Like Tree4Likes
  • 1 Post By Lex
  • 1 Post By Mortose
  • 1 Post By Zoom66
  • 1 Post By Zoom66
 Old 01-12-2014, 03:33 PM   #1
Zoom66's Avatar
Posts: 281   (View Stats)
Default BT decision time
Read all your BT Sticky and still debating between GTX2867 and GTX3071/76 setup for my car. At this time I don't plan to built the engine, my car is my DD. Incline to get the 2867 and to get a E85 Tune as I have with my K04 but not sure how much more will I get from my current setup. Any suggestions? Also if I get your "kit" what else do I need to get to install based on my current mods? Thanks.
 Old 01-12-2014, 05:36 PM   #2
Oni
Oni's Avatar
Posts: 565   (View Stats)
Oni is the leader of the worldOni is the leader of the worldOni is the leader of the worldOni is the leader of the worldOni is the leader of the worldOni is the leader of the worldOni is the leader of the worldOni is the leader of the worldOni is the leader of the worldOni is the leader of the worldOni is the leader of the world
Me personally, I would go 3071. It has room to grow if you ever decide to build and it will run more efficient @ stock blocks limits than a 2867. The 2867 can shine a bit quicker, but without a built block, you won't push it that hard down low anyway.
'12 Velocity Red Mica MS3
Cobb AP V3 // Autotech Fuel Pump Internals // HTP 3" // UR Catted V2 DP // UR Resonated TP // UR Resonated CBE // GrimmSpeed EBCS // CP-E TMIC // GFB Respons BPV // JBR Trilogy 88/80/80 // Corksport Hood Struts // Prosport EVO Boost Gauge w/ block8head vent pod // E30 Freektune
Installing Soon : Stratified GA // Bosch 3 Bar Map w/ PNP Harness
Oni is offline   Reply With Quote
The Following 4 Users Say Thank You to Oni For This Useful Post:
ckMS3 (01-12-2014), Code Monkey (01-12-2014), EdgeAutosport.com (01-13-2014), Pu Manchu (01-12-2014)
 Old 01-12-2014, 05:48 PM   #3
^ what he said
 Old 01-12-2014, 05:58 PM   #4
ckMS3's Avatar
Posts: 1,112   (View Stats)
What they said. You really can't go wrong with either one. You would need a bigger intake to fit the turbo and a 3 bar map if you plan on running more than 21psi.
348tq/367whp -21.5 psi
 Old 01-12-2014, 06:09 PM   #5
sidekick's Avatar
Posts: 3,093   (View Stats)
Do you ever plan on making more than 440-450WHP? If no, then get the 2867. If yes, get the 3071. You're going to lose some low end with the 3071, which will probably make overall drivability suffer slightly.
 Old 01-12-2014, 06:32 PM   #6
MSF's Punishing Member
Pu Manchu's Avatar
Posts: 2,992   (View Stats)
Groans: 546
3071, even if your goal is to never go past 400whp.
 Old 01-12-2014, 09:50 PM   #7
JgamB's Avatar
Posts: 2,566   (View Stats)
Basically you're just choosing your effective RPM range. It'll start and end and little later with the 3071, so I'd base your choice on how you like your car to respond.
I notice you have the CP-E catted DP, so you might also get away with running the 3071 IWG without creep issues. I'm not sure anyone can confirm that as it seems to be a case by case basis.
 Old 01-13-2014, 03:44 PM   #8
I'm going to agree with everyone else here. The 2867 will have more power band, but the 3071 will likely be safer on a stock block because torque down low is what proves costly for the factory internals.
I recommend either a JBR or an HTP 3" intake to go with a bigger turbo. You can go bigger to 3.5" if you want, but I recommend a 3" intake for any big turbo setup. It seems as if you have everything else you will need.
PS: a 3bar map sensor and the plug and play harness would also be something you will want to get so you can control boost over 22psi.
sidekick (01-13-2014), Zoom66 (01-14-2014)
 Old 01-13-2014, 04:10 PM   #9
On top of what the edge guys said you will need a form of boost control Either a 3 port or the boost dial we make will do the trick.
I think of the GT2867 as a 330-375whp turbo and the 3071 as a 375-450whp turbo in most setups.
Remember that the tradeoff for a higher hp number is spool and response. So if you do lots of city and lower speed driving a smaller turbo is better suited. If you have a lot of open road go for the larger snail.
Zoom66 likes this.
bstover17 (01-13-2014), sidekick (01-13-2014), Zoom66 (01-13-2014)
 Old 01-13-2014, 04:21 PM   #10
Zoom66's Avatar
Thanks for the input Lex. I have a Cobb 3 port EBCS on my K04 right now. Most of my driving is Highway so pulling in for a GTX3071r IWG setup with a 3" HTP intake, also getting me a 3 Map Sensor while I am at it. Going to order the 14psi spring setting and shoot for 21-22 PSI with 25% E85 tune. Would you be concerned with boost creep with this setup?
