![]() | | #81 | ![]() |
![]() Join Date: Mar 2008 Location: Pittsburgh, PA
Rep Power: 0 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 17,174
Groans: 45
| The Following User Says Thank You to bova For This Useful Post: | Fobio (05-04-2009) |
![]() | | #82 | ![]() |
| Banned ![]() Join Date: Mar 2008 Location: On this planet (Washington)
Rep Power: 0 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 436
Whoosh was not fully built, he did push his car and push it hard. Abuse has nothing to do with why this is happening, abuse will keep it from happening. Myself and others have tried to blow up there MS3 motors, I was getting 7 to 8 counts of knock 3 to 4 months ago (modded and pushing hard at 24 to 26 psi) I wanted the car to blow up, never did. It was only after I put the car back to stock and started driving it on a daily basis that the problem showed up and then, kaboom. | ||||||||||||
| The Following User Says Thank You to ptperformance For This Useful Post: | SpeedSixxx (03-06-2010) |
![]() | | #83 | ![]() |
| Fuck sushi rolls ![]() Join Date: May 2008 Location: Los Angeles
Rep Power: 12764 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 2,168
Groans: 356
| Not Ranked : 0 score yo ptp. consider trying this JEGS Crankcase Evacuation Kit - JEGS I have used in on 3 of my street/strip muscle cars with great results in the past. I dont deal with modern engines/turbos so I am not sure how it would vary ...... but usually the simplest way is the best way.
__________________ 2007 Ms3 3071r fully bolted , retired and sold after 110k miles of abuse 2014 Black Track Pack premium , NA 4lyfe ...AED dyno tuned on E85 466.6whp / 406.8 TQ SAE |
| The Following User Says Thank You to rodrigo For This Useful Post: | SpeedSixxx (03-06-2010) |
![]() | | #84 | ![]() |
![]() Join Date: Aug 2008 Location: Medford, NJ
Rep Power: 0 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 625
| Not Ranked : 0 score Does using a heavier weight oil play any beneficial role of mitigating this? ie: 5W or 10W-40?
__________________ 08.5 CWP MS3 - Cobb AP *Stage 2* ATR with a street tune - JBR Power Path Stage II Short Ram Intake - Corksport TMIC - Corksport Downpipe (w/OE midpipe) - PTP HPFP - Stock BPV - TWM SS w/bushings - CP-e RMM - Bilstein Sports w/OE springs - TSW Nurburgring Machined 18x8.5 Wheels - FIREHAWK INDY 500 - SIZE: 235/40R18 - Cobb RSB - Motorcraft XT-M5-QS in the tranny! |
![]() | | #85 | ![]() |
I didn't mean to scare anyone, but this is an issue that needs to be addressed and as far as I am concerned we are diligently working on it.
Now this where I get pissed. You obviously have no idea how our PCV system works. The valve is not located in the valve cover, its located in the side of the block, this is why I am stating that the system is over come with oil, because its getting sprayed at a particular RPM and filling up the box that controls the vacuum for the PCV system, the valve cover has ZERO to do with the PCV system. Obviously from this statement you are talking about things you know nothing about, so from this point forward I am going to either delete you posts or ask you to do your homework before you post. Quality oil has been used in the car from day one, so that idea or theroy you had on that is just that... theory. We have PROOF that the motor is lighting off under the oil control ring and even with "quality" in the motor there are still signs of it. I suspect that its fuel in the oil that is burning off but I have to wait and see what my ford buddy has to say about it. The condition that bent the motors was very light throttle in 3rd gear, maybe 3 to 4 psi. This was the first time I had gotten on the motor in 2 hours of basic crusing. Last time, something caused the hydrolock, please tell me what you think it was vs shooting down my evidence that it was oil. Thanks.
What we are doing is trying to get you guys an answer for why a forged rod motor blows the rods out so easily and what is causing the motor to bend the rods. I know that the cly had quench plays a part with this but what is getting into the combustion chambers causing the rods to bend. If I had been at WOT running 30 PSI I could understand what caused the rods to let go, I wasn't and several others have not been as well. Its a down low condition that causes the motor to suck a huge gulp of oil (so far I think its oil until someone can come up with a better idea). I will be working on a fix for the car for sure, and yes we will have it for sale, but not until we have confirmed that its working on these cars. Stay tuned is all I can say for right now.
