  • 1 Post By JP@edgeautosport.com
 Old 02-21-2012, 12:18 AM   #1
JP@edgeautosport.com's Avatar
Posts: 887   (View Stats)
Neutral  +1 score
Default NEW Turbosmart IWG Actuators!!!
Hey guys! Check this out! Forge has had the only option for this for a long time now and now Turbosmart has stepped in and created a nice piece too. Available in blue or black and sold as a direct bolt-on part. Comes with springs that allow for adjustment from 3-26psi base pressure. This is great for those of you looking to push the limit of the stock K04!!!
MSRP: $199.99
YOUR PRICE: $179.99 SHIPPED
CLICK HERE TO CHECK IT OUT!!!
Designed like any Turbosmart product, with the highest of quality and precision, the Internal Wastegate Actuators (IWG) provide better turbo response and greater sensitivity when managing boost pressures. The Turbosmart IWG is adjustable with several spring options and packaged in a kit form so they can be fitted as a direct bolt-on replacement for the factory part.. It canʼt get any easier!
Features:
• Silicone diaphragm with Nomex reinforcement to withstand high temperatures.
• High grade, billet aluminum construction.
• Stainless steel rods and connecting clevis for corrosion resistance.
• Locking Collar design cap allows for quick spring changes.
• Range of springs from 3 to 26 psi base pressure.
Ms3_Miami likes this.
The Following 7 Users Say Thank You to JP@edgeautosport.com For This Useful Post:
AZSPEED3 (08-26-2012), breakfstincluded (02-21-2012), Darksun280 (03-27-2012), Eaglesfan (03-23-2012), Easter Bunny (08-26-2012), EdgeAutosport.com (02-21-2012), PapaSmurf (03-23-2012)
 Old 03-23-2012, 01:28 PM   #2
bump @Eaglesfan try this out?
 Old 03-23-2012, 01:48 PM   #3
SLOWHATCH's Avatar
Posts: 2,461   (View Stats)
Groans: 274
So what exactly is this going to provide? I was under the impression we were already maxing out the k04 with the stock iwg?
 Old 03-23-2012, 01:55 PM   #4
This will allow you to hold boost up top a little longer. We do run the k04 to the potential but this allows higher boost levels throughout the power band and less tapering
SLOWHATCH (03-23-2012)
 Old 03-23-2012, 01:59 PM   #5
Eaglesfan's Avatar
Posts: 174   (View Stats)
Eaglesfan is the leader of the worldEaglesfan is the leader of the worldEaglesfan is the leader of the worldEaglesfan is the leader of the worldEaglesfan is the leader of the worldEaglesfan is the leader of the worldEaglesfan is the leader of the worldEaglesfan is the leader of the worldEaglesfan is the leader of the worldEaglesfan is the leader of the worldEaglesfan is the leader of the world
I am curious about it!
Injen cai, TIP, turbosmart bov, TR8 front mount, Cobb IC Piping, Ebay dp, Cobb ap w/PERM, 16 x 6.5 steelies, Race Built exhaust mani and a 167k mile K04!
Eaglesfan is offline   Reply With Quote
 Old 03-23-2012, 04:43 PM   #6
silvapain's Avatar
Posts: 6,665   (View Stats)
Groans: 136
Subbed for when I have money.
Tapadatass
 Old 08-26-2012, 11:33 AM   #7
Bob Ross Fanclub
Tomas's Avatar
Posts: 3,811   (View Stats)
Is there any way Edge could get Turbosmart to make one of these for the ATP turbos?
 Old 08-27-2012, 04:32 PM   #8
Let me call turbosmart and see if they make something that is compatible along those lines.
Tomas (08-27-2012)
Turbosmart BPV redblur 2010 MS3 - Engine, Transmission & Driveline 31 09-07-2011 12:55 PM
Page generated in 0.30556 seconds with 25 queries
