Like Tree5Likes
  • 1 Post By EdgeAutosport.com
  • 1 Post By timmcc02
  • 1 Post By jrotaryb
  • 1 Post By jack_hammer
 Old 03-04-2014, 05:05 PM   #1
jack_hammer's Avatar
Posts: 6,822   (View Stats)
Groans: 549
Default Koni kits with h&r springs
Any chance you guys plan to carry these when released?
https://www.google.com/url?q=https:/...8grSpRAd-MtdCA
Here's the link to the website
http://www.koni-na.com/cat_search.cf...=25&mod_id=535
Sent from my LG-MS770 using Tapatalk
it's fun to do bad things
EdgeAutosport.com (03-05-2014), Tokay444 (04-21-2014), trancehead (03-05-2014)
 Old 03-04-2014, 05:27 PM   #2
SparkySparks's Avatar
Posts: 1,314   (View Stats)
http://www.koni-na.com/cat_search.cf...e5Qx7AcFnhc5UH
Second link doesn't seem to be working, would be nice for these to release while Koni is doing their 25% off.
On Order:
Coming Soon:
DIY Projects:
 Old 03-04-2014, 05:32 PM   #3
Groans: 549
Looks like April 2014 according to the link that's not working. Here's another link. I'm on my phone, so sometimes links don't copy properly
http://www.koni-na.com/sport_spring.cfm
The Following 2 Users Say Thank You to jack_hammer For This Useful Post:
rfinkle2 (03-18-2014), WetzMS3 (03-26-2014)
 Old 03-04-2014, 06:02 PM   #4
obijack's Avatar
Posts: 1,830   (View Stats)
That would be bad ass!
2014 Honda Grom-Red
2014 Yamaha Grizzly 350- Blue
 Old 03-05-2014, 08:33 AM   #5
We will certainly be carrying those when they are released!
obijack likes this.
Sterling (03-26-2014), Tokay444 (04-21-2014), trancehead (03-05-2014)
 Old 03-16-2014, 05:17 PM   #6
timmcc02's Avatar
Posts: 253   (View Stats)
timmcc02 is the leader of the worldtimmcc02 is the leader of the worldtimmcc02 is the leader of the worldtimmcc02 is the leader of the worldtimmcc02 is the leader of the worldtimmcc02 is the leader of the worldtimmcc02 is the leader of the worldtimmcc02 is the leader of the worldtimmcc02 is the leader of the worldtimmcc02 is the leader of the worldtimmcc02 is the leader of the world
Groaned at 9 Times in 3 Posts
Let us know when that sport kit becomes available!
jeffdevo likes this.
timmcc02 is offline   Reply With Quote
 Old 03-17-2014, 05:05 PM   #7
Will do!
jeffdevo (03-25-2014)
 Old 03-18-2014, 10:43 AM   #8
jrotaryb's Avatar
Posts: 416   (View Stats)
The STR.T "Orange" strut/shock set is available now from Koni to my knowledge (without the H&R springs, which should be different than the current H&R's sold individually).
Now idea how good they are, but they are very affordable...
pedal2plastic.wordpress.com
The driving game blog
Cobb: AP, SRI & RMM
Corksport: TIP, TMIC, RP,SSP
Autotech Internals
Bilstein PSS Coilovers
SPC Rear Camber Arms
JBR RSB
Gram Lights 57F - 18x8.5 +45
Rfinkle2 tuned @21psi
The Following User Says Thank You to jrotaryb For This Useful Post:
 Old 03-25-2014, 09:24 PM   #9
nybe0010's Avatar
Posts: 276   (View Stats)
nybe0010 is the leader of the worldnybe0010 is the leader of the worldnybe0010 is the leader of the worldnybe0010 is the leader of the worldnybe0010 is the leader of the worldnybe0010 is the leader of the worldnybe0010 is the leader of the worldnybe0010 is the leader of the worldnybe0010 is the leader of the worldnybe0010 is the leader of the worldnybe0010 is the leader of the world
Groaned at 3 Times in 1 Post
on the website. I see koni is offering the oranges and yellows as kits now. one comes with blue koni springs and the other is h&r. i havent heard much about the oranges either, but indeed very affordable
@EdgeAutosport.com;
11' Black Mica MS3 ATK Reman Long Block iMOTO Shift Forks LuK Clutch Fidanza Flywheel
GC+Koni Coilovers CNT CBE JBR Trilogy Mounts Forge V1 BPV CPE SafeSeals Block8Head Dual Vent Pod Blowshift Boost / OP
nybe0010 is offline   Reply With Quote
 Old 03-26-2014, 07:53 AM   #10
jrotaryb's Avatar
@EdgeAutosport.com;
I'm not sure about that - from what understand, they are not offering two kits with two different springs. The springs offered will be the same as the current H&R springs. I contacted a Koni rep who told me that the springs are not unique to the Koni kit and are the same as the H&R springs you can currently buy from a number of different vendors. So, if you currently have H&R springs and want a set of yellows/oranges from Koni, you will effectively have the same "kit".
Whether Koni will have them painted/powder coated in Koni blue for their packaging is yet to be seen (as Koni's website notes the product may look different because the site is using a stock photo).
For now, Koni's price for STR.T ("orange") with the annual shock sale is pretty crazy!