Again, if you don't buy please offer something else up for us to talk about. Just shooting down my idea and not offering anything else looks foolish on your part. Please, anything that you think could cause the rods to stop in the bores and bend like this. I think we can agree that its been hydro locked, what caused it if it was not oil?
I am not here to make speculation, I am here telling you that the motor hydrolocked from oil and I am working on the reasons why, sure the delivery might be a big off, take it with a grain of salt and look at the big picture, not the little one. As far as it happening to everyone, I would be silly to make a claim like that (read into if you want but that was not what I was getting at) which I didn't. I do feel that finding a solution as to why the motor bends the rods in the few that have had this happen would benifit everyone. Will it happen to you or the next guy, no idea, if there was a better way or solution to keep it from happening, I am sure you would install that on your car just as you would an intake or down pipe.
Get a divided CC with a media filter on one side. Our fix for this problem will come with a OCC that has just these attirbutes. Not sure when it will be avalible so if you cannot wait, get a OCC that has what I have stated, thanks. | ||||||||||||||||||||||||||||||
| The Following 9 Users Say Thank You to ptperformance For This Useful Post: | 802MS3 (05-04-2009), Frosty (05-04-2009), gamblore (05-06-2009), kramer (07-07-2009), kyoo (02-11-2010), mituc (07-17-2009), phillyb (05-03-2009), SpeedSixxx (03-06-2010), TruboPower (05-03-2009) |
![]() | | #86 | ![]() |
Yes the pistons stop before TDC thus causing the damage you see. No, the oil spraying on or during the intake stroke and then firing off would not cause rods to bend like this, you might see detonation or pistons breaking, but bending rods like the one's in the pictures would take a hydrolock. I appreciate the input, and I would suspect that you could see damage from your idea, but it should be localized in the piston where the heat and pressure would cause the damage, the rods bent because they were stopped from traveling up the bore anymore. If it would have been a detonation issue, the pistons would have shown damage equal to the rods, this was not the case.
It might help, but not enough to stop the problem. Its a design flaw, that we will have a fix for here soon. | ||||
![]() | | #87 | ![]() |
![]() Join Date: Mar 2008 Location: Canada
| Not Ranked : 0 score Don't take it too personally John ... I think we're just all trying to rationalize in our heads the reasons (for or against) on this to see if it all makes sense. Questions: 1- is the pcv valve not far enough from the actual oil level that it would be difficult to actually suck up oil? (maybe it is close? just wonderin') 2- would the oil catch can not be full of oil as well? Did you check that? Thx ... really appreciate the tear-downs and analysis!!
__________________ 2007 White MazdaSpeed 6 for sale ... new wheels = G8 GXP manual. |
![]() | | #88 | ![]() |
(Thread Starter) | Not Ranked : 0 score Guys, I am sorry that it took me so long to get to your questions. They have all been addressed and I will try to stay in here to help out. Thanks. |
| The Following User Says Thank You to ptperformance For This Useful Post: | gamblore (05-06-2009) |
![]() | | #89 | ![]() |
Groans: 45
| Not Ranked : 0 score simple egr delete is what ron did by fabricating a plate that would cost no more than a dollar and then also buying a 1/2" NPT plug for on the intake mani. i've been waiting to install mine for a while i'll get to it one day cause last time i took the throttle body off the egr was real dirty and also seemed to have oil in it besides carbon. |
![]() | | #90 | ![]() |
1. This is the problem, the stock location of the PCV is damn near the oil line of the motor. Its getting splashed by the motor and filling up the system. This is what we found out when we were testing the smoking turbo idea and I started a thread on that as well. We are well on our way to figuring out the problem and addressing it. 2. Sorry no OCC was on the car due to the fact that we had taken it pretty much back to stock, less the FMIC and new exhaust system, pump and clamp. I would like to see how many have blown under light throttle and were using a OCC. Next, I would like to see how many have blown running an EGR delete, this is playing a huge part in and as to why our motor popped. An EGR delete might become the next must have mod due to this particular issue of bending the rods and knock. I will keep you posted on what we find with the EGR issues, thanks. | |
![]() | | #91 | ![]() |
Groans: 45
![]() | | #92 | ![]() |
| The Following User Says Thank You to ptperformance For This Useful Post: | 802MS3 (05-04-2009) |
![]() | | #93 | ![]() |
![]() | | #94 | ![]() |
Groans: 45
| Not Ranked : 0 score well with ATR i'll just turn that code off, thats why i was going to do it that way. |
![]() | | #95 | ![]() |
Groans: 45
why would you want to put more oil in for a long trip, you might have sealed your fate right there if it falls in that your theory is correct. anytime i've put 5.5qts in its always at max line. | |
![]() | | #96 | ![]() |
(Thread Starter) | Not Ranked : 0 score Yes, if you have a COBB AP then you can shut it off. I also think that this plays a huge part into and why the AP has not had as many motor failures as those with out it. I think they turn it off with the 101 to 103 flashes, I could be wrong so take this as speculative. Thanks. |
![]() | | #97 | ![]() |
| Not Ranked : 0 score Didn't think you could??
