| Approved MSF Vendor ![]() Join Date: Nov 2011
Rep Power: 778 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 0
(Thread Starter) | Not Ranked : 0 score It's going into my MS6. AFI T4 divided topmount manifold - ceramic coated and wrapped Dual Tial 38mm MV-S wastegates ATP T4 divided 1.06 AR housing ceramic coated and blanket Garrett GTX3076R w/ Snail Turbo billet compressor wheel (original ingested debris) Carrillo rods/bolts CP 9:1 Pistons ARP main and head studs Ported head Port matched stock intake w/ VTCS intact The goal is to see how much area under the curve can be obtained without supplemental fuel. Then the baby turbo goes buh-bye and we get serious w/ some new fueling solutions. As you can see from the pic, it's almost ready to go in. |
| The Following 13 Users Say Thank You to Steve@VersaTune For This Useful Post: | BrianB6 (07-05-2015), Code Monkey (07-01-2015), Dralphy (07-23-2015), fivefingerdeathpunch (07-02-2015), Mauro_Penguin (07-05-2015), mazdaspeeding (07-01-2015), MD1032 (03-04-2016), mituc (01-10-2016), phate (07-01-2015), SpeedRebirth (07-05-2015), theschrum (07-05-2015), Tokay444 (07-05-2015), WetzMS3 (07-02-2015) |
![]() Join Date: Nov 2010 Location: South Haven, MI
Rep Power: 0 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 2,824
Groans: 75
| Not Ranked : 0 score Port matched with VTCS still in it? Seems kinda odd. Is there just a lot of space around the flappers now?
__________________ Franken Turbo, built motor, meth. DIY parts: Shift Knob, Shift Plate, Shift Bushings, Battery Tray, EBCS, RSB, probably more. "Your signature should just say, I'm the shit." -LynzeC |
(Thread Starter) | Not Ranked : 0 score I didn't go deep into the runners. I just flared the opening from the flaps out to the flange to smooth the transition. |
| The Following User Says Thank You to Steve@VersaTune For This Useful Post: | Easter Bunny (01-06-2016) |
Groans: 75
| Not Ranked : 0 score Any reason why? Just to keep cold start not terrible? Seems like it would be quite a restriction on the rest of the system. Especially with a ported head you should have awesome flow.
(Thread Starter) | Not Ranked : 0 score Trying to keep low end torque for early spool. I'm going for max area under the curve for this phase. I will put a new intake on when I swap the turbo. |
![]() Join Date: Dec 2009 Location: layton, UT
Rep Power: 0 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 122
| Not Ranked : 0 score Thts quite a big hotside if Ur looking for spool
__________________ In progress: Engine: Built long block by Keefover. Keyed crank,keyed cams/VVT,Crower 65lb valve springs,Wiseco pistons,Manley H beam rods,AFI t3 stock location mani,Comp turbo CT4x 53-56,Kozmic 6th port PI with 2200cc bosch injectors,N2MB WOT box,Relentless ported intake mani,Kozmic oil feed line,Custom oil return line,Ramfab 3.5" intake,Ramfab alum. crash bar,Ramfab IC piping,TR10 IC,Saiko Michi and JBR dual custom catch can setup, Guardian angel v3 with 4bar map sensor,Dual Deatschwerks in-tank fuel hat with bigger pickup,-6an nylon braided fuel lines,Fuel labs FPR,SP63 3 port EBCS,Mishimoto oil cooler, HKS SSQV1,BSD,Autotech FP internals,CPE injector seals EGR delete,TB coolant bypass delete,M2 Ebay DP Suspenion/Bracing: Sonic tuning CO's revalved by Feal Suspension, QA1 600lb rear springs, 750lb front Swift springs,AWR front and rear sway bar endlinks,Whiteline RSB,SPC front adjustable ball joints,GT spec ladder brace,SU rear interior brace,NRG harness bar. Drivetrain:SS brake lines,SS clutch line,Carbotech ax6 F&R, Southbend STG 3 endurance clutch and flywheel,SU rear diff mount,SU front rear diff mount,SP63 TC caps,DSS rear axles,AWR Trilogy mounts 70A,Hubcentric centering rings,2" brake ducting F&R,TWM STS stg 1 with bushing kit Interior:Redline custom shift boot,Redline custom steering wheel cover,Redline custom ebrake handle cover Bride Stradia V.2 rep seats,Corbeau seat brackets,JBR heavy shift knob,Custom LED gauge cluster,Custom Steering column dual gauge pod,AEM wideband failsafe,AEM oil pressure gauge,Schrothe Rallye 4 harnesses,Escort 9500ix with mirror mount and hard wired with external controller,DIY ipod adapter. Exterior: STI front lip,Enkei PF01SS 17x9 +48 wrapped in Bridgestone Potenza RE-71R's 245/45/17,Full clear bra,Muteki SR48 blue locking lug nuts,RHO side plate mount,Smoked side markers, Shark fin antenna |
(Thread Starter) | Not Ranked : 0 score I'm trying to see if all of the insulation on the exhaust manifold and housing can make up for it. I may swap out the housing. |
