![]() Join Date: Sep 2009 Location: Austin, Texas
Rep Power: 0 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 289
Groans: 40
(Thread Starter) | Not Ranked : 0 score CR K04 Stage 4 Hybrid, comparison to k04 |
| Not Ranked : 0 score Even the stage 4 seems to be rated less than the PTP turbo.
| [MSF STIG] ![]() Join Date: Apr 2008 Location: Gloucester, VA
Rep Power: 2120 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 1,476
| Not Ranked : 0 score If you're gonna mess with the OEM K04, then this is where you go for the "hybrid" versions: bnrsupercars.com
__________________ `07 Speed6 Sport Tit Gray Sleeper Express... SOLD `11 Ducati 1198SP SBK Duc Red w/Termi exh; Redline flash-tune + PC-5; Sargent; Shift-tech, CDT, & EVR Carbon; 14F/39R gear w/FBF QC; Speedymoto; R&G; ProGrip; Custom LED; Antigravity; Ducabike; Duc Perf, etc... a 182whp/105wtq The BIG DOG `12 Ducati 1100SP EVO Hyper Duc CORSE w/Termi exh; Redline flash-tune + PC-5; Ducshop Hyperstacks; 14F/41R gear w/FBF QC; Shift-tech, CDT, & BST(wheels) Carbon; R&G; ProGrip; Antigravity; Ducabike; Duc Perf, etc... a 95whp/75wtq The Hooligan `12 Aprilia RSV4 "Factory" SBK w/Akra Tit exh & race map; 15/42 gear; R&G; ProGrip; Gilles; CompWerkes; LightWerkes; Lightech; LSL Pegs; Antigravity; Zero Gravity; AF1 Flat Carbon, etc... the 181whp/83wtq The Land Rocket `17 Ford Focus RS Nitrous Blue w/Cobb V3/AT; OZ Ultraleggera; Schroth harness The Super Fun Toy |
| The Following User Says Thank You to FORZDA 1 For This Useful Post: | Mistersix (04-12-2010) |
![]() Join Date: Dec 2009 Location: Chicago
Rep Power: 0 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 5,256
![]() Join Date: Apr 2009 Location: Danbury, CT
Rep Power: 0 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 1,870
| Not Ranked : 0 score BNR is the way to go I just paid for mine a couple days ago, so hopefully in a week or 2 it will be in my hands
__________________ 08.5 MS3 GT - COBB AP : HPFP : DM CatchCanBack to almost stock! 99 Miata NB - Stock for now Building a EFR 6258 Kit w/ Megasquirt 2 enhanced, COPs, Methanol, 750cc Injectors |
![]() Join Date: Mar 2010
Rep Power: 0 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 895
| Not Ranked : 0 score stage 1 or 2? |
| Not Ranked : 0 score 2, wanted 3 but he had no timeframe on when that would be available, and i suck at waiting so i went w/ the 2 Ill post up pics when I get er
| Not Ranked : 0 score they mentioned that stage 1 was a straight up bolt on but were vague about stage 2...what modifications are required for stage 2? and so really they are just fitting in new compressors to the same housing? would the same compressor do better in a bigger housing? i guess im really seeing most of the benefit (other than the upgraded compressor and other things) is the fact that it is a bolt on meaning all intake mods and exhaust mods that fit the stock k04 will work on these hybrids as well |
| Banned ![]() Join Date: Mar 2008 Location: Winter springs
Rep Power: 0 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 2,251
Groans: 974
Groaned at 738 Times in 373 Posts
| Not Ranked : 0 score i'm still waiting on my stage 3 kkk modified k04-112 super hybrid to come in. i'm thinking my car will be a stage 4 maybe 5 once i get this hooked up. I just hope my rods don't exist the block. |
| The Following User Says Thank You to Alpha For This Useful Post: | Docnox (04-05-2010) |
LinkBack to this Thread: http://www.mazdaspeedforum.org/forum/forum/f498/k04-k06-hybrid-52874/ | ||||
| elaborazioni sui 1.8T..che siano A3 S3 A4 TT ecc... | This thread | Refback | 04-12-2010 11:56 AM | |
| Toyota FT-CH Compact Hybrid: Compact Hybrid To Extend Prius Family | Haltech | Automotive News | 0 | 01-11-2010 05:10 PM |
| REPORT: Two-mode hybrid joint development disbanded; Ram hybrid coming in 2010 | Haltech | Automotive News | 0 | 10-28-2009 03:40 PM |
| 2010 Kia Hybrid Test Drive: Prototype Forte and Cee'd Hybrids Pave Way to 2011 Optima Hybrid | Haltech | Automotive News | 0 | 08-20-2009 10:40 AM |
| First Drive: 2009 Chevrolet Silverado Hybrid and GMC Sierra Hybrid | Haltech | Automotive News | 0 | 02-28-2009 04:50 PM |
| GM prices Silverado Hybrid, Sierra Hybrid, and Pontiac G3 | Haltech | Automotive News | 0 | 11-18-2008 04:40 PM |