![]() | | #98 | ![]() |
(Thread Starter) | Not Ranked : 0 score 5.8 qts is what it takes to reach the max line with our car. We then start and re-check, normally its close to 6 qts after the filter fills up. I only filled it to the max line, but I also was not on a level hill when I checked it. That could be part of the problem, but I suspect that more motors would be blowing based on oil overfills then what we are seeing. The oil level was down to just above the add line when the motor popped. Not sure why other then the exhaust side was full of oil during the tear down. |
![]() | | #99 | ![]() |
Groans: 45
| Not Ranked : 0 score yeah you just go into advanced and uncheck the 2 codes related to EGR. |
![]() | | #100 | ![]() |
![]() Join Date: Jul 2008 Location: NY
Rep Power: 0 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 34
| Not Ranked : 0 score i am sorry, when going 65, in 6th gear the car is at 3k rpms. that is the typical speed for most highways. according to you this will kill the mzr. how many engines have you inspected? what were the differences between them? how were they driven? to look at a handful of engines and simply state that this is the reason seems hasty. While I may not know engines to your extent i do know statistics and research principles and there are quite a few issues in regard to your statements. There are quite a few confounding variables here. but if you are correct, shouldn't you be on the phone with a lawyer about a class action lawsuit? if the car can't be driven at 3k rpms, which it seems would be the average rpm for highway driving, there is a problem here |
| The Following User Says Thank You to Ghost Rider For This Useful Post: | mouse0330 (05-10-2009) |
![]() | | #101 | ![]() |
| Not Ranked : 0 score My theory on the bent rods months back was a forceful combustion wallop to the piston head due to mis-timing but I just threw it out as food for thought. Timing would have to be advanced far enough for the combustion event to occur before the ideal time (like when it's still on the upstroke) and I'm not sure what would cause that outside of some bug in the ECU logic.
![]() | | #102 | ![]() |
Groans: 356
| Not Ranked : 0 score the spark plug fires on the upstroke (towards the end of it) and that kind of timing issues would present itself in the form of burned plugs , hole in the piston ..not bent rods.
![]() | | #103 | ![]() |
Next, I have looked at close to a dozen motors that have blown or bent the rods. Some have sent me parts others have sent me whole motors. They all seem to have the same condition showing signs or hydrolock. How many have you looked at? As far as how the were driven, or how they were modded, no idea... but this doesn't take away that the motors appear to be hydrolocked failures. Unless you have a better idea with some pictures to back up your claim of why they have failed, you comments are moot and speculative at best. I think its safe to say that there is a problem with the systems we are looking at for sure, this is why we are looking at them. If Mazda will address this, I have no idea. I am not willing to go out and build a motor and put $1000's into it to have this happen again. I am going to address the problem and take it from there to save my built motor. Again, if you have nothing to bring to the table other then "your wrong PTP" so be it, you will look childish in doing so with nothing to back up what you have to say.
