Like Tree142Likes
 Old 03-06-2014, 10:37 AM   #1
Neutral  +1 score
Default Precision Turbo Kits at EdgeAutosport
I teased this a while ago in the thread that we released the Kozmic Precision Downpipe in but we now officially have a "kit" that is ready for you to order and bolt on to your car.
For ever since I can remember, ATP (Garrett) bolt on turbos were pretty much the only option for adding on big power with relative ease. You pretty much had no choice if you wanted to avoid the time consuming and high cost of going custom. We were limited because hardly anyone made a manifold for us and the only ones that were available were flanged for stock turbo anyways so the choice was clear. ATP Bolt on was the only reasonable way to go.
But now we finally have the option to make running a precision turbo much easier. Precision Turbo was founded in 1987 and is one of the worlds foremost manufacturers of high performance turbochargers. Uncompromised quality and unsurpassed performance is their moto and they produce some of the highest flowing aftermarket turbos at a bargain of a price.
So our thanks goes out to cp-e and Kozmic Motorsports for making this kit possible. cp-e created the precision flanged option for their LRT Manifold and Kozmic has created a downpipe, a dump tube, and an oil return/feed line designed specifically for a precision turbo and the cp-e manifold. We are very excited about these kits as we believe this is the future for big power on the Mazdaspeed platform. So without further adieu, I present to you the Precision Bolt-on Turbo Kit for the Mazdaspeed 3
The kit includes the following.
Precision Turbo of your choice
cp-e LRT Manifold w/ Precision flange
Tial 44mm MVR Wastegate
Kozmic Precision Oil Feed Line
Kozmic Precision Oil Return Line
Kozmic non Water Cooled EGR Block off
V-Band Clamps for Precision Turbine inlet/outlet
Bolt to replace one of the manifold studs
Precision Ball-Bearing Turbo Kit - $3854.22
Precision Jounal Bearing Turbo Kit - $3254.22
Precision Turbo Kit V-Band Journal Bearing Turbo Mazdaspeed 6 2006-2007 - $3149.73
Precision Turbo Kit V-Band Ball Bearing Turbo Mazdaspeed 6 2006-2007 - $3749.73
Things to Note:
You have to do the Primary EGR Delete for this kit because the Precision Ported S Cover will interfere with the EGR valve as well as the lower driver side stud for the exhaust manifold. That is why we will be including a bolt, flat washer, and lock washer with the kit so you can replace the stud and not have any issues.
Special thanks goes out to @Hanzodurrr; as he was the first person to purchase this "kit" and was kind enough to let us use it for the pictures that we are now able to show you guys with.
As always, feel free to post up any questions or concerns you have and we will be happy to help!
The Following 61 Users Say Thank You to EdgeAutosport.com For This Useful Post:
ABloodBrother (03-07-2014), alaskazero (03-06-2014), Alpha (03-25-2014), Amnesiac (03-06-2014), amoosenamedhank (03-11-2014), anavrinIV (03-07-2014), ArcticSpeed3 (11-17-2014), beachshoer (03-06-2014), Boosted Beluga (03-06-2014), Boost_creep (03-06-2014), bstover17 (03-06-2014), BZiggy10 (03-07-2014), cld12pk2go (04-05-2014), cocoanton (01-01-2015), cshunter (03-06-2014), Cyclops (03-10-2014), Domino81 (03-06-2014), DSIT995 (03-06-2014), faeker (04-17-2014), Fail_6 (03-06-2014), Hammology (03-19-2014), Hanzodurrr (03-06-2014), hartlch (05-11-2014), hatchedspeed3 (03-07-2014), impossible (03-07-2014), ItsNox (03-10-2014), jkowalski (03-09-2014), josurr (04-07-2014), Justin@Freektune (03-06-2014), killer-ms3 (03-06-2014), LatinKraze (03-06-2014), Lex (03-06-2014), LumberJack (03-06-2014), magicka (03-06-2014), Mauro_Penguin (03-07-2014), Mazdalover01 (03-06-2014), Micha (03-06-2014), Mike@Stratified (03-06-2014), Mochi (03-10-2014), mr_mazda329 (03-06-2014), ms3blackmica (03-06-2014), mtnrunner (03-06-2014), Nliiitend1 (03-06-2014), NoRegrets (03-06-2014), obijack (03-06-2014), PapaSmurf (03-07-2014), Poohster (03-06-2014), Pu Manchu (03-07-2014), RdotQelo (03-06-2014), Realgib3 (03-07-2014), RichieRichness (03-07-2014), RobT2009 (03-07-2014), SamiChicago (06-25-2014), SC08Speed3 (03-07-2014), Sterling (04-07-2014), The Panda (03-06-2014), Tokay444 (03-06-2014), trancehead (03-07-2014), Vader (03-06-2014), wake2011 (03-06-2014), WetzMS3 (03-06-2014)
 Old 03-06-2014, 10:38 AM   #2
Hanzodurrr's Avatar
Posts: 240   (View Stats)
Hanzodurrr is the leader of the worldHanzodurrr is the leader of the worldHanzodurrr is the leader of the worldHanzodurrr is the leader of the worldHanzodurrr is the leader of the worldHanzodurrr is the leader of the worldHanzodurrr is the leader of the worldHanzodurrr is the leader of the worldHanzodurrr is the leader of the worldHanzodurrr is the leader of the worldHanzodurrr is the leader of the world
Now I got a turboner thanks
Note 2 Tappin
JBR Wrinkly Black Dong//CX FMIC w/Wrinkle black piping//PPT Tune//Autotech HPFP//Corksport Springs//TWM Full Replacement//JBR 88tmm 88rmm 80pmm//JBR OCC//JBR EGR delete//JBR TIG//GFB 100% Rice to Air//TB bypass// Kozmic Vband DP//CP-E ExMani//PTE 5558//Stoptech Power Slots all around//Stoptech SS lines//EBC Yellows//
BLEW UP AUG 2014
Aug 2015 SP63 Long Block coming soon!!!