![]() Join Date: Jan 2015 Location: Jacksonville, FL
Rep Power: 0 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 28
Groaned at 26 Times in 14 Posts
| The Following 2 Users Say Thank You to cam1391 For This Useful Post: | Easter Bunny (01-06-2016), impossible (05-29-2017) |
| Not Ranked : 0 score Ummm I'm pretty sure insulation on Ur exhaust mani. Isn't going to make up for Ur spool
(Thread Starter) | Not Ranked : 0 score I plan on testing different parts. That's what this car is for. T4 hotside selection is limited. I plan to make some big numbers later on. I didn't want to have to swap the manifold. I wish there was a true twin scroll t4 like the EFRs have. I may switch to an EFR when I'm ready to go big. |
![]() Join Date: Jun 2012 Location: Jacksonville, FL
Rep Power: 0 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 24,365
Groans: 171
| Not Ranked : 0 score Tell me more about this twin scroll manifold your using.
__________________ -Fearless vampire killers, banned in DC, how low can a punk get? -Delray/Grieco Mazda or Direct Auto Body, ask me why you should NOT take your car to either. ![]() -It is more fun to drive a slow car fast, than it is to drive a fast car slow |
![]() Join Date: Dec 2008 Location: VA Beach
Rep Power: 0 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 930
| Not Ranked : 0 score When going twin scroll, you can't really compare the a/r of the turbine housing to what you would go with single scroll. Spool should come on very quickly with this size turbo and 1.06 hotside. With my PTE 6262 and a T4 1.06 twin scroll hotside, I hit 23psi on my very first pull at 3240 rpm.
__________________ 06 Speed 6 GT: True twin scroll T4 PTE Billet 6262, dual MVS, SP 10.6:1 pistons, K1 rods, sleeved block... 08 Speed 3|SOLD |
| The Following 6 Users Say Thank You to theschrum For This Useful Post: | 802MS3 (07-05-2015), Code Monkey (07-05-2015), Easter Bunny (01-06-2016), fivefingerdeathpunch (01-06-2016), Mauro_Penguin (07-05-2015), WetzMS3 (01-06-2016) |
(Thread Starter) | Not Ranked : 0 score AFI Turbo Manifold - Mazda Speed 3/6 Topmount - Race only- TREADSTONE PERFORMANCE Pics of mine with twin EWG: After ceramic coating: |
| The Following 3 Users Say Thank You to Steve@VersaTune For This Useful Post: |
| Not Ranked : 0 score where did u get a twinscroll housing for a PTE?? NM found AGP turbo carries them... fuck if I would of known I would of got a t3 twinscroll housing and mani... fuck!!
| The Following User Says Thank You to MSP611 For This Useful Post: | theschrum (07-05-2015) |
Turbine Housing, T4 Divided inlet 3" V-Band outlet, 1.06 A/R for GT3582R/GTX35 : atpturbo.com Last edited by Steve@VersaTune; 07-05-2015 at 08:21 AM. Reason: MSF Database - Automerged Doublepost | ||
| Not Ranked : 0 score Also, not sure if AFI fixed the design, but there will likely be clearance issues for the wg if you are keeping your A/C. And super tight dp fitment.
| The Following 2 Users Say Thank You to theschrum For This Useful Post: | 802MS3 (07-05-2015), Mauro_Penguin (07-05-2015) |
| Not Ranked : 0 score this is on the top mount mani's??
After looking at the pics side by side, my WG pipe has a different angle. I'll find out about clearance in a day or two. It's going in this week. | |
| The Following 2 Users Say Thank You to Steve@VersaTune For This Useful Post: | Code Monkey (07-05-2015), Mauro_Penguin (07-05-2015) |
![]() | | #19 | ![]() |
![]() Join Date: Apr 2009 Location: Cincinnati
Rep Power: 2046 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 1,096
| Not Ranked : 0 score I have a topmount 3076 with the .78A/R T3 twin scroll housing; I should have gone with the 1.06. I had to put a custom spring in my dual port BOV to allow some recirc while cruising to keep it from surging. It's nearly impossible to stay out of boost during normal driving and it hits 32 psi at just over 3000rpm.
