  • 1 Post By darth_speeder
 Old 10-31-2012, 01:30 PM   #1
Importfan12's Avatar
Posts: 171   (View Stats)
Importfan12 has a reputation beyond reputeImportfan12 has a reputation beyond reputeImportfan12 has a reputation beyond reputeImportfan12 has a reputation beyond reputeImportfan12 has a reputation beyond reputeImportfan12 has a reputation beyond reputeImportfan12 has a reputation beyond reputeImportfan12 has a reputation beyond reputeImportfan12 has a reputation beyond reputeImportfan12 has a reputation beyond reputeImportfan12 has a reputation beyond repute
Default Importfan12's MS6 3076 Build
This process started in April when I took it to a local shop that was highly recommended to get the VVt issue all taken care of before something bad happened. Well needless to say he screwed the whole thing up. It somehow slipped timing and bent the valves. Then after he rebuilt the head for free it somehow had a spun bearing when I picked it up. So after some research trying to prove it was his fault I said F**k it let just build it.
So the Current set up now is in the break in Period.
Wiseco 9.5:1 +.020 pistons
Eagle Rods
ARP Main and head Studs
All new OEM Bearings, Seals and bolts
ACT 6 puck “Pixie Dust” Clutch and Flywheel kit
PG Version 3 manifold
3” catless downpipe
MagnaFlow cat back
Grimmspeed EBCS
PG SRI and TIP for now!!!
Currently BNR S3
Sure Rear MM
AWR Passenger mount
Sure DreadNaught
Following parts are going to be installed as soon as the motor is Broke in.
ATP GT3076
WMI kit Sure Full 3” to 4” turbo Intake
3 Bar MAP
MattJackson P&P MAP harness
So once the break in period is over I will be installing the 3076, WMI, and 3” Full aeros and getting a re-tune. Hoping for 420ish AWHP.
2007 MS6 GT3076 Built motor.
Importfan12 is offline   Reply With Quote
The Following 8 Users Say Thank You to Importfan12 For This Useful Post:
06Speed6 (10-31-2012), :: Gusto :: (11-10-2012), greenespeed (10-31-2012), helmetface (10-31-2012), jracer (10-31-2012), psychophyr (10-31-2012), Roddiy (10-31-2012), uncorked11 (10-31-2012)
 Old 10-31-2012, 01:41 PM   #2
Karmat's Avatar
Posts: 1,179   (View Stats)
Am I reading this wrong or did you have the same guy that screwed up your VVT job, spun bearing, build the motor?
2002 Corvette Z06 (Black)
 Old 10-31-2012, 01:58 PM   #3
No I did the motor build myself with guidance from others
Originally Posted by dastpe View Post
so how is that going to be an evo killer?
Most of them around here it will with no problem. I also didnt list all the suspension mods for the track.
anything that bases it's identity of defeating something else is weaksauce.
Fixed for you since its "weak Sauce"
Last edited by Importfan12; 10-31-2012 at 01:58 PM. Reason: MSF Database - Automerged Doublepost
 Old 10-31-2012, 01:47 PM   #4
darth_speeder's Avatar
Posts: 653   (View Stats)
darth_speeder is the leader of the worlddarth_speeder is the leader of the worlddarth_speeder is the leader of the worlddarth_speeder is the leader of the worlddarth_speeder is the leader of the worlddarth_speeder is the leader of the worlddarth_speeder is the leader of the worlddarth_speeder is the leader of the worlddarth_speeder is the leader of the worlddarth_speeder is the leader of the worlddarth_speeder is the leader of the world
looks like there's a contender for the highest speed6 in socal tittle
[SIGPIC][/SIGPIC] Corn Fed//Richtuned
darth_speeder is offline   Reply With Quote
The Following User Says Thank You to darth_speeder For This Useful Post:
Importfan12 (10-31-2012)
 Old 10-31-2012, 01:49 PM   #5
dastpe's Avatar
Posts: 1,644   (View Stats)
dastpe is the leader of the worlddastpe is the leader of the worlddastpe is the leader of the worlddastpe is the leader of the worlddastpe is the leader of the worlddastpe is the leader of the worlddastpe is the leader of the worlddastpe is the leader of the worlddastpe is the leader of the worlddastpe is the leader of the worlddastpe is the leader of the world
dastpe is offline   Reply With Quote
The Following 11 Users Say Thank You to dastpe For This Useful Post:
06Speed6 (10-31-2012), Darksun280 (10-31-2012), jracer (10-31-2012), mczimer (11-06-2012), MS3-a(sore)ASS-rex (10-31-2012), Pu Manchu (10-31-2012), Realgib3 (10-31-2012), RoyalDex (10-31-2012), Spiral1183 (10-31-2012), surebOOst (10-31-2012), uncorked11 (10-31-2012)
 Old 10-31-2012, 02:08 PM   #6
helmetface's Avatar
Posts: 5,685   (View Stats)
Groans: 219
*STOCK EVO Killer*
The Following 3 Users Say Thank You to helmetface For This Useful Post:
Darksun280 (10-31-2012), dastpe (10-31-2012), RoyalDex (10-31-2012)
 Old 10-31-2012, 02:11 PM   #7
Originally Posted by helmetface View Post
*STOCK EVO Killer*
How many EVO's do you know making over 400awhp? I dont know of that many. People take shit too seriouly.