Hanzodurrr is offline   Reply With Quote
The Following 6 Users Say Thank You to Hanzodurrr For This Useful Post:
Domino81 (03-06-2014), EdgeAutosport.com (03-06-2014), killer-ms3 (03-06-2014), LatinKraze (03-06-2014), Mochi (01-09-2015), mr_mazda329 (03-06-2014)
 Old 03-10-2014, 11:17 AM   #3
xTRELLx's Avatar
Posts: 396   (View Stats)
xTRELLx is the leader of the worldxTRELLx is the leader of the worldxTRELLx is the leader of the worldxTRELLx is the leader of the worldxTRELLx is the leader of the worldxTRELLx is the leader of the worldxTRELLx is the leader of the worldxTRELLx is the leader of the worldxTRELLx is the leader of the worldxTRELLx is the leader of the worldxTRELLx is the leader of the world
Groaned at 27 Times in 14 Posts
Note 2 Tappin
What turbo u get?
Sent while fappin wit the Eskimos
xTRELLx is offline   Reply With Quote
 Old 03-10-2014, 11:19 AM   #4
Hanzodurrr's Avatar
Originally Posted by xTRELLx View Post
What turbo u get?
I got a 5558 . 82 ar. Here is me looking gay with it.uploadfromtaptalk1394471922152.jpg
Note 2 Tappin
BLEW UP AUG 2014
The Following 4 Users Say Thank You to Hanzodurrr For This Useful Post:
Bullet (03-10-2014), Easter Bunny (03-11-2014), mr_mazda329 (03-12-2014), SLOWHATCH (03-16-2014)
 Old 03-10-2014, 11:25 AM   #5
xTRELLx's Avatar
I got a 5558 . 82 ar. Here is me looking gay with it.Attachment 150916
Note 2 Tappin
Well that pisses me off. I got the 5558 also. Waiting for my parts to get in still. When I was going over the build with JP I saw that nobody else had it. You beat me to it. (insert angry face here)
 Old 03-10-2014, 11:26 AM   #6
Hanzodurrr's Avatar
Dam sorry man I ordered it all like the beginning of last month luckily they had one dp left.
Note 2 Tappin
BLEW UP AUG 2014
 Old 03-06-2014, 10:46 AM   #7
bstover17's Avatar
Posts: 586   (View Stats)
Groans: 228
This is making it very hard to decide on a turbo path....
Pending BNR s3 revision
Pending BNR S4 release
Tax sale on GTX3071
and now this.....
Bravo @EdgeAutosport.com;
2010 MAZDASPEED 3
The Following 2 Users Say Thank You to bstover17 For This Useful Post:
EdgeAutosport.com (03-06-2014), trancehead (03-07-2014)
 Old 03-06-2014, 10:48 AM   #8
Micha's Avatar
Posts: 3,436   (View Stats)
Get a dp for a 6 made and I will get this in a heartbeat.
I am slow again.
I modded it a little.
The Following 8 Users Say Thank You to Micha For This Useful Post:
Alpha (03-25-2014), cocoanton (05-02-2014), Downmented (03-08-2014), kbz0129 (07-11-2014), lilred (03-09-2014), SamiChicago (06-25-2014), stanley0910 (03-07-2014), The Panda (03-06-2014)
 Old 03-06-2014, 10:50 AM   #9
That is up to Kozmic, but I think they are just needing to get a MS6 in there so they can fab one up.
Bullet likes this.