![]() | | #104 | ![]() |
I would find it hard to see something like this happening with our motor due to the multiple bent rods that we had. But, I am willing to entertain anything at this point to rule out what I think the problem really is. Thanks. | |
![]() | | #105 | ![]() |
(Thread Starter) | Not Ranked : 0 score And how the hell did a few posts get placed above my original post in the start of this thread? Anyone find that odd? |
![]() | | #106 | ![]() |
| Not Ranked : 0 score I forgot to mention a boost spike as well in my theory but let's move on with yours ... makes more sense considering the events leading up to it.
![]() | | #107 | ![]() |
| Not Ranked : 0 score There's been some funny shit going on the past few days with dates and order of posts.
![]() | | #108 | ![]() |
Rep Power: 10779 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 6,334
P.S. if you have a BSD u should be putting in close to 7 quarts of oil.
__________________ 2006 Mazdaspeed 6 GT Black Mica #4126 KILLAH Built/SPEED PERF6RMANC3 (SP) 10.6:1 Pistons ~ SP 11mm H11 Head Studs ~ K1 rods ~ SP CNC Head Work ~ Crower 65lb Valve Springs ~ Fully Keyed/Pinned Motor ~ GTX35R w/Tial .82AR Hotside ~ JMF IM w/1000cc PI Injectors ~ SP 75mm TB ~ SP In-Tank FP w/Dual DW300's ~ AEM FPR ~ SP Custom PI Fuel kit ~ CPE 4" MAF ~ CPE SAFEseals ~ TR1035 FMIC ~ CPE Atmosphere DP/Ex Manifold/Oil/Water Lines ~ Tial MV-R EWG VTA'd ~ Denso ITV-24's ~ CPE Dual CBE ~ CPE BT TIP ~ CPE RMM ~ JBR TMM ~ JBR PMM ~ TTFMM ~ CPE RDM ~ Sonic Tuning CO's ~ LED Tails ~ Sonic Tuning HID's ~ Whiteline RSB ~ ACT 6 Puck w/unicorn dust First K04 in the 12's First MS6 in the 11's Certified RichTune E-Tuner | |
![]() | | #109 | ![]() |
![]() Join Date: Apr 2009 Location: oakland, ca
Rep Power: 0 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 387
Groaned at 56 Times in 24 Posts
| Not Ranked : 0 score i really wish mazda would just pony up and help us figure this shit out. are they even aware? is this even a possibility?
__________________ chief moped rider..... i just never let my friends see the moped. mopeds are great. they will do anything! |
![]() | | #110 | ![]() |
| Banned ![]() Join Date: Mar 2008 Location: Gaithersburg, MD
Rep Power: 0 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 335
Can you disprove that the WI/meth injection was not at fault? ie, instead of trying to prove the oil was at fault, try to disprove that there wasn't a sudden surge of excess WI spraying from a M10 nozzle overloading the cylinders. Both of those car's had meth injection right? We all know that excess water can hydrolock a motor like nobodies business. | |
| The Following 2 Users Say Thank You to Crossbow For This Useful Post: | 802MS3 (05-04-2009), ptperformance (05-03-2009) |
![]() | | #111 | ![]() |
Yea, and doctors should admit when they screw up. Its all about liablity, Mazda will never admit there is a problem, and I can just about say for a fact that they know about it, how... because the few vehicles they are involved with in the motorsports venues that they support or back as a sponsor. I am not going to get to much into that but I can say that there is something they know but are not sharing with the rest of the world. | |||
![]() | | #112 | ![]() |
Now this was not on the motor we have pictured, the motor in the pictures did not have WI running on the car. Pulled it off months ago. So that idea will not work with this motor. The other motor, maybe but there was nothing showing in the intake that we had residual in there. The other motor could have been hurt prior to the WI being installed. We suspect this because after we got the WI installed we hit the dyno, we couldn't get the knock under control on the dyno due to a possible failure that happened prior to the install. This is all speculation with that motor due to the fact that we never torn into it to check it out. My motor, zero problems with knock and no WI. | |
![]() | | #113 | ![]() |
![]() Join Date: Apr 2008 Location: Baltimore MD
Rep Power: 0 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 199
| Not Ranked : 0 score So lets say your theory is correct, what rpm cruising range do you recommend on the highway to be safe? |
![]() | | #114 | ![]() |