 Old 10-31-2012, 02:15 PM   #8
dastpe's Avatar
there are a lot of them...a lot. i think the of the three guys who have evos on msf that i know of they are all well over 400 on a mustang dyno. guys run 10s with the stock evo 9 turbo (with other mods of course).
but i digress, the build should be awesome and a ton of fun once completed.
edit: keep in mind my evo on stock block was hitting 452awhp before the build.
The Following 2 Users Say Thank You to dastpe For This Useful Post:
Darksun280 (10-31-2012), MS3-a(sore)ASS-rex (10-31-2012)
 Old 10-31-2012, 02:39 PM   #9
helmetface's Avatar
Groans: 219
Chill bro. You're obviously the one taking things seriously.
If you hadn't noticed, I -thanked- your OP..I'm excited for the build and I hope you do big things with it..
But you can't type "EVO KILLER" and not expect to get some flak, ya feel?
 Old 10-31-2012, 03:00 PM   #10
RoyalDex's Avatar
Posts: 117   (View Stats)
RoyalDex has a reputation beyond reputeRoyalDex has a reputation beyond reputeRoyalDex has a reputation beyond reputeRoyalDex has a reputation beyond reputeRoyalDex has a reputation beyond reputeRoyalDex has a reputation beyond reputeRoyalDex has a reputation beyond reputeRoyalDex has a reputation beyond reputeRoyalDex has a reputation beyond reputeRoyalDex has a reputation beyond reputeRoyalDex has a reputation beyond repute
Stacks.
Don't get me wrong You will have a nice ride FOR SURE and will spank my almost stock ms6 but evo killer is a strong pair of words.
Good luck with the build
RoyalDex is offline   Reply With Quote
The Following User Says Thank You to RoyalDex For This Useful Post:
 Old 10-31-2012, 01:51 PM   #11
jack_hammer's Avatar
Posts: 6,822   (View Stats)
Groans: 549
it's fun to do bad things
 Old 10-31-2012, 02:02 PM   #12
SleeperHatch's Avatar
Posts: 3,138   (View Stats)
@Joe Isuzu
2009 CWP Speed3
 Old 10-31-2012, 02:15 PM   #13
surebOOst's Avatar
Posts: 1,795   (View Stats)
surebOOst is the leader of the worldsurebOOst is the leader of the worldsurebOOst is the leader of the worldsurebOOst is the leader of the worldsurebOOst is the leader of the worldsurebOOst is the leader of the worldsurebOOst is the leader of the worldsurebOOst is the leader of the worldsurebOOst is the leader of the worldsurebOOst is the leader of the worldsurebOOst is the leader of the world
Groaned at 61 Times in 40 Posts
@Darksun280
How do you feel about a sub 500awhp ms6 beating a Evo?
2006 Evolution IX RS
ER Built 2.3l
On jackstands
awaiting parts
surebOOst is offline   Reply With Quote
The Following User Says Thank You to surebOOst For This Useful Post:
 Old 10-31-2012, 02:25 PM   #14
Whatever regardless if I will be beating EVO's or not this car is gonna be fun. I know there are a lot of awesome EVO's out there. It was supposed to be a funny statement but flame away B*tches
 Old 10-31-2012, 02:33 PM   #15
surebOOst's Avatar
Just having some fun man lol Your build should be good and I would think with a built motor you could push more than 420 if you invest in drivetrain goodies aswell! Good luck on the build!
ER Built 2.3l
On jackstands
awaiting parts
 Old 10-31-2012, 02:29 PM   #16
here we go
subbed for future brawls
:: Gusto :: likes this.
The Following 4 Users Say Thank You to darth_speeder For This Useful Post:
Importfan12 (10-31-2012), jack_hammer (10-31-2012), speedyspaghetti (10-31-2012), surebOOst (10-31-2012)
 Old 10-31-2012, 03:12 PM   #17
Black Metal's Avatar
Posts: 699   (View Stats)
Black Metal is the leader of the worldBlack Metal is the leader of the worldBlack Metal is the leader of the worldBlack Metal is the leader of the worldBlack Metal is the leader of the worldBlack Metal is the leader of the worldBlack Metal is the leader of the worldBlack Metal is the leader of the worldBlack Metal is the leader of the worldBlack Metal is the leader of the worldBlack Metal is the leader of the world
Groans: 78
You better make more than 420 with this setup...
