  • 1 Post By LiEast
 Old 07-10-2011, 03:39 PM   #1
LiEast's Avatar
Posts: 582   (View Stats)
LiEast is the leader of the worldLiEast is the leader of the worldLiEast is the leader of the worldLiEast is the leader of the worldLiEast is the leader of the worldLiEast is the leader of the worldLiEast is the leader of the worldLiEast is the leader of the worldLiEast is the leader of the worldLiEast is the leader of the worldLiEast is the leader of the world
Default what else is needed?
so i was just getting somethings together for a while now to make sure i have everything i picked up a cpe big maf and inlet steep speed mani 44mm wastegate and i just got in a GT35R!!! got it with some oil lines that i should be able to convert to fit.
looking to get this going start of august but wonding what little crap is needed... do i "NEED" a boost controller? thats my main question where i would hook that up if i didnt get one...
and are people supporting these bad boys or just letting the mani hold it? the stepp speed is bad ass still dont wana have that thing just hang off it....
2008 RED MS3 GT>>>T3 GT35R .82 A/R>>>Tial 44 EWG dumping>>>SteedSpeed T3 Mani>>>Built Motor
PERM!
LiEast is offline   Reply With Quote
 Old 07-10-2011, 03:54 PM   #2
crazyp's Avatar
Posts: 1,093   (View Stats)
Groans: 68
lol im doing the same thing, went with a gt3071 though because i got it for a good price. Since i have a speed 6 i went steedspeed topmount, only the 6's can do this. the manis are stout from what i read so no support is needed. . I bought a 1.1 bar spring for my .44 and plan to run a MBC with it, but im learning too. The 35R is rather large, most dont recommend more than a 3076 because of lag
 Old 07-10-2011, 04:00 PM   #3
LiEast's Avatar
I already got the turbo theres a bunch of guys running the gt35r just looking to see about what little things i need before this monster goes in.. that way i dont get stopped mid project
crazyp likes this.
PERM!
 Old 07-10-2011, 06:41 PM   #4
jroc's Avatar
Posts: 1,482   (View Stats)
Cant use the search button, or go to the "big turbo build diaries" section of the forum? Or look for the sticky thread of whats needed for a build?
JDMFresh.com 1990 Mazda Miata
The Following User Says Thank You to jroc For This Useful Post:
LiEast (07-11-2011)
 Old 07-11-2011, 06:14 AM   #5
LiEast's Avatar
I did I'm just looking more of people's do and don'ts I pretty much got it all set just liking for a little convo of options and tips...
But your right...stupid post
PERM!
 Old 07-11-2011, 06:28 AM   #6
MS3-a(sore)ASS-rex's Avatar
Posts: 7,012   (View Stats)
Groans: 224
Is this the ATP 35r or a T3 Garrett 35r? If T3....
Cpe big inlet probably won't fit with the SS mani sou you'll probably have to make your own inlet. You'll need couplers from the turbo to the fmic because the new one sits lower. You'll need a new downpipe. Alot of people swap the stock BCS for a grimmspeed 3 port. I've seen people max out the cpe maf housing so you may want to look into that. If you're not running meth I suggest you get a kit. Solid motor mounts to stop the turbo from smacking the firewall. New injector seals. Fuck the return button.
I'm sure other people have shit to add as well.
NATOR PA
 Old 07-11-2011, 06:51 AM   #7
LiEast's Avatar
It's a T3 Garrett set up.... See I got the CPe inlet but it really won't fit? Sits that much lower? Thanks for the heads up..
PERM!
 Old 07-11-2011, 08:05 AM   #8
Groans: 224
I'm almost positive it won't fit but I've never tried to fit one myself. Someone else may have better (first hand) experience. I was pretty sure the cpe inlet was made primarily for the ATP turbos though.
NATOR PA
 Old 07-11-2011, 05:32 PM   #9
bmylez's Avatar
Posts: 3,197   (View Stats)
Groans: 31
Although the SS manifold keeps the turbo basically in the stock location, the exhaust housing will make the turbo sit a little lower. Not sure if it's enough to make the cp-e inlet not work, but it's easy to compare exhaust housings. The Mazda housing is basically a T25 with a dfifferent flange. Everything else sits the same. Then look at a t3 v-band discharge housing.
2007 CTS-V - Trying to sell
LiEast (07-11-2011)
 Old 07-11-2011, 09:22 PM   #10
LiEast's Avatar
I'll make it fit! ... Some how ;p
PERM!
 Old 07-13-2011, 10:05 PM   #11
steedspeed's Avatar
steedspeed is the leader of the worldsteedspeed is the leader of the worldsteedspeed is the leader of the worldsteedspeed is the leader of the worldsteedspeed is the leader of the worldsteedspeed is the leader of the worldsteedspeed is the leader of the worldsteedspeed is the leader of the worldsteedspeed is the leader of the worldsteedspeed is the leader of the worldsteedspeed is the leader of the world
DJ is a good guy to ask about the top mount manifold. Is the 35R a twin scroll?
steedspeed is offline   Reply With Quote
 Old 07-13-2011, 10:22 PM   #12
bmylez's Avatar
Groans: 31
Leen...don't see him mentioning top mount anywhere...I think he knows it won't fit the 3.
 Old 07-13-2011, 10:23 PM   #13
Groans: 224
OP has a MS3...isn't topmount out of the question?
NATOR PA
 Old 07-13-2011, 10:29 PM   #14
bmylez's Avatar
Groans: 31
Correct. Unless you want to hack out your firewall, you're not getting a top mount in there.
MS3-a(sore)ASS-rex (07-13-2011)
 Old 07-13-2011, 10:32 PM   #15
Groans: 224
More of a statement than a question lol. Directed more towards Leen and the OP. I'm an idiot
NATOR PA
 Old 07-13-2011, 10:33 PM   #16
doubleflusher's Avatar
Posts: 20,650   (View Stats)
Groans: 1,443
I'm an idiot
QFT
Beanfab / Tuned by Nishan
The Following User Says Thank You to doubleflusher For This Useful Post:
 Old 07-13-2011, 10:36 PM   #17
Groans: 224
QFT
How do you catch this every time I say it?! Lol
NATOR PA
doubleflusher (07-13-2011)
 Old 07-13-2011, 10:37 PM   #18
Groans: 1,443
We frequent the same threads.
 Old 07-13-2011, 10:41 PM   #19
Groans: 224
I stalk you.
Fixed.
NATOR PA
doubleflusher (07-14-2011)
 Old 07-14-2011, 08:44 PM   #20
LiEast's Avatar
yea not top mount its a ms3
PERM!
TPMS help needed mghtymouse380 2010 MS3 - Wheels & Tires 8 04-11-2011 12:42 PM
bov needed? LiEast MazdaSpeed 3 - Engine, Transmission & Driveline 7 03-15-2009 02:48 PM
Aftermarket BOV/BPV really needed?? ATAZ MazdaSpeed 3 - Engine, Transmission & Driveline 3 02-24-2009 05:39 PM
Page generated in 0.38249 seconds with 26 queries