You said that the way they are driven and their mods do not take away from the hydrolock theory; but they do complicate the matter of saying it is the oil, does it not? What if some were equipped with CAI and driven through deep puddles. Perhaps they were missing the plastic undertray. This is a plausible cause for hydrolock, yes? Can you rules this out as a possibility? What about the meth/wi thread? is that another possibility? These questions are not meant to piss you off or take away from your theory; they are legitimate questions I have. And, while I am not accusing you of doing something improper or lying, it is important to remember that you are someone looking to sell parts and make money. I think as a consumer it makes sense for me to bring up any questions I may have. Regardless, I am done with this, as you seem to be overly defensive and feel the need to call me names. I know this means nothing to you, but I am not too inclined to support a business that feels a need to insult me when I ask questions. I thank you for your work and wish you the best of luck. | |
![]() | | #115 | ![]() |
__________________ 08.5 CWP MS3 - Cobb AP *Stage 2* ATR with a street tune - JBR Power Path Stage II Short Ram Intake - Corksport TMIC - Corksport Downpipe (w/OE midpipe) - PTP HPFP - Stock BPV - TWM SS w/bushings - CP-e RMM - Bilstein Sports w/OE springs - TSW Nurburgring Machined 18x8.5 Wheels - FIREHAWK INDY 500 - SIZE: 235/40R18 - Cobb RSB - Motorcraft XT-M5-QS in the tranny! | |
![]() | | #116 | ![]() |
Groans: 356
| Not Ranked : 0 score Originally Posted by lenny127 View Post "yo ptp. consider trying this JEGS Crankcase Evacuation Kit - JEGS I have used in on 3 of my street/strip muscle cars with great results in the past. I dont deal with modern engines/turbos so I am not sure how it would vary ...... but usually the simplest way is the best way. I have thought about this, but have yet to try it. I am afraid that it would suck oil into the exhaust system if we were to keep the stock location for CC vapors. It could be used on the drivers side spout thou, this would really help with ring seal and getting the pressure out of the top of the valve cover. I will take a look at this when we get a chance, thanks. " john, if the concern is pulling oil, u can certainly make an encased baffle system that allows to pull up air but oil wont be able to "climb" out of.
![]() | | #117 | ![]() |
![]() Join Date: Jan 2009 Location: PHX/SV AZ
Rep Power: 0 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 772
Groans: 94
Groaned at 43 Times in 33 Posts
| Not Ranked : 0 score I know the answer to the OP's question. Too much meth.
__________________ 321 HP/348TQ-- 13.940 @ 106 /3kft ASL |
![]() | | #118 | ![]() |
![]() Join Date: Feb 2009
Rep Power: 141 ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 7
| Not Ranked : 0 score so is this motor issue happening with the cx7 also? |
![]() | | #119 | ![]() |
I am going to agree with you on the other blown motors, there is a lot of speculation that goes into those, I can only tell you what my motor did. I did not drive it through a puddle, I did not suck anything into my CAI, and I don't have WI on the motor. Next, the few that have taken there motors down to see what happend and the parts that I have inspected have not shown signs of water ingestion nor any damage to the top of the pistons. This would be a good cause to show that these motors hydrolocked as well. Hence, why I am stating that it was an oil condition but I cannot rule out other forms of hydrolock with others cars. Last, if I were going to call names you would have known it. I an not known for holding back when someone is being a tool. Childish is not calling names and if you feel that it is, I would move away from the forums.... a lot of name calling happens in them. Take care and if you have questions, ask them but don't try to punch holes in my findings unless you have some findings of your own you would like to share. Thanks.
![]() | | #120 | ![]() |
| Why does your motor blow thread, look inside. | ptperformance | Mazdaspeed3/6 General Discussion | 207 | 08-16-2009 12:01 PM |
| Why did Mark's motor blow? | MarkyMark | Mazdaspeed3/6 General Discussion | 61 | 05-20-2009 01:33 PM |
| Will i blow? | Grim | MazdaSpeed 3 - Engine, Transmission & Driveline | 26 | 02-20-2009 10:22 AM |
| Is my engine going to blow? | toprock | MazdaSpeed 3/6 - Troubleshoot/Diagnostics | 15 | 01-19-2009 10:38 PM |