 Old 01-13-2014, 04:36 PM   #11
With a catted downpipe like in your sig you should be fine for boost creep.
Zoom66 (01-13-2014)
 Old 01-13-2014, 04:24 PM   #12
Mortose's Avatar
Posts: 2,441   (View Stats)
Groans: 39
My experiance (at elevation) is that i LOVE the 2867, but my prefferance was to not ever have to brake boost, fast spool, and exelent drivability. With this turbo, i have no issues jumping out into traffic if need be.
Badinfluence likes this.
99 miata: sold
The Following 4 Users Say Thank You to Mortose For This Useful Post:
Godsarmy (01-14-2014), sidekick (01-13-2014), YABBAMZR (01-13-2014), Zoom66 (01-14-2014)
 Old 01-13-2014, 04:48 PM   #13
YABBAMZR's Avatar
Posts: 183   (View Stats)
YABBAMZR is the leader of the worldYABBAMZR is the leader of the worldYABBAMZR is the leader of the worldYABBAMZR is the leader of the worldYABBAMZR is the leader of the worldYABBAMZR is the leader of the worldYABBAMZR is the leader of the worldYABBAMZR is the leader of the worldYABBAMZR is the leader of the worldYABBAMZR is the leader of the worldYABBAMZR is the leader of the world
I have to agree with @Mortose; with spool and brake boosting. I wanted something similar to the k04 spool time for perfect everyday dd.
It pulls hard all the way to redline if needed.
Also I’m not at elevation.
2010 black mica
~GTX2867~ Auto tech internals--UR DP--UR res TP--bosch 3 bar map--HTP 3.5" intake--GFB dual port bpv--Cobb fmic--Cobb AP--GS EBCS--
--JBR fully mounted --JBR OCC--JBR TB TIG--JBR 51r battery tray--JBR RSB--JBR rear camber arms
--Stratified extended shifter--
Freektuned
333hp/354tq @ gsd (without meth)
YABBAMZR is offline   Reply With Quote
The Following 4 Users Say Thank You to YABBAMZR For This Useful Post:
ibsir (01-13-2014), Mortose (01-13-2014), sidekick (01-13-2014), Zoom66 (01-14-2014)
 Old 01-14-2014, 02:45 PM   #14
Zoom66's Avatar
Well pulled the trigger today
ATP GTX2867r
HTP 3" Intake
Bosch 3 bar Map
Map Sensor harness
2" silicone coupler
T clamps
and a lot of patience to wait for the brown truck to deliver and then install...LOL
JgamB likes this.
The Following 4 Users Say Thank You to Zoom66 For This Useful Post:
Bolted6 (01-19-2014), bstover17 (01-15-2014), EdgeAutosport.com (01-14-2014), that1rowdyracer (01-14-2014)
 Old 01-14-2014, 03:00 PM   #15
Zoom66's Avatar
ATP GTX2687
HTP 3" Intake
Bosch 3 bar Map
Map Sensor harness
2" silicone coupler
T clamps
Forgot to thank JP and his team for the assistance putting this packet together
The Following User Says Thank You to Zoom66 For This Useful Post:
 Old 01-14-2014, 03:49 PM   #16
It was our pleasure! Let us know if you need anything else!!
Zoom66 (01-14-2014)
 Old 01-14-2014, 04:43 PM   #17
Mortose's Avatar
Groans: 39
2" coupler? For what? The gtx2867r has a 3" inlet. Unless your talking bout the compressor exit, if so, just ignore me.
99 miata: sold
The Following User Says Thank You to Mortose For This Useful Post:
Zoom66 (01-14-2014)
 Old 01-14-2014, 04:51 PM   #18
Zoom66's Avatar
yep for the compressor exit to hook up to my Cobb FMIC...
Mortose likes this.
 Old 01-15-2014, 04:16 PM   #19
Zoom66's Avatar
What boost are you running on your 2867 and what HP and torque are you getting?
 Old 01-15-2014, 05:23 PM   #20
Mortose's Avatar
Groans: 39
Well, I'm running around 25-26 psi right now, and waiting for a new revision from lex. My HP/tq numbers are going to be skewed a little as I'm at 6400 asl, but from my research, I would say 400/410 isn't a grossly over corrected power level.
@atvfreek; is at sea level iirc, so his numbers would be more accurate.
99 miata: sold
 Old 01-15-2014, 09:40 AM   #21
06yellowroush's Avatar
Posts: 108   (View Stats)
06yellowroush is a splendid one to behold06yellowroush is a splendid one to behold06yellowroush is a splendid one to behold06yellowroush is a splendid one to behold06yellowroush is a splendid one to behold06yellowroush is a splendid one to behold06yellowroush is a splendid one to behold06yellowroush is a splendid one to behold
What numbers for the gtx2876 are safe an conservative for a stock block? Im stuck between the gtx3071 and gtx2876.
