 Old 06-30-2017, 09:05 AM   #1
mazda_speed_6's Avatar
Posts: 84   (View Stats)
mazda_speed_6 is just really nicemazda_speed_6 is just really nicemazda_speed_6 is just really nicemazda_speed_6 is just really nice
Default mazdaspeed 6 gtx 3576 vs pt 6266 1\4mile
So ive been doing a shit ton of research on big turbo builds after hours of reading it seems every one says pte turbos make more power with better spool but im try to do a build that will dominate at the 1/4 mile i found one thread that talks about garret turbos giving faster 1\4 mile but couldnt really find any info. What would you guys say would be a better choice right now im set on getting the pte 6262 ive read alot of threads about the atp turbo being to restrictive?
2006 MS6 sri/tbe/cpe diff mount/TS bpv/AT internals/jbr motor mounts/COBB acessport/stratified ots map/act 6 puck
mazda_speed_6 is offline   Reply With Quote
 Old 08-12-2017, 09:52 PM   #2
No advice buddys? Trying to hit low 11s by next summer.
 Old 08-12-2017, 10:26 PM   #3
gdawg25's Avatar
Posts: 248   (View Stats)
You planning on building your motor?
 Old 08-12-2017, 10:41 PM   #4
Yes sir i plan on sending my motor to speed performance to get a stage 3 long block build also wanna send my tranny and have them install a upgrade final drive aswell.. Im gonna switch to port injection and run a 50/50 mix e85/91. My goal is to hit around 650 whp would like a turbo that spools fast and makes good tq
 Old 08-12-2017, 10:42 PM   #5
Shwa's Avatar
Posts: 322   (View Stats)
EFR for daysssssssssssssssssss
The Following User Says Thank You to Shwa For This Useful Post:
mazda_speed_6 (08-13-2017)
 Old 08-12-2017, 10:49 PM   #6
Ive never looked in to EFR turbos to be honest there Borg Warner turbos right?
 Old 08-13-2017, 12:16 AM   #7
MSF's Punishing Member
Pu Manchu's Avatar
Posts: 2,992   (View Stats)
Groans: 546
that's going to depend more on your driving than your choice of those 2 turbos. either one has the power to put you in the 10s
94 M
MS6
IS350
The Following User Says Thank You to Pu Manchu For This Useful Post:
 Old 08-13-2017, 09:10 AM   #8
Will the 2 turbos net around the same power ive read that the atp gtx3576 are pretty restrictive on the atp turbine side? read this on the edgeautosport gen 2 gtx turbo thread? I know the gtx 3576 is capable of 10s my brothers sti runs 10.9s but im almost sure it aint a atp turbo his turbo use a vband on the hot side.
Logged my 1/4mile run MTLspeed6 Mazdaspeed3/6 General Discussion 6 08-21-2013 02:01 AM
Page generated in 0.27677 seconds with 23 queries