Bullet (03-09-2014), cocoanton (05-02-2014), Micha (03-06-2014), mr_mazda329 (03-06-2014), stanley0910 (03-07-2014)
 Old 03-09-2014, 11:40 AM   #10
Bullet's Avatar
Posts: 78   (View Stats)
Bullet has a reputation beyond reputeBullet has a reputation beyond reputeBullet has a reputation beyond reputeBullet has a reputation beyond reputeBullet has a reputation beyond reputeBullet has a reputation beyond reputeBullet has a reputation beyond reputeBullet has a reputation beyond reputeBullet has a reputation beyond reputeBullet has a reputation beyond reputeBullet has a reputation beyond repute
Lol they can have one of mine
Bullet is offline   Reply With Quote
The Following User Says Thank You to Bullet For This Useful Post:
EdgeAutosport.com (03-10-2014)
 Old 03-06-2014, 01:34 PM   #11
mr_mazda329's Avatar
Posts: 798   (View Stats)
Groans: 55
Broner! Many skeets. Can't wait to help install this weekend.
97 Miata Daily Driver
The Following 2 Users Say Thank You to mr_mazda329 For This Useful Post:
EdgeAutosport.com (03-06-2014), LatinKraze (03-06-2014)
 Old 03-06-2014, 01:40 PM   #12
You guys make sure and take lots of install pics!
Domino81 (03-06-2014), Hanzodurrr (03-06-2014)
 Old 03-06-2014, 02:02 PM   #13
Deldran's Avatar
Posts: 3,139   (View Stats)
Groans: 118
Why are the turbo options so limited I would be more interested in a 5128 or 5130 cea
Not everyone with a 3 or 6 is looking for big power. those two turbos would be great track or ax turbos. quick spool and good top end
Damond Built Speed 6
 Old 03-06-2014, 02:10 PM   #14
Hanzodurrr's Avatar
Edge can get you anything you just have to call them.
Note 2 Tappin
BLEW UP AUG 2014
The Following 2 Users Say Thank You to Hanzodurrr For This Useful Post:
Domino81 (03-06-2014), Downmented (03-08-2014)
 Old 03-06-2014, 02:08 PM   #15
Misfit_S3's Avatar
Posts: 168   (View Stats)
Misfit_S3 is the leader of the worldMisfit_S3 is the leader of the worldMisfit_S3 is the leader of the worldMisfit_S3 is the leader of the worldMisfit_S3 is the leader of the worldMisfit_S3 is the leader of the worldMisfit_S3 is the leader of the worldMisfit_S3 is the leader of the worldMisfit_S3 is the leader of the worldMisfit_S3 is the leader of the worldMisfit_S3 is the leader of the world
Looks familiar @EdgeAutosport.com; lol This time next week I should have it bolted on and have the tuning process going.
Precision 5858 Kit / CP-e FMIC / HKS SSQV / JBR RMM / JRB Trans Mount / JBR EGR Blockoff / JBR OCC / NGK's / Ultimate Racing CBE / Swift Springs / 18x8.5 Enkei Raijin with 245/40/18 NT05
Misfit_S3 is offline   Reply With Quote
 Old 03-06-2014, 02:51 PM   #16
jbr makes fall-a-parts.
Tokay444's Avatar
Posts: 13,163   (View Stats)
Groans: 793
Is the manifold flange for the TiAL hotside and precision hotside the same and just the dp flange differs? Or are there three different cpe mani's?
"Exclusivity" - CP-enis
Demodded.
The Seals
Easter Bunny (03-07-2014), Mauro_Penguin (03-07-2014)
 Old 03-06-2014, 02:58 PM   #17
2.0t03speed's Avatar
Posts: 1,302   (View Stats)
cp-e mani has 4 options :no flange, k04, tial, or precision
The Following 4 Users Say Thank You to 2.0t03speed For This Useful Post:
Easter Bunny (03-07-2014), EdgeAutosport.com (03-06-2014), Hanzodurrr (03-06-2014), Tokay444 (03-06-2014)
 Old 03-06-2014, 03:16 PM   #18
Those turbos don't have an option for the Vband turbine inlet and outlet and therefore won't work with the manifold or downpipe. The ones we have as options are the only ones that do have the vband turbine inlet/outlet.
It is different. The size is pretty similar but you can't fit one to the other. Also, placement for the downpipe will be slightly different due to the geometry of the different turbos.
Easter Bunny (03-07-2014), Mauro_Penguin (03-07-2014), Tokay444 (03-06-2014)
 Old 03-06-2014, 03:36 PM   #19
This is excellent to see made available!
I have a hard time finding a database of compressor or turbine maps for the Precision turbos. Are they available somewhere? This will really help in turbo selection.
