| EdgeAutosport.com EdgeAutosport.com is committed to being the best at what we do. High performance aftermarket parts is what we do but not who we are. We operate at the highest level of integrity and honesty, all while bringing you superior products and unmatched customer service and support. We hold ourselves to the highest standards, just like we do for our cars! Let us know how we can help! |
(Thread Starter) | Not Ranked : 0 score Hey guys its becoming more and more common for people to build their motors with the age and wear starting to creep up on us. Im going to list a few basic quotes of what it takes to build your motor and so you can get an idea if you are on the fence of taking the plunge! Now we all build at different points so replacing certain parts due to wear or peace of mind such as oil pumps and if you wanted to do vvt while you were in there also we have pricing for those we can get those ordered for you as well. Anyways if you have any questions or want to add anything let me know Also when you are building a motor and need to replace the head gasket we need to know what year and model the motor came from. (this is very important to help maintain oil functions in the motor)Wiseco Pistons-480.15 K1 Rods- 399.00 Main Bearings-123.50 Rod Bearings-92.52 Head Studs-174.42 Main Studs-122.35 Rear Main Seal-68.73 Front Oil Seal-9.13 Crank Pully bolt-11.58 Friction Washers-45.60 Overhaul Gasket Set-299.00 Cometic Head Gasket-89.00 VVT Actuator -119.06 Timing Chain-41.00 Timing Chain Tensioner-74.00 ACT 6 Puck Clutch-678.15 Flywheel Blolts-40.00 EDIT: I dont want to clutter the op with more parts right now but if you want to know the different options you have for hard parts here is a link to the website. http://www.edgeautosport.com/categor...ine/internals/
__________________ ![]() Click here to check out some clearance items were getting out of here! There are some great deals in here! Last edited by EdgeAutosport.com; 09-19-2012 at 10:26 AM. |
| The Following 27 Users Say Thank You to EdgeAutosport.com For This Useful Post: | atvfreek (10-08-2012), Bob-o (09-19-2012), bobbybennett23 (09-19-2012), Code Monkey (09-20-2012), Colin1337 (09-19-2012), Domino81 (09-19-2012), doubleflusher (09-19-2012), ESB Jiu JItsu (09-19-2012), exentix (09-19-2012), GunGuru727 (10-24-2012), helmetface (09-19-2012), kritz (09-19-2012), laxplayermjd (09-19-2012), Micha (03-26-2013), Monotonous ONE (11-25-2012), moomooz12 (09-19-2012), MS3-a(sore)ASS-rex (09-19-2012), ms3blackmica (01-09-2013), mtnrunner (09-19-2012), Onelovesoccer (10-04-2012), Pseud0logik (09-19-2012), robry (02-08-2013), Seatime3 (09-19-2012), silentwolf8 (09-19-2012), TiGraySpeed6 (09-19-2012), trf5000 (09-19-2012), uncorked11 (09-19-2012) |
![]() Join Date: Mar 2009 Location: Oceanside, CA
Rep Power: 0 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 925
| Not Ranked : 0 score I would suggest throwing up the price for some arp lube crap up there, and some assy lube. this thread will be stupid useful as i have given this list to like 5 people now. haha
__________________ Murdered out 2007 speed3 GT with navi. |
| The Following 4 Users Say Thank You to mtnrunner For This Useful Post: | doubleflusher (09-19-2012), EdgeAutosport.com (09-19-2012), kritz (09-19-2012), MS3-a(sore)ASS-rex (09-19-2012) |
(Thread Starter) | Not Ranked : 0 score Thanks for the heads up I go get some price quotes now. |
Groans: 224
| Not Ranked : 0 score Might want to price in timing tool purchase/rental, new timing chain & tensioner, serpentine belt & tensioner and as mtnrunner said, assembly and ARP lube. Edit: I also suggest including the other piston and connecting rod options available to the market.
| The Following User Says Thank You to MS3-a(sore)ASS-rex For This Useful Post: | EdgeAutosport.com (09-19-2012) |
| Not Ranked : 0 score can you guys sticky this in your section? much easier to refer people to this thread than text a list everytime.
| The Following User Says Thank You to mtnrunner For This Useful Post: | EdgeAutosport.com (09-19-2012) |
Groans: 224
| Not Ranked : 0 score Done. Good idea
| Approved MSF Vendor ![]() Join Date: May 2010 Location: Denver, CO
Rep Power: 1280 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 906
| Not Ranked : 0 score We're going to add some parts on here and update it with other ancillary parts but so far this is the bare minimum you need to replace when ripping the motor apart. |
| The Following 2 Users Say Thank You to JP@edgeautosport.com For This Useful Post: | MS3-a(sore)ASS-rex (09-19-2012), mtnrunner (09-19-2012) |
(Thread Starter) | Not Ranked : 0 score Timing chain and vvt added. |
| The Following User Says Thank You to EdgeAutosport.com For This Useful Post: | MS3-a(sore)ASS-rex (09-19-2012) |
(Thread Starter) | Not Ranked : 0 score Here is the assembly lube |
![]() Join Date: Mar 2010 Location: Lewistown, PA (State College)
Rep Power: 1938 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 3,144
| Not Ranked : 0 score What about machine work?