06yellowroush is offline   Reply With Quote
 Old 01-15-2014, 09:58 AM   #22
bladerunner10121's Avatar
Posts: 83   (View Stats)
bladerunner10121 is the leader of the worldbladerunner10121 is the leader of the worldbladerunner10121 is the leader of the worldbladerunner10121 is the leader of the worldbladerunner10121 is the leader of the worldbladerunner10121 is the leader of the worldbladerunner10121 is the leader of the worldbladerunner10121 is the leader of the worldbladerunner10121 is the leader of the worldbladerunner10121 is the leader of the worldbladerunner10121 is the leader of the world
Do some searching and reading but ill be nice....
regardless of the turbo. The number you have to worry about on the stock block is torque. The limits of the stock block have been tested to be safe to about the 400 lb-ft. Keep it below that and don't boost below 3k and you should be good to go on the stock block with either turbo.
Having said that the gtx3071 is much better suited for stock block safety because of where it puts the power band.
bladerunner10121 is offline   Reply With Quote
The Following 2 Users Say Thank You to bladerunner10121 For This Useful Post:
EdgeAutosport.com (01-15-2014), Vader (01-15-2014)
 Old 01-15-2014, 10:06 AM   #23
I have done some reading im just trying to get a ballpark of safe numbers for the gtx28 but everyone is saying the gtx 3071 is better suited for stock block because of the torque. Torque is aka the killer of our motors. So im probably just gonna go with the gtx3071 when it comes time.
The Following User Says Thank You to 06yellowroush For This Useful Post:
 Old 01-15-2014, 10:11 AM   #24
SneakySin's Avatar
Posts: 780   (View Stats)
SneakySin is the leader of the worldSneakySin is the leader of the worldSneakySin is the leader of the worldSneakySin is the leader of the worldSneakySin is the leader of the worldSneakySin is the leader of the worldSneakySin is the leader of the worldSneakySin is the leader of the worldSneakySin is the leader of the worldSneakySin is the leader of the worldSneakySin is the leader of the world
Groaned at 7 Times in 4 Posts
I think you've only taken in half the story so to speak. If you're more of a daily around town kinda guy and want a little extra pep, the 2867 may be more suitable for u as well. Just have your torque tuned down when u get tuned. If you have longer stretches of road and prefer your power up top, the 3071 may be more suitable.
Both would work just clearly would be tuned different. Hopefully that helps although that may have already been stated previously but I'm not scrolling back up to check lol
2008 Speed 3
CS 3" Intake//BNRS3v2//GS EBCS//3BAR MAP SENSOR//AT FP Internals//ATP DP catless//Custom FMIC//JBR Stage 3 SSP//CP-e Stage 2 RMM//MD OCC w/Sight Tube//EGR Del//NGK Iridium IX Plugs//Cobb AP//FreekTuned!!!!!
SneakySin is offline   Reply With Quote
 Old 01-15-2014, 02:12 PM   #25
Yea it does help me. Thanks for the advice. I probably going to go with the gtx3071 but also a couple friends who own speed 3s as well as freek said I should go for the 3076. But I think that will be over kill.
 Old 01-15-2014, 06:10 PM   #26
Zoom66's Avatar
Those are nice numbers. Are you on stock block?
 Old 01-15-2014, 07:07 PM   #27
Mortose's Avatar
Groans: 39
Yep.
99 miata: sold
 Old 01-18-2014, 10:05 AM   #28
Zoom66's Avatar
All the parts are in... install happening today...
The Following 5 Users Say Thank You to Zoom66 For This Useful Post:
Bolted6 (01-19-2014), bstover17 (01-19-2014), EdgeAutosport.com (01-20-2014), Goodrich27 (01-18-2014), YABBAMZR (01-18-2014)
 Old 01-19-2014, 06:07 AM   #29
Goodrich27's Avatar
Posts: 678   (View Stats)
Goodrich27 is the leader of the worldGoodrich27 is the leader of the worldGoodrich27 is the leader of the worldGoodrich27 is the leader of the worldGoodrich27 is the leader of the worldGoodrich27 is the leader of the worldGoodrich27 is the leader of the worldGoodrich27 is the leader of the worldGoodrich27 is the leader of the worldGoodrich27 is the leader of the worldGoodrich27 is the leader of the world
Interested to see how your install and results end up. I've gone back and forth about the 28 or 30 but I finally decided to go gtx28 also. Just will have to have mike or lex tune for lower torque on my stock block. glwb
Sent from my phone whilst bojanglen.
