| Blinder Xtreme Laser Jammer Blinder Xtreme is the TOP LED based Police Laser jammer on the market. The Blinder Xtreme covers all current Police Laser guns currently used by Law Enforcement. |
| Approved MSF Vendor ![]() Join Date: Dec 2010 Location: Lakeland,Fl
Rep Power: 121 ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 0
(Thread Starter) | Not Ranked : 0 score Blinder HP-905 Compact Laser Jammer |
| Not Ranked : 0 score Added to my wish list - just a matter of time.
![]() Join Date: Apr 2012 Location: Los Angeles
Rep Power: 425 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 956
| Not Ranked : 0 score Website is down?
__________________ 2012 BLACK MICA w/TECH Go: Cobb- AP(v2)//AT- Internals//ETS- TMIC//CorkSport- True 3" Intake/Camber Plates/BPV/Boost Tubes/Recirc Tube//Denso- ITV22's//NATOR- TP//JBR- 80a Duro TMM & PMM/SSP/Counterweight/Anchors//CP-E- Stage II RMM//Tri-Point- RSB w/Monster Endlinks//GT-Spec- 4 Points Ladder Brace/Mid Chassis Brace/Front 4-Point Brace/Front & Rear Lower Tie Bar/Trunk Reinforcement Brace//Bosch- 3 Bar MAP Sensor//Technafit- SS Brake Lines//KW- v3 Coilovers//Swift- Springs (8K front/6K rear)//BC- Rear Spring Perches Shoes: MB- Battles (Matte Gunmetal) 18X8 +43 wrapped wit Michelin PSS's 245/35/ZR18 Rice: Tint//Blacked Out Badging//CorkSport - Hoodlifts/Engine Compartment LEDs//JBR- Special Edition Cylindrical Knob Stereo: Full Custom Mobile Audio/Video Entertainment System 91 & Corn diagnostics by: |
| The Following User Says Thank You to The Nut For This Useful Post: | BACKYARDKUSTOMZ (03-10-2014) |
| Not Ranked : 0 score I hate to poop in a vendor subforum, but these guys haven't responded in forever and most of their links don't work. They aren't releasing firmware updates to beat the new LIDAR algorithms either. Do yourself a favor and contact laser interceptor USA if you want a functional jammer and support.
| The Following 4 Users Say Thank You to JgamB For This Useful Post: |
![]() Join Date: Jul 2008 Location: Syracuse, NY
Rep Power: 2506 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 2,527
| Not Ranked : 0 score If these guys aren't active I'd personally close the thread. I'll let @Raider; or @Haltech; determine that though.
__________________ ![]() Anthony D. Christiano - Co-Owner at Inspiration Studios Photography 2008 CosmicBlue Mazdaspeed3 294whp/335wtq - Stock K04 370whp/370wtq - BNR stage 3 FreekTuned, BNR Stage 3, Cobb AccessPort, HTP tray and 3" intake, Devil's Own Meth Injection D10 Nozzle, 3-Bar Map & Plug & Play Connector, PTP Injector Seals & Studs, KritzSpeed 3-Port BCS, Sure Return, UR Downpipe, CorkSport Race Pipe, Magnaflow Cat-back, CP-E FMIC, TWM STS, TWM A6 Leopard Shift Knob, TWM Leather Shift Boot, AutoTech Fuel Pump Internals, JBR trinity, Forge Version 2 BPV, Koni Yellows, H&R's, Sonic Tuning ST100's 18x8.5 + 5/16" spacer (ET40), SPC camber arms, Cobb Rear Sway Bar, Nitto NT05 235/40/18 (front) BF Goodrich g-Force Sport 235/40/18 (rear), MSD DashHawk, 35% tint, Semi-debadged ...Unicorn Jizz |
(Thread Starter) | Not Ranked : 0 score I am here. I am working on a new site and took some personal time due to illness but I'm still around. I will update my links shortly. |
| The Following 3 Users Say Thank You to BlinderGuy For This Useful Post: |
![]() Join Date: Sep 2014 Location: SoCal from NC and NYC
| Not Ranked : 0 score I see you Guys are in and out and nothing became of what members are looking for. The Anti Laser Priority, how do you campare?