EdgeAutosport.com likes this.
Cobb: AP, SRI & RMM
Autotech Internals
JBR RSB
 Old 03-26-2014, 07:56 AM   #11
Groans: 549
the oranges are only for the front. the rears are "TBA"
 Old 03-26-2014, 09:22 AM   #12
jrotaryb's Avatar
Wrong. Rear is TBA for Gen1 MS3. They are available for Gen2 now:
Front:
8750 1088L
8750 1088R
Rear:
8050 1109
Cobb: AP, SRI & RMM
Autotech Internals
JBR RSB
 Old 03-26-2014, 09:35 AM   #13
nybe0010's Avatar
i just looked on edge and saw oranges for both gens. from what i read the orange is comparable to the yellows on like the softest setting. so would that be too soft for most of us then? how would that compare to the fsd? i know your not suppose to run lowering springs with those but ppl have done it without issues. orange can be had for $450 ish and i thought i saw yellows online for like $517 or something!
 Old 03-26-2014, 11:28 AM   #14
The orange STR.T shocks are their "street" upgrade. Meaning for cars who want a little more performance out of their setup but are probably gonna never find themselves on a track. The Yellow's are just a step up from that having the adjustability to go a bit stiffer and be used on the track as well as the street. You can run lowering springs with either of these no problem as they are both designed to work with them. It seems the H&R springs are the preferred spring for both of these struts though.
The FSD's aren't necessarily designed with lowering springs in mind as they are more for comfort and daily drivability. I'm sure you can put lowering springs on a set of FSD's but it probably won't give you the best results...
nybe0010 (03-26-2014), OverBoosted (03-26-2014)
 Old 03-26-2014, 12:06 PM   #15
OverBoosted's Avatar
Posts: 1,608   (View Stats)
I would be interested in a review of the SRT.Ts. Im in need of new struts and am highly considering them or the yellows.
 Old 03-26-2014, 01:58 PM   #16
Groans: 549
i DGAF about the pu. i'm living that genwon life, playa!
 Old 04-20-2014, 07:39 AM   #17
Steezyms3's Avatar
Posts: 202   (View Stats)
Steezyms3 has a brilliant futureSteezyms3 has a brilliant futureSteezyms3 has a brilliant futureSteezyms3 has a brilliant futureSteezyms3 has a brilliant futureSteezyms3 has a brilliant futureSteezyms3 has a brilliant futureSteezyms3 has a brilliant futureSteezyms3 has a brilliant futureSteezyms3 has a brilliant futureSteezyms3 has a brilliant future
Groaned at 6 Times in 4 Posts
If anybody wants to try those orange konis I do not recommended them. I tried on one of my previous integras and they did not last more than 2k miles before they gave out on me. They were always bouncy I did have the car lowered about 2 inches but they didn't hold up for even as long as stock ones would have so just keep that in mind.
Steezyms3 is offline   Reply With Quote
 Old 04-21-2014, 11:59 AM   #18
nybe0010's Avatar
your ride was lowered 2 inches.. @smr87; begs to differ.
 Old 04-21-2014, 12:32 PM   #19
Steezyms3's Avatar
That was just my 2 cents. Yes I was lowered a good amount but even on stock shocks I've lowered two inches before and held up way longer than those konis did.
 Old 04-21-2014, 03:49 PM   #20
smr87's Avatar
Posts: 1,288   (View Stats)
smr87 is the leader of the worldsmr87 is the leader of the worldsmr87 is the leader of the worldsmr87 is the leader of the worldsmr87 is the leader of the worldsmr87 is the leader of the worldsmr87 is the leader of the worldsmr87 is the leader of the worldsmr87 is the leader of the worldsmr87 is the leader of the worldsmr87 is the leader of the world
I've got about 2.5k on my set right now, so far so good. Including a proper thrashing on a less than smooth road this morning. Comparing across two different platforms is useless. I also hope you filed a warranty claim on those if they shit the bed that quickly I'd venture to guess they had something wrong with them.
1999 Cosmos M3
turning bits and more better suck, squish, bang, and blow
FREEK'D 2012 Liquid Silver Genpu-sold
We were young, and we were fearless and, after all, nobody had ever told us young engineers that we couldn't successfully land humans on another planet. So we did it.
smr87 is offline   Reply With Quote
The Following User Says Thank You to smr87 For This Useful Post:
EdgeAutosport.com (04-21-2014)
 Old 04-21-2014, 05:29 PM   #21
2" is pretty aggressive! But either way, it seems that the guys who have them on their speeds are pretty happy with them.
 Old 06-26-2014, 07:42 AM   #22
Just wanted to let you guys know that we have these kits in stock. I'll be making up a thread on them shortly.
KONI Yellows w/ Cobb springs & stock springs Fobio MazdaSpeed 3/6 - Suspension & Brakes 9 08-20-2012 08:24 PM
Koni FSD and Cobb Springs tagkat MazdaSpeed 3/6 - Suspension & Brakes 7 05-22-2011 08:51 AM
Springs and koni or coilovers? Shooter445 MazdaSpeed 3/6 - Suspension & Brakes 2 03-07-2011 06:16 PM
Page generated in 0.41513 seconds with 30 queries
