 Old 05-17-2012, 04:41 PM   #81
smoogs12's Avatar
Posts: 7,731   (View Stats)
Groans: 423
@bmylez I would hope not lol
-Pat
2008 True Red MS3
GT3071R 'n Stuff
SOLD
1999 Jeep XJ
1996 Jeep XJ
1994 Miata
 Old 05-17-2012, 05:25 PM   #82
Deldran's Avatar
Posts: 3,139   (View Stats)
Groans: 118
When I get an intake I will be going from stock to 3" I will also do the test and post results in here
Damond Built Speed 6
The Following 2 Users Say Thank You to Deldran For This Useful Post:
djuosnteisn (05-17-2012), smoogs12 (05-17-2012)
 Old 05-17-2012, 07:59 PM   #83
86AmishMs3's Avatar
Posts: 3,639   (View Stats)
Groans: 338
Honestly my take on the whole 3" tip, stock turbo is this:
1. It will help out, you will have less frictional losses/ gram of air consumed by going to a bigger pipe. Frictional losses = pressure drop. So there should be a little less vacuum inlet tract.
2. If you have a smooth transition from 3" to 2" to where the actual turbo inlet is you will increase velocity. When increasing velocity due to bernoulli effect there will be less pressure behind that air, giving a sort of ram effect. But the problem is the pressure loss is still high at the 2" inlet
3. Considering the vacuum is still higher in the 2" inlet part of the turbo...I still see minimal gains. I suspect there will be gains but nothing major. And this thinking is from an aftermarket 2.5" to a 3". I would say if you're going to go 3" and you're stock turbo inlet then great!, but if you already have an aftermarket tip...then I don't think you can justify the money spent to go 3"
4. Which concludes me to my next point...you're still trying to skate uphill. Buy a bigger, more efficient turbo.
Current: N54 135i
DCI, DP's, Exhaust, FMIC
12.3@122
2009 Mazdaspeed 3:
GT3076 - Corkey tuned
390whp/400wtq
12.8@114
Sold
The Following 2 Users Say Thank You to 86AmishMs3 For This Useful Post:
Brennan (05-19-2012), djuosnteisn (05-21-2012)
 Old 05-17-2012, 09:20 PM   #84
Deldran's Avatar
Groans: 118
I agree with what u said I just want to help find hard data on the subjects.
I by no means think that a full 3" intake will make my Turbo more than what it is.
 Old 05-19-2012, 12:12 PM   #85
dead-zone's Avatar
Posts: 442   (View Stats)
dead-zone is the leader of the worlddead-zone is the leader of the worlddead-zone is the leader of the worlddead-zone is the leader of the worlddead-zone is the leader of the worlddead-zone is the leader of the worlddead-zone is the leader of the worlddead-zone is the leader of the worlddead-zone is the leader of the worlddead-zone is the leader of the worlddead-zone is the leader of the world
Groaned at 53 Times in 17 Posts
I got the 2.5 and the turbo sucks like a hungry baby sucking the nipple
dead-zone is offline   Reply With Quote
 Old 05-19-2012, 01:08 PM   #86
Brennan's Avatar
Posts: 220   (View Stats)
Brennan is the leader of the worldBrennan is the leader of the worldBrennan is the leader of the worldBrennan is the leader of the worldBrennan is the leader of the worldBrennan is the leader of the worldBrennan is the leader of the worldBrennan is the leader of the worldBrennan is the leader of the worldBrennan is the leader of the worldBrennan is the leader of the world
Suppose that someone is upgrading a stock TIP and has a 2.5" SRI currently (maybe me), does it make sense to go with a 3" TIP thinking that said person may go with a 3" intake in the future? Seems to me like it would.
'10 Velocity Red Mica MS3 with Tech
Performance: JBR SSP + Bushings, JBR 80a RMM, Ebay TP, CS SRI + TIP, AP (Self Tooned @18.5 PSI), MD OCC, CP-e HPFP, ITV22s, EGR delete, Forge V1 BPV, Ford Motorcraft Tranny Fluid
Other: DDM 6000k HID Lows, CS LED Fogs, CS Interior/Plate LEDs, RallyArmor Flaps, 34/17 Tint, Heavy Knob, Rockford Fosgate PRIME R500-1 Amp + Alpine SWR1242D 12" Sub + PAC AOEM-MAZ2
Future/wishlist: Driver mod, CS TMIC (on the way!), CS turbo-back, H&R Coilovers
Check out the Gen2 "ECU Computer Tuning" sticky on software that will trim/highlight your AP datalogs!
Brennan is offline   Reply With Quote
 Old 05-19-2012, 01:16 PM   #87
smoogs12's Avatar
Groans: 423
Do you plan on BT? Or are you buying it just because?
But at any rate, yes just buy the 3" tip now, unless you just want to spend money on a 2.5" tip that you wont need.
-Pat
2008 True Red MS3
GT3071R 'n Stuff
SOLD
1999 Jeep XJ
1996 Jeep XJ
1994 Miata
 Old 05-19-2012, 01:20 PM   #88
Brennan's Avatar
Not planning on BT, but that doesn't mean it'll never happen. Just figuring a 3" TIP doesn't hurt anything and is only $25 more (from HTP). Thanks.
The Following User Says Thank You to Brennan For This Useful Post:
smoogs12 (05-19-2012)
 Old 05-19-2012, 01:29 PM   #89
smoogs12's Avatar
Groans: 423
Yeah there really is no reason not not go 3".
Up until recently price was the main reason. Seeing as that price gap has closed, there is really no reason not to.
