressure
 Old 07-21-2010, 08:58 PM   #11
The Great NY's Avatar
Posts: 360   (View Stats)
The Great NY is the leader of the worldThe Great NY is the leader of the worldThe Great NY is the leader of the worldThe Great NY is the leader of the worldThe Great NY is the leader of the worldThe Great NY is the leader of the worldThe Great NY is the leader of the worldThe Great NY is the leader of the worldThe Great NY is the leader of the worldThe Great NY is the leader of the worldThe Great NY is the leader of the world
im gonna say boost leak or boost control issue. it has nuthin to do with the fact he is running blow thru.
good luck on finding the cure to the issue
The Great NY is offline   Reply With Quote
 Old 07-21-2010, 09:11 PM   #12
Close but not exactly, Most blow through mafs peg sooner because when you place an elbow in front of a maf it will thow off the maf output buy 15 to 20% high,(rich) whatever. therefore it hits 5 volts sooner. also putting a bend before the MAF will cause turbulence. and putting it too close to the TB may cause backwash and/or turbulence as well. If you have enough straight tubing in front of a blow through maf it won't peg any sooner than a draw through maf (the air mass is the same). whenever i do a blow thru MAF on someones car, i always find a way to put a minimum of 6-8" of straight pipe before the maf. This is how I get them to peg at the same horsepower B/T or D/T. Ideally the more straight tubing the better but it just dosen't always work that way, because sometime there isnt room to do it, unless you make room. i really like to make it 12" straight, but the minimum is 6-8" before the MAF, after the MAF is just as important, but doesnt effect the readings near as much.
aside from not being able to drive the car on draw thru in the event of a pipe blowing off and the car running better with blow thru anyway, that is enough for me to make every car i build that uses a MAF blow thru when boosted.
The Following 2 Users Say Thank You to The Great NY For This Useful Post:
madvillain (07-21-2010), xcoldricex (07-21-2010)
 Old 07-21-2010, 09:15 PM   #13
kotez's Avatar
Posts: 56   (View Stats)
kotez is a jewel in the roughkotez is a jewel in the roughkotez is a jewel in the rough
grammAr
kotez is offline   Reply With Quote
 Old 07-21-2010, 10:47 PM   #14
ILL3ST
xcoldricex's Avatar
Posts: 2,777   (View Stats)
ate baller has a thread about him running a blow through maf.
it also lets you VTA!
GT35r Spool jhershorin MazdaSpeed 3/6 - Turbo Induction 25 02-21-2013 07:13 PM
GT35R mattizle14 MazdaSpeed 3/6 - Big Turbo Builds 71 04-07-2010 05:06 PM
gt35r: Should I do it? madvillain Mazdaspeed3/6 General Discussion 38 05-26-2009 11:43 AM
Page generated in 0.32874 seconds with 28 queries