__________________ 2010 MS3 - Sold 2015 CX-5 GT AWD - Current ![]() |
| The Following User Says Thank You to trf5000 For This Useful Post: | EdgeAutosport.com (09-19-2012) |
| The Following User Says Thank You to EdgeAutosport.com For This Useful Post: | trf5000 (09-19-2012) |
Groans: 224
| The Following 2 Users Say Thank You to MS3-a(sore)ASS-rex For This Useful Post: | EdgeAutosport.com (09-19-2012), trf5000 (09-19-2012) |
Groans: 224
![]() Join Date: Jul 2008 Location: Syracuse, NY
Rep Power: 2506 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 2,527
| Not Ranked : 0 score Yeah, just toss that in a package... lol
__________________ ![]() Anthony D. Christiano - Co-Owner at Inspiration Studios Photography 2008 CosmicBlue Mazdaspeed3 294whp/335wtq - Stock K04 370whp/370wtq - BNR stage 3 FreekTuned, BNR Stage 3, Cobb AccessPort, HTP tray and 3" intake, Devil's Own Meth Injection D10 Nozzle, 3-Bar Map & Plug & Play Connector, PTP Injector Seals & Studs, KritzSpeed 3-Port BCS, Sure Return, UR Downpipe, CorkSport Race Pipe, Magnaflow Cat-back, CP-E FMIC, TWM STS, TWM A6 Leopard Shift Knob, TWM Leather Shift Boot, AutoTech Fuel Pump Internals, JBR trinity, Forge Version 2 BPV, Koni Yellows, H&R's, Sonic Tuning ST100's 18x8.5 + 5/16" spacer (ET40), SPC camber arms, Cobb Rear Sway Bar, Nitto NT05 235/40/18 (front) BF Goodrich g-Force Sport 235/40/18 (rear), MSD DashHawk, 35% tint, Semi-debadged ...Unicorn Jizz |
| The Following User Says Thank You to Domino81 For This Useful Post: | EdgeAutosport.com (09-19-2012) |
| Not Ranked : 0 score The head studs and main studs come with the little .5oz deal but I like to be super generous with the lube and run out of that quicly. the 1.69 oz would probably be enough for the average person. Since its only like 10-20 bucks i bought the 10oz container and had enough for a good time after. Machine work doesnt really fit into this thread because there are too many variables. Just going accross town to a different machine shop can cost a few hundred dollars more or less. Typical machine work is bore and hone with deck plate, check line bore, valve job, balancing, and resurfacing head and block deck.
__________________ Murdered out 2007 speed3 GT with navi. Last edited by mtnrunner; 09-19-2012 at 12:25 PM. Reason: MSF Database - Automerged Doublepost |
| The Following 2 Users Say Thank You to mtnrunner For This Useful Post: | EdgeAutosport.com (09-19-2012), trf5000 (09-19-2012) |
![]() | | #19 | ![]() |
| Not Ranked : 0 score Ignorance is bliss for Tom haha.
| The Following 3 Users Say Thank You to trf5000 For This Useful Post: |
![]() | | #20 | ![]() |
(Thread Starter) | Not Ranked : 0 score Just tell tom to spray more to cover up the vibes. What vibes bro? I have NOZ |
| The Following 3 Users Say Thank You to EdgeAutosport.com For This Useful Post: |
![]() | | #21 | ![]() |
(Thread Starter) | Not Ranked : 0 score ttt |
![]() | | #22 | ![]() |
| The Following User Says Thank You to mtnrunner For This Useful Post: | EdgeAutosport.com (09-20-2012) |
![]() | | #23 | ![]() |
(Thread Starter) | Not Ranked : 0 score yes but it bumps it to the main part of our page in the front. |
![]() | | #24 | ![]() |
| Not Ranked : 0 score oic
![]() | | #25 | ![]() |
(Thread Starter) | Not Ranked : 0 score Does anyone prefer a specific rod/piston combo? |
| The Following User Says Thank You to EdgeAutosport.com For This Useful Post: | MS3-a(sore)ASS-rex (09-25-2012) |
![]() | | #26 | ![]() |
Groans: 224
| Not Ranked : 0 score Eagle rods & CP Pistons is my personal choice. Oh and measured piston height....cylinders 1&4 and 2&3 match up perfect...I hate this car lol
| The Following User Says Thank You to MS3-a(sore)ASS-rex For This Useful Post: | EdgeAutosport.com (09-25-2012) |
![]() | | #27 | ![]() |
any wrist pin thats 22.5 will fit a genpu piston.