__________________ 2006 MS6 GT - Built engine, twin scroll GT3076R, dual MV-S wastegates dumped to atmosphere, TR1035 FMIC, too many parts to list... ![]() 2009 MS3 GT - Built engine, JBR intake/TIP and short shifter, all engine mounts, Autotech HPFP internals, ETS TMIC, Custom AP tune, Pauter rods, CP pistons, and 6-puck ACT clutch -GTX2867R Coming Soon |
| The Following 8 Users Say Thank You to JMEngineer For This Useful Post: | 802MS3 (07-05-2015), Code Monkey (07-05-2015), Easter Bunny (01-06-2016), fivefingerdeathpunch (01-06-2016), Mauro_Penguin (07-05-2015), theschrum (07-05-2015), torquemaniac (01-28-2016), WetzMS3 (01-06-2016) |
![]() | | #20 | ![]() |
| Not Ranked : 0 score Wow that is an incredible difference from single scroll. |
![]() | | #21 | ![]() |
![]() Join Date: Jun 2011 Location: Parma, OH
Rep Power: 1009 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 545
Groaned at 7 Times in 4 Posts
| Not Ranked : 0 score I thought wrapping a manifold that has ceramic coat is a no-no?
__________________ Parting out car, 800whp motor with 4k miles on it, 6466 turbo kit... ect I also do diesel gear swaps hit me up for more info. |
![]() | | #22 | ![]() |
| Not Ranked : 0 score The twin scroll already improves spool characteristics by reducing cylinder interference so you can run a larger A/R from that perspective and achieve similar spool. However a twin scroll housing with the same A/R as a single scroll will be more restrictive. The increased surface area of having a divided housing means more friction for the exhaust gases. This is another reason to run a bigger A/R on a twin scroll versus a single.
| The Following 6 Users Say Thank You to Lex For This Useful Post: | 802MS3 (07-05-2015), Code Monkey (07-05-2015), Mauro_Penguin (07-24-2015), RE-ACTIONENGSPEED3 (07-23-2015), theschrum (07-05-2015), WetzMS3 (01-06-2016) |
![]() | | #23 | ![]() |
![]() Join Date: Nov 2011 Location: Greece-Athens
Rep Power: 0 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 470
| Not Ranked : 0 score so any updates?
__________________ 2008 speed3 True red. Pte 6466 & AWD Mode on !!!! 11.114@131.04 .........GTX3071.....FWD 10.62@136.64............PTE6466.....AWD [SIGPIC][/SIGPIC] |
![]() | | #24 | ![]() |
(Thread Starter) | Not Ranked : 0 score I've been crazy busy lately. I got it in the car on Monday night. There is a clearance issue with one wastegate. I will need to make a short angled extension to locate it where there is clearance. I'm travelling right now so I can't post pics. |
![]() | | #25 | ![]() |
| Not Ranked : 0 score When you have time share some photos , because i`m really interested in the top mount setup with t4 divided option .........
| The Following User Says Thank You to RE-ACTIONENGSPEED3 For This Useful Post: | Mauro_Penguin (07-24-2015) |
![]() | | #26 | ![]() |
![]() Join Date: Jan 2011 Location: Jacksonville, FL
Rep Power: 0 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 311
__________________ 08 MazdaSpeed3 | Cobb AP | MS Intake | CS TIP | CP-E FMIC | CNT Catless TBE | ITV22 | | AutoTech Internals | TurboSmart BOV | BC Racing Coilovers | CS RMM | CS TMM | | Black Powdercoated Stockers | Built Motor | | Mahle 88mm Pistons | Manley H-Beam Rods | | |
| The Following User Says Thank You to Jtaylor For This Useful Post: | ItsNox (07-24-2015) |
![]() | | #27 | ![]() |
| Not Ranked : 0 score I should, but the next race in my country is very unknown (due to my country`s economical situation)about when it will take place...I estimate late September....
| The Following 6 Users Say Thank You to RE-ACTIONENGSPEED3 For This Useful Post: | Easter Bunny (01-06-2016), ItsNox (07-24-2015), Jtaylor (07-24-2015), Mauro_Penguin (07-24-2015), Micha (08-03-2015), WetzMS3 (01-27-2016) |
![]() | | #28 | ![]() |
| Not Ranked : 0 score I'm guessing you ran into this issue.