- 2006 Black Mica MS6 -
- GT3071R - CP-e CAI - CP-e BT TIP - ATP Catted DP - JBR RMM - Corksport TMIC - Cobb AP -
- Autotech Internals - Turbo XS 50/50 - DSS Rear Axle - Sure Juggernaught & Dreadnaught -
- GS EBCS - H&R Springs - Sure TIG's - PNP'D Intake Manifold - EGR Delete -
12.89 @ 104.9 1.82 60' 4500' ASL on K04 20 PSI E30
12.01 @ 113.9 1.80 60' 4500' ASL on 3071 22 PSI E20
- 2004 Silver Sunlight Metallic RX-8 -
- 6MT - Stock -
Black Metal is offline   Reply With Quote
The Following 3 Users Say Thank You to Black Metal For This Useful Post:
helmetface (10-31-2012), Importfan12 (10-31-2012), Monotonous ONE (10-31-2012)
 Old 10-31-2012, 03:31 PM   #18
MS3-a(sore)ASS-rex's Avatar
Posts: 7,012   (View Stats)
Groans: 224
Lemme get that S3....
NATOR PA
 Old 10-31-2012, 03:41 PM   #19
Ian0611's Avatar
Posts: 80   (View Stats)
Ian0611 is a name known to allIan0611 is a name known to allIan0611 is a name known to allIan0611 is a name known to allIan0611 is a name known to allIan0611 is a name known to all
What kind of 1/4 mile times do you expect run with your build?
Ian0611 is offline   Reply With Quote
 Old 10-31-2012, 04:00 PM   #20
I have no idea I don't plan on running it on a drag strip ever. I am trying to do time attack and autox only.
 Old 10-31-2012, 04:06 PM   #21
dastpe's Avatar
i dont know much abt the 3076, but wont that be a bit laggy for an autox?
Black Metal (10-31-2012), Importfan12 (10-31-2012)
 Old 10-31-2012, 04:07 PM   #22
Groans: 78
Stick with the s3 or a 71 for autox
- 6MT - Stock -
The Following User Says Thank You to Black Metal For This Useful Post:
 Old 10-31-2012, 04:19 PM   #23
Don't plan on doing much autox so I am not to worried about lag.
Originally Posted by uncorked11 View Post
You might want to call DJ for a fifth port fo mo fuel. GLWB
I can't afford 5th port right now maybe later hoping the wmi will work for now.
Last edited by Importfan12; 10-31-2012 at 04:19 PM. Reason: MSF Database - Automerged Doublepost
 Old 10-31-2012, 04:22 PM   #24
uncorked11's Avatar
Posts: 1,238   (View Stats)
Groans: 165
yea I know Iwas set to pick one up but I decided I need to build the block first.
New....Camaro SS/RS
Stocked out selling parts.
2011 Black MS3
2006 Jeep Wrangler
-20 grand of Shit
 Old 10-31-2012, 04:14 PM   #25
uncorked11's Avatar
Groans: 165
New....Camaro SS/RS
2011 Black MS3
2006 Jeep Wrangler
-20 grand of Shit
The Following User Says Thank You to uncorked11 For This Useful Post:
 Old 10-31-2012, 04:23 PM   #26
xI Leveler Ix's Avatar
Posts: 1,752   (View Stats)
Groans: 75
Bunch of haters in here. Good luck Kc! Looking forward to see your car sometime!
STOCK AS OF 2015...
Old Stuff....
The Following User Says Thank You to xI Leveler Ix For This Useful Post:
 Old 10-31-2012, 06:10 PM   #27
surebOOst's Avatar
If there would have been real shit talk from a evo owner it would be from this guy... @4G63
ER Built 2.3l
On jackstands
awaiting parts
 Old 10-31-2012, 06:13 PM   #28
dastpe's Avatar
^ what he said, im too new to the evo world to talk too much crap.
ever planning to try to get the setup to ~500awhp?
 Old 10-31-2012, 07:17 PM   #29
Fux Wit It
Darksun280's Avatar
Posts: 9,214   (View Stats)
Groans: 175
Thread scan complete.
No threats detected.
Carry on citizens....
10.7 @ 133 auto 1G DSM
The Following 5 Users Say Thank You to Darksun280 For This Useful Post:
06Speed6 (10-31-2012), bstover17 (10-31-2012), Don06speed6 (10-31-2012), Ian0611 (10-31-2012), nycMS3 (10-31-2012)
 Old 10-31-2012, 08:19 PM   #30
bmylez's Avatar
Posts: 3,197   (View Stats)
Groans: 31
Thread scan complete. Threat to white women detected.
2007 CTS-V - Trying to sell
The Following 2 Users Say Thank You to bmylez For This Useful Post:
Darksun280 (10-31-2012), xI Leveler Ix (11-01-2012)
 Old 10-31-2012, 08:01 PM   #31
Speeeeeed
06Speed6's Avatar
Posts: 6,530   (View Stats)
@Darksun280 Darky i think he has more than enough to crush your car
2006 Mazdaspeed 6
Killer new stuff!!! phahengpro JAMES BARONE RACING 8 04-21-2011 12:26 AM
ATP's Boost Cut Killer SPDZRCR6 MazdaSpeed 6 - How-To's 10 01-04-2011 05:45 PM
Killer Chiller I want one!!!!!! bioevolve MazdaSpeed 3/6 - Fuel, Nitrous & Water Injection 38 11-18-2009 07:10 AM
Boost Cut Killer SPDZRCR6 MazdaSpeed 3/6 - Turbo Induction 2 10-14-2009 06:14 AM
Page generated in 0.52045 seconds with 36 queries