__________________ ![]() Click here to check out some clearance items were getting out of here! There are some great deals in here! Last edited by EdgeAutosport.com; 09-25-2012 at 10:38 AM. Reason: MSF Database - Automerged Doublepost | |
![]() | | #28 | ![]() |
![]() Join Date: Feb 2012 Location: King of Prussia, PA
Rep Power: 0 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 126
| Not Ranked : 0 score Wiseco Pistons you already have but I'd be curious about the Molnar Technology rods if you have them.
__________________ 2011 VMR Mazdaspeed 3 Cp-e | Cobb | JBR | Freektune |
| The Following User Says Thank You to Ezekiel81923 For This Useful Post: | EdgeAutosport.com (09-25-2012) |
![]() | | #29 | ![]() |
(Thread Starter) | Not Ranked : 0 score We will be also carrying the Molnar rods. |
![]() | | #30 | ![]() |
![]() Join Date: Dec 2009 Location: Minneapolis, MN
Rep Power: 390 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 1,607
| Not Ranked : 0 score What about some options for people looking for a fairly mild build. What rods will work with a gen2 piston for example and what that set up would cost.
__________________ 2006 BCM MS6 GT CS SRI/TIP Jbarone SSP/bushings cp-e RMM, TMIC, Stiff Diff AP KMD V2.whatever Ebay Catless DP Grom Ipod |
| The Following User Says Thank You to BigjohnB20 For This Useful Post: | EdgeAutosport.com (09-25-2012) |
![]() | | #31 | ![]() |
(Thread Starter) | Not Ranked : 0 score Who needs to get built by edge? |
![]() | | #32 | ![]() |
![]() Join Date: Mar 2010 Location: Edmonton, AB
Rep Power: 0 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 631
| The Following User Says Thank You to Bob-o For This Useful Post: | EdgeAutosport.com (10-15-2012) |
![]() | | #33 | ![]() |
| Not Ranked : 0 score If you offered a package with a built short block... I'd seriously consider it.
| The Following User Says Thank You to Domino81 For This Useful Post: | GartzSpeed (12-12-2012) |
![]() | | #34 | ![]() |
| The Following User Says Thank You to EdgeAutosport.com For This Useful Post: | GartzSpeed (12-12-2012) |
![]() | | #35 | ![]() |
| Not Ranked : 0 score Seriously? ...rushes to website... Wheeeerrre?
| The Following User Says Thank You to Domino81 For This Useful Post: | EdgeAutosport.com (10-09-2012) |
![]() | | #36 | ![]() |
![]() Join Date: Jun 2011 Location: Olympia, WA
Rep Power: 0 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 133
Groans: 58
Groaned at 134 Times in 68 Posts
| Not Ranked : 0 score any chance you guys build the motors and install them yourself? ![]() I hope so. Or know of a reputable place in oregon/WA???
__________________ US ARMY 07 True Red MS3 //Fully Bolted-Dizzy Tuned Wife drives the Speed now, I caught the gay, miata for me. 96 Red Miata // Not stock** Missing home... Florida ![]() |
| The Following User Says Thank You to jonspeed3 For This Useful Post: | EdgeAutosport.com (10-09-2012) |
![]() | | #37 | ![]() |
Also in that area I have a few places I can recommend you to | |
![]() | | #38 | ![]() |
Groans: 58
| Not Ranked : 0 score Please do tell all places you recommend. Seriously contemplating a build sometime next month when i return to the states.
| The Following User Says Thank You to jonspeed3 For This Useful Post: | EdgeAutosport.com (10-10-2012) |
![]() | | #39 | ![]() |
| Not Ranked : 0 score Eric, you whore. Btw, are you referring to the CP-E engine packages? Because I found those...
![]() | | #40 | ![]() |
I was also referring to something Alan is assigned to in getting pricing and parts list together for us directly to offer built motors built here locally and I will keep you posted with those prices when I find them out | |
| Weston's MS6 Build Thread | Weston | MazdaSpeed 3/6 - Build Diaries | 23 | 08-14-2014 03:37 PM |
| Captain KR's build thread | Captain KR | Mazda MZR DISI Engine Builds (2006-2013) | 28 | 04-17-2013 08:41 AM |