| The Following User Says Thank You to theschrum For This Useful Post: | Easter Bunny (01-06-2016) |
![]() | | #29 | ![]() |
(Thread Starter) | Not Ranked : 0 score No. It's on a different angle than that. The tial mvs I have hits the protruding firewall on my MS6. It clears the ac line. |
![]() | | #30 | ![]() |
(Thread Starter) | Not Ranked : 0 score Here is my setup. Close, but not quite clear. |
| The Following 4 Users Say Thank You to Steve@VersaTune For This Useful Post: |
![]() | | #31 | ![]() |
(Thread Starter) | Not Ranked : 0 score At the fab shop now. Should be on the road next week. |
![]() | | #32 | ![]() |
| Not Ranked : 0 score Im excited to see wat this does... I may have to put a twin scroll housing on my AFI Mani and see how this turbo handles it Sent from my Nexus 7 using Tapatalk
![]() | | #33 | ![]() |
(Thread Starter) | Not Ranked : 0 score I ran the engine for 10 min with just a short elbow on the turbo to check for oil/water leaks. With the ceramic coating + turbo blanket, I was able to put my hand on the blanket. It was only a little warm. It's safe to say that the exhaust energy is being retained in the exhaust stream. I'm very anxious to see what the spool profile looks like. |
| The Following 4 Users Say Thank You to Steve@VersaTune For This Useful Post: | ALPINEST4RS (02-05-2016), Easter Bunny (01-06-2016), Mauro_Penguin (01-07-2016), RE-ACTIONENGSPEED3 (01-06-2016) |
![]() | | #34 | ![]() |
| Not Ranked : 0 score twin scroll rocks....... I`m really curious to se how this turbo setup will spools and handles power at high revs.
![]() | | #35 | ![]() |
| Not Ranked : 0 score Hmm guess we'll see if this double heat protection is a go or not.. Will tell me i need to buy a blanket or not cuz I was slightly wondering the same thing lol. Sent from my Nexus 7 using Tapatalk
![]() | | #36 | ![]() |
| Not Ranked : 0 score I'm really curious to see how the spool is on this. One of the last things I'm still deciding for my turbo is what A/R I want. I'll be on an S256 (similar size to the gt3076) but on a T3 housing and I can't decide between a .75 and 1.0.
![]() | | #37 | ![]() |
| Not Ranked : 0 score if the spool isn't good but you already have the twinscroll can you try soemething similar to this? Maybe juste a trap made in between with a kind of wastegate pressurised actuator to activate the second part when the initial boost is reached ? Is Variable Twin Scroll Turbocharging the Answer to Future Turbos?
![]() | | #38 | ![]() |
![]() Join Date: Nov 2014 Location: La Porte, TX
Rep Power: 0 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 56
| Not Ranked : 0 score Thats a cool idea. would you control the scrolls with a manual set up
__________________ Cobb AP JBR Tru-3.0 CNT Catted DP "Gutted" CNT Catback JBR 88 RMM DM PMM and TMM 3 port, Turbosmart dual port FReaktune E33 |
![]() | | #39 | ![]() |
| Not Ranked : 0 score just a pressure actuator could probably works fine? a used 8psi WG for exemple. the second chamber would open when the intake reach 8 psi. the only problem could be to direct the flow of the blocked side to the other scroll
![]() | | #40 | ![]() |
Photo evidence... 30psi at about 3100rpm in 4th
__________________ 2006 MS6 GT - Built engine, twin scroll GT3076R, dual MV-S wastegates dumped to atmosphere, TR1035 FMIC, too many parts to list... ![]() 2009 MS3 GT - Built engine, JBR intake/TIP and short shifter, all engine mounts, Autotech HPFP internals, ETS TMIC, Custom AP tune, Pauter rods, CP pistons, and 6-puck ACT clutch -GTX2867R Coming Soon | |
| The Following User Says Thank You to JMEngineer For This Useful Post: | Mazdazilla6 (01-26-2016) |
| Oil prices headed up or down? Experts divided | Haltech | Automotive News | 0 | 05-11-2015 08:50 AM |
| Stage 2 Topmount logs | Speeed3 | MazdaSpeed 3/6 - ECU Computer Tuning | 59 | 11-10-2011 12:05 PM |