-Pat
2008 True Red MS3
GT3071R 'n Stuff
SOLD
1999 Jeep XJ
1996 Jeep XJ
1994 Miata
 Old 05-21-2012, 12:21 PM   #90
Captain
djuosnteisn's Avatar
Posts: 11,480   (View Stats)
...But the problem is the pressure loss is still high at the 2" inlet
But wouldn't the pressure drops be compounded? For instance, the pressure drop at the inlet will be there regardless, but it's pressure input is based off the rest of the TIP / intake. So if there is a considerable drop in that "up stream" region, then it'll only make the 2" restriction worse.
Put differently, lets say the 2" inlet causes a 2 psi vac at 350 g/s... If there was already a 2psi drop from the filter / intake / TIP, would that 2" inlet see -4psi?
Your the fluids expert hahaha. I just always understood that pressure drops were cumulative, and that even if a bottleneck exists in one portion of a flow tract, improvements can still be made elsewhere (with diminished returns obviously).
500awhp 440awtq uncorrected
Check out the hair Salon:
www.permtuning.com
86AmishMs3 (05-21-2012), smoogs12 (05-21-2012)
 Old 05-21-2012, 02:00 PM   #91
86AmishMs3's Avatar
Groans: 338
Of course its cumulative. But the frictional losses in a contraction of a pipe are proportional to the ratio of the cross sectional areas...meaning that there will be a larger frictional loss (pressure drop) reducing from say a 3" to a 2" pipe, then say a 2.5 to a 2" pipe. That shouldn't come as much suprise. And I'm saying this will offset some of the less frictional losses that were gained from going from a 2.5" to a 3" pipe before the reduction. My guess is without pulling out my chemE bible is that you're still better off with a 3" pipe, but the reduction at the turbo inlet negates a lot of what you gained.
But in any piping system you want to reduce the amount of contractions, expansions, bends, length to have the lowest pressure drop. Also important is the relationship between diameter and fluid velocity. You go too big of a pipe you're vastly affecting fluid velocity and you'll actually decrease performance. I'm sure within the confines of an engine bay though you won't realize that problem though.
All this can be calculated fairly well from theory...but I'm lazy.
Jaz likes this.
Current: N54 135i
12.3@122
2009 Mazdaspeed 3:
390whp/400wtq
12.8@114
Sold
djuosnteisn (05-21-2012), smoogs12 (05-21-2012)
 Old 05-21-2012, 02:05 PM   #92
Captain
Lol, you don't need to calculate it. I'm just picking your brain.... because you actually own a chemE bible
What's the frictional loss going from open atmosphere into the end of a pipe (basically worst case reduction)? Cause if the frictional loss was proportional with the change in diameter, that would make it infinite, right? Where does the diminished friction increase begin to take effect?
www.permtuning.com
 Old 05-21-2012, 02:13 PM   #93
86AmishMs3's Avatar
Groans: 338
The valuations I gave are heuristics for special circumstance. For example for a cross sectional ratio of less then .715...the frictional factor is:
F=(K*V^2)/2 for turbulent flow in smooth pipe. K= .4 (1.25-(A2/A1)
Now in your scenerio that you just described...the ratio is infiniti. So you use a differenty heuristic where K = .75(1-A2/A1) as you can see A2/A1 is basically A2/infiniti = 0 so then K = .75 for an open atmosphere condition.
There are sooo many heuristics for scenerios...to make life easier.
Current: N54 135i
12.3@122
2009 Mazdaspeed 3:
390whp/400wtq
12.8@114
Sold
 Old 05-21-2012, 02:28 PM   #94
86AmishMs3's Avatar
Groans: 338
It's hard to explain fluid dynamics IMO. But for the most part fluid dynamics are intuitive. The only thing counter intuitive is where bigger pipes actually reduce flow and increae pressure drops. And that happens at certain flows. Why huge cams and big intake runners are great for higher rpm performance but not low rpm performance
Current: N54 135i
12.3@122
2009 Mazdaspeed 3:
390whp/400wtq
12.8@114
Sold
 Old 06-03-2012, 02:32 PM   #95
Matt H.'s Avatar
Posts: 137   (View Stats)
Matt H. has a reputation beyond reputeMatt H. has a reputation beyond reputeMatt H. has a reputation beyond reputeMatt H. has a reputation beyond reputeMatt H. has a reputation beyond reputeMatt H. has a reputation beyond reputeMatt H. has a reputation beyond reputeMatt H. has a reputation beyond reputeMatt H. has a reputation beyond reputeMatt H. has a reputation beyond reputeMatt H. has a reputation beyond repute
FYI guys i think this intake would be pure sex the person wanting the gtx28 turbo as this turbo does not have the 4 inch inlet but a 3 and htp has three inlet to tip sizes the three is one of them just think this would be a very responsive and clean setup!!!
Matt H. is offline   Reply With Quote
LinkBack to this Thread: http://www.mazdaspeedforum.org/forum/forum/f498/htp-3-turbo-inlet-98602/
Mazda MPS Owners Club • View topic - HTP Turbo Inlet Pipe This thread Refback 02-21-2012 09:52 AM
3" turbo inlet cageyvet Mazdaspeed3/6 General Discussion 17 06-18-2010 12:48 PM
cp-e / whoosh "BIG" MAF & turbo inlet *teaser pics inside whoosh@Realtune MazdaSpeed 3/6 - Turbo Induction 33 11-05-2008 09:49 AM
3" Turbo Inlet Pressure Question corsa MazdaSpeed 3/6 - Turbo Induction 14 08-16-2008 10:16 AM
Page generated in 0.37925 seconds with 27 queries