__________________ __________________ 2012 Black MazdaSpeed3 Power: GTX3076R IWG / COBB EBCS / Bosch MAP Sensor Adapter Harness / Bosch 3 Bar T-MAP MAP Sensor with IAT / JBR TRU-3.5 / DM EGR Delete Kit / FORGE V1 BPV / AUTOTECH HPFP INTERNALS / UR TBE / UR DP / UR SP / NGK IRIDIUM IX / COBB SW / UR FMIC / MD OCC V1 & V2 / BrassCraft Coolant Bypass / RC IM Mani / cp-e Exi Mani / ZZB REPLACEMENT / Handling: DM TMM / DM RMM / DM PMM / JBR FSB / JBR RSB / JBR RTA / CS FEL / SPC CAMBER ARMS / BCRacing COILOVERS / GTSPEC STB /FRONT EBC YELLOWS / FRONT EBC SLOTTED ROTORS / GOODRIDGE SSL / TWM STS /RPF1 17x9 Wheels / 225/45-17 Toyo Proxes S4 / ACT ZX4-HDG6 / Extra Safety: COBB AP V3 / AEM WIDEBAND FAILSAFE (AFR) / V1 / AEM TRU BOOST / CS Skidplate / Innovate Motorsports MTX-D: Oil Pressure & Temperature / Fuel: 91 & 93 Octane / Looks: VENTPOD / JTMS3 DUAL POD / RB MUD FLAPS / Black Glossified Dipped Stock Wheels / GV OPEN MOUTH GRILL / JBR SHIFT KNOB / Black Powder Coated Front Calipers with Green MazdaSpeed Decals / Green Cabin and Trunk 8K Lights / Green Demon Headlights with black painted housing and RBG halo rings / RC signature VC / JTMS3 Stealth Sub Enclosure with a 10" JL Swallow Sub / baysonR MS-Style Lip Kit / COMING SOON AEM METH KIT / Anti Laser Priority /CS Radiator Panel / CS Rear Chassis Brace / CS Mid-Chassis Brace / CS Hood Scoop / DYNO TUNED by HYPNOTIC 93 and STREET TUNED on 91 soon e85 mix |
| Not Ranked : 0 score @BlinderGuy; no takes on the question?
| Not Ranked : 0 score The ALP is the best on the market - punch through tests vs the Dragon Eye prove it. Even with the limited distribution of these "random" pulse generating guns, the response will buy you ~1500ft to slow down before a reading is obtained. In some cases you can still get a jam-to-gun vs ECCM. The bulk of lidar guns are virtually useless vs any decent jammer setup, whether it's Blinder, LI (now an Escort product) or the ALP.
__________________ __________________ 2012 Black MazdaSpeed3 Power: GTX3076R IWG / COBB EBCS / Bosch MAP Sensor Adapter Harness / Bosch 3 Bar T-MAP MAP Sensor with IAT / JBR TRU-3.5 / DM EGR Delete Kit / FORGE V1 BPV / AUTOTECH HPFP INTERNALS / UR TBE / UR DP / UR SP / NGK IRIDIUM IX / COBB SW / UR FMIC / MD OCC V1 & V2 / BrassCraft Coolant Bypass / RC IM Mani / cp-e Exi Mani / ZZB REPLACEMENT / Handling: DM TMM / DM RMM / DM PMM / JBR FSB / JBR RSB / JBR RTA / CS FEL / SPC CAMBER ARMS / BCRacing COILOVERS / GTSPEC STB /FRONT EBC YELLOWS / FRONT EBC SLOTTED ROTORS / GOODRIDGE SSL / TWM STS /RPF1 17x9 Wheels / 225/45-17 Toyo Proxes S4 / ACT ZX4-HDG6 / Extra Safety: COBB AP V3 / AEM WIDEBAND FAILSAFE (AFR) / V1 / AEM TRU BOOST / CS Skidplate / Innovate Motorsports MTX-D: Oil Pressure & Temperature / Fuel: 91 & 93 Octane / Looks: VENTPOD / JTMS3 DUAL POD / RB MUD FLAPS / Black Glossified Dipped Stock Wheels / GV OPEN MOUTH GRILL / JBR SHIFT KNOB / Black Powder Coated Front Calipers with Green MazdaSpeed Decals / Green Cabin and Trunk 8K Lights / Green Demon Headlights with black painted housing and RBG halo rings / RC signature VC / JTMS3 Stealth Sub Enclosure with a 10" JL Swallow Sub / baysonR MS-Style Lip Kit / COMING SOON AEM METH KIT / Anti Laser Priority /CS Radiator Panel / CS Rear Chassis Brace / CS Mid-Chassis Brace / CS Hood Scoop / DYNO TUNED by HYPNOTIC 93 and STREET TUNED on 91 soon e85 mix | |
My laser jammer has paid for itself (LI 8.9) and I recommend a setup to anyone that frequents the highway or has a high concentration of lidar law enforcement in their area.
__________________ Manley forged long block, secret snail, manifolds, and 2gal E85 tune running like a champ - about to dial in a lot of meth and see what we've got. 13.10@117.1 full weight DD no prep 1/4 (BNR S3 / E85) | |
| Blinder Laser Jammer | BlinderGuy | Blinder Xtreme Laser Jammer | 0 | 07-21-2012 12:14 PM |
| New Blinder Laser Diode Jammer System | BlinderGuy | Blinder Xtreme Laser Jammer | 14 | 04-27-2012 11:02 AM |
| Blinder Laser Jammer Information Video | BlinderGuy | Blinder Xtreme Laser Jammer | 0 | 03-21-2012 10:56 AM |
