![]() Join Date: Apr 2009 Location: Great White North
Rep Power: 512 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 1,214
(Thread Starter) | Not Ranked : 0 score I'm having trouble identifying what to call my setup. I have an HTA3076r with the Tial housing. Essentially I have dual v-band adapters coming out of the hot side. Is this considered an IWG since it's off the turbo, or is this a EWG? I've considered it an EWG, but I want to be certain. Apparently the 38mm Tial is too small... My vband flange is 2.5" OD on the turbo, the Tial is 2". I wasn't able to find specs on the MV-R (V44 replacement), but the MV-S is 2.180" OD according to the technical doc. ... First BT build......
__________________ Mod List: ATP 3071R @ 22 psi, Grimspeed in 3-port mode, Steedspeed Manifold, Snow Performance Stage 2 Meth Kit, Cobb AP, CP-E 3" Nano SRI, CP-E Big Inlet TIP, Cobb "Stage 2" Suspension Kit, CP-E FMIC, CP-E DP, CP-E HPFP, CP-E MM, TWM STS, Custom Tuned by Fobio. |
| ILL3ST ![]() Join Date: Jun 2008 Location: Ann Arbor, MI
Rep Power: 1317 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 3,292
| Not Ranked : 0 score hey! another person with an hta. i'm trying to decide if i want to get a tial housing or not for it. it's considered ewg. as you can see atp calls it an ewg housing http://www.atpturbo.com/mm5/merchant...egory_Code=HSG sell me the 38mm. |
If you have the same setup, how would you mount it? An intermediate pipe/reducer off the turbo? I'm working with SU on getting it exchanged fortunately, so I won't be reselling it. Now I just need to find a tech sheet on the MV-R... That one should fit, I hope/think....
__________________ Mod List: ATP 3071R @ 22 psi, Grimspeed in 3-port mode, Steedspeed Manifold, Snow Performance Stage 2 Meth Kit, Cobb AP, CP-E 3" Nano SRI, CP-E Big Inlet TIP, Cobb "Stage 2" Suspension Kit, CP-E FMIC, CP-E DP, CP-E HPFP, CP-E MM, TWM STS, Custom Tuned by Fobio. | |
| Not Ranked : 0 score what's the ID? probably 44mm. |
(Thread Starter) | Not Ranked : 0 score The OD is 2.5", which is 63.5mm. I haven't measured the Id yet... I'll try to do that tomorrow.
| GT3071R (T3 Exhaust Housing) | holeinmypocket | MazdaSpeed 3/6 - Turbo Induction | 28 | 07-06-2010 10:51 PM |
| DIY Intake / MAF Housing | CaptainKRM | Mazdaspeed3/6 General Discussion | 40 | 01-29-2009 01:11 AM |
| The ATP Mazdaspeed Specific Exhaust Housing Info | socks | MazdaSpeed 3/6 - Turbo Induction | 16 | 10-21-2008 02:34 PM |
