![]() | | #241 | ![]() |
![]() Join Date: Jun 2012 Location: Mesa, Arizona
Rep Power: 0 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 1,244
__________________ Fastest GTX3076r, T3 twinscroll, built block, D14 meth spraying gen1 on the internet! |
| The Following 2 Users Say Thank You to mr.speedy3 For This Useful Post: | Mauro_Penguin (05-29-2016), Mazdazilla6 (05-23-2016) |
![]() | | #242 | ![]() |
(Thread Starter) | Not Ranked : 0 score My engine bay is finally with showing people. If you don't count the fingerprint smudges and the beautiful brown silicone off of the turbo.. or the mismatched clamp. It looks fairly decent. uploadfromtaptalk1464815946788.jpg All while looking sort of stock uploadfromtaptalk1464815984982.jpg tapatalkin
| The Following 6 Users Say Thank You to mr.speedy3 For This Useful Post: | g00s3y (06-23-2016), KiwiFlavor (06-23-2016), Mauro_Penguin (06-08-2016), Mazdazilla6 (06-04-2016), Micha (07-17-2016), Snyeed (06-16-2016) |
![]() | | #243 | ![]() |
![]() Join Date: May 2013 Location: Mejico, Texas
Rep Power: 0 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 2,088
Groans: 30
| Not Ranked : 0 score Is VTCS deleted and PNP'd on your stock IM or completely stock? I see you still have the components for VTCS there
__________________ 2009 Mazdaspeed 3 w/ Manley bottom end, keyed and lightened crank, CNC ported head, 2018 JMF v2 port injection fueled, CM twin disk clutch and Precision 6466 turbo, Kozmic built gen2 transmission with final drive swap. Tuning by PD Tuning |
![]() | | #244 | ![]() |
tapatalkin
__________________ Fastest GTX3076r, T3 twinscroll, built block, D14 meth spraying gen1 on the internet! | |
![]() | | #245 | ![]() |
Groans: 111
| Not Ranked : 0 score Since you seem to have endless issue mostly caused by the tight fitting, I wonder if you considered a Focus RS exhaust manifold since the 2.0/2.3 Ecoboost is basically the mazda 2.3disi-T engine block with different parts, variable timing also on the exhaust cam, a new PCV system, and so on. There's a change the head core is also similar.
| Official: BMW adds four-cylinder twin-scroll turbo power to X3 | Haltech | Automotive News | 0 | 02-17-2012 06:50 AM |
| removing twin scroll divider | turd burglar | MazdaSpeed 3/6 - Turbo Induction | 11 | 05-12-2010 11:06 PM |
| Twin-Scroll K04?!?!? | Mfinlay04 | Mazdaspeed3/6 General Discussion | 37 | 05-27-2009 06:28 PM |