Go fasters:Manley H beams and Wiseco 87.5mm Forged pistons with stock compression, GTX3076 with Tial 38mm EWG, Full Race exhaust manifold w/2000* ceramic coating, MD meth injection TB spacer and Devils Own DC30 WMI with DO14 nozzle, Cobb 3 port ebcs, Ultimate Racing V2 Catless DP, Relentless Customs PNP IM with VTCS delete, TR11 core with HTP under route piping,ACT 6 puck, Corksport catless RP and CBE, CPE Stage II RMM,Cpe side mounts, perm plate with MD sealed and VTA OCC, HTP 4in Intake,ISC N1 coilovers, CS RSB, Tial BPV, Auto tech internals, Cobb ap v3, CPE injector seals,ngk step colder plugs, JBR throttle body TIG and coolant bypass, Corksport polyurethane exhaust hangers, Motorcraft unicorn juice, t6 rotella, Stoptech slotted and drilled front rotors with posi quiet pads.
Rice:corksport led fogs, Corksport eyelids, Corksport hood struts ,blacked out genpu rims, red evil M front and rear, red calipers, Corksport black mud flaps, Corksport shift knob, powder coat red valve cover, Intercooler pipes, and black gloss intake manifold A pillar gauge mount w/ AEM AFR, Oil temp, and Oil pressure gauges.
Goodrich27 is offline   Reply With Quote
 Old 01-19-2014, 01:05 PM   #30
mituc's Avatar
Posts: 3,528   (View Stats)
Groans: 111
For those concerned with the spool and response of a GTX3071 I need to say it's not bad at all. It can make boost down low just that it will come a bit slower, that's all. If you're at like 2200rpm and push the accel pedal in about 50% it takes about a second or so before it wakes up in 3rd or 4th, but once it does it just goes. This is still a 2.3 litre engine, so even before the turbo wakes up you will still have some ponies to push you forward and bring the RPM up.
Slower spool on these turbos is not horribly slow, just a bit slower. As for the boost... they can make boost even at low RPM (below 3k), just that not as fast as a smaller turbo, and sometimes this may be a good thing. And once you're at like 4k rpm the inertia is totally gone.
Once the streets will be clean again, probably in March or April, I'll work again with @Lex on a revision of my current tune to make it wake up sooner and faster.
Right now with the slower spool (which I guess no matter what we do with the tune will still be there, it's just the inertia of the bearings and wheels) when on summer tires I can also go WOT in 2nd gear from about 3000rpm with minimal wheel spin which occurs pretty late, so slower spool/boost build-up is not always a bad thing. With the factory K04 I was never able to go WOT in 2nd with or without the factory 1st/2nd gears load limits without massively spinning the wheels in the 3-4k rpm range.
So when times comes choose wise my friends... but right now I'd still take the gtx3071 even if there was a time when I was thinking that the 2876 may be better (which may still be the case, but now I just have a long and happy marriage with the 3071 and I can't see any reason to divorce).
2008 Cosmic Blue Mazda 3MPS
self-Versatuned to 22PSI
 Old 01-19-2014, 01:23 PM   #31
Goodrich27's Avatar
Totally agree different strokes for different folks but I run 3/9 E85 and read a few places that they couldn't without going 5th or 6th port.
 Old 01-19-2014, 03:50 PM   #32
Zoom66's Avatar
Build is done, I will post pictures later. Only issue we ran into was not related to the turbo but stripping out a couple of the bolts that hold the heat shields, other than that pretty straight forward. Zero oil, anti-freeze or boost leaks...nice.
Right now just running a break-in map with 0 WGDC and 15 psi max boost to make sure everything is in order before Eric at FlowTuned starts dialing in the fun. Even at this level the difference is significant from the K04, extremely happy with this baby. Spool sound is pure sex on this turbo with a 3" HTP intake..
Bolted6 (01-19-2014), EdgeAutosport.com (01-20-2014), JgamB (01-20-2014), Mortose (01-19-2014), Vader (01-20-2014)
 Old 01-20-2014, 02:33 PM   #33
Glad you like it!! Just wait till the boost goes up, then you'll love it!
Vader (01-20-2014), Zoom66 (01-20-2014)
Decision Time 6262ms3 MazdaSpeed 3/6 - Wheels & Tires 3 02-18-2012 01:39 PM
Decision Time - Koni's or ? buttdart MazdaSpeed 3/6 - Suspension & Brakes 10 07-24-2011 01:43 PM
Henderson says GM bankruptcy decision still in doubt; Hummer decision expected before month's end Haltech Automotive News 0 04-17-2009 11:30 AM
*****Please help me with my decision please help ****** silversurfer3 Mazdaspeed3/6 General Discussion 8 11-07-2008 07:26 AM
Page generated in 0.55242 seconds with 36 queries