EDIT: Looks like they don't release compressor maps which is a shame. We just have to go by "hp level"
Easter Bunny (03-07-2014), EdgeAutosport.com (03-06-2014), Mauro_Penguin (03-07-2014)
 Old 03-06-2014, 03:51 PM   #20
Nishan
ms3blackmica's Avatar
Posts: 5,635   (View Stats)
Nope.
No compressor maps for Precision turbos.
I've been using and working with Precision turbos for quite some time now on other platforms besides the Mazdaspeed and they are great turbos especially for the price.
If I were to do a Precision build on my MS3, my choice of parts would be no different.
www.tunedbynishan.com
The Following 10 Users Say Thank You to ms3blackmica For This Useful Post:
Domino81 (03-06-2014), Easter Bunny (03-07-2014), EdgeAutosport.com (03-06-2014), Hanzodurrr (03-06-2014), impossible (03-07-2014), Micha (05-31-2014), Realgib3 (03-07-2014), rfinkle2 (03-07-2014), SamiChicago (06-25-2014), The Panda (03-06-2014)
 Old 03-06-2014, 03:59 PM   #21
swsmailman's Avatar
Posts: 1,118   (View Stats)
Giggity Giggity Giggity.
I love that more kits are being made like this, really helps to just buy one thing instead of having to piece it all together.
2013 Liquid Silver MazdaSpeed
 Old 03-06-2014, 04:13 PM   #22
Misfit_S3's Avatar
Lol. Tell me about it. I pieced everything together last week but it was worth it. Nick spent days on the phone with me.
The Following User Says Thank You to Misfit_S3 For This Useful Post:
LumberJack (03-08-2014)
 Old 03-06-2014, 04:40 PM   #23
We are very excited about this kit! It just makes taking it to the next level so much easier. No more crazy custom stuff has to be done to run big power setups. Don't get me wrong, it isn't all rainbows and butterflies but it certainly takes a lot of the difficult work out. Plus, your engine will thank you for running such an efficient setup!
And @swsmailman;, you have the intake so you are all ready to go for a precision kit right?
altaprecision (03-10-2014), Justin@Freektune (03-07-2014), LumberJack (03-08-2014), swsmailman (03-07-2014), trancehead (03-07-2014)
 Old 03-07-2014, 08:19 AM   #24
swsmailman's Avatar
Why yes I do, I also have the EGR kits as well. Can I trade in a not even installed CPE DP for the Kozmic as well lol.
Someday, Someday.
 Old 03-07-2014, 06:56 AM   #25
RobT2009's Avatar
Posts: 108   (View Stats)
RobT2009 has a reputation beyond reputeRobT2009 has a reputation beyond reputeRobT2009 has a reputation beyond reputeRobT2009 has a reputation beyond reputeRobT2009 has a reputation beyond reputeRobT2009 has a reputation beyond reputeRobT2009 has a reputation beyond reputeRobT2009 has a reputation beyond reputeRobT2009 has a reputation beyond reputeRobT2009 has a reputation beyond reputeRobT2009 has a reputation beyond repute
Hopefully I can get this soon!
2008.5 CWP MazdaSpeed 3
SURE Aeros // SURE Sidewinder // Autotech Internals // CNT Catless DP - Catback // Custom FMIC // SURE TIG TB/IM // Denso ITV-22's // StreetUnit EGR Block Off // Turbosmart 50/50 // Streetunit RMM // SURE Oil Rig // BC Coilovers // RPF1 17x9 +45 // Nitto Motivo 255/40 // SURE AGS Heavy Weight Knob // JBR SSP// SURE Countershift // Shift Anchors // Cobb AP // Stoptech brake pads Powerslot rotors Stoptech SS lines //
RobT2009 is offline   Reply With Quote
The Following 2 Users Say Thank You to RobT2009 For This Useful Post:
EdgeAutosport.com (03-07-2014), Hanzodurrr (03-07-2014)
 Old 03-07-2014, 09:34 AM   #26
Found this and I checked a few HP ratings for these turbos that seem to correlate more or less with this chart
4447= 37 lbs/min
4747= 43 lbs/min
4947= 47 lbs/min
5147= 53 lbs/min
5152= ?? lbs/min
5347= 54 lbs/min
5356= 50 lbs/min
5362= 52 lbs/min
5558= 54 lbs/min
5562= 57 lbs/min
5565= 59 lbs/min
5857= 58 lbs/min
6062= 65 lbs/min
6065= 66 lbs/min
Somewhere around 43-45 lbs/min turbo is what you need for 400whp on high octane/E85 mix/meth.
SarcasticOne (03-10-2014)
 Old 03-07-2014, 09:41 AM   #27
Realgib3's Avatar
Posts: 2,443   (View Stats)
This is a great deal for a turbo kit. The Vband mani and precision turbo combination has been the most proven combo on this platform and I would (and have been for years) push anyone thinkin about goin BT, to go with Precision, ESPECIALLY since this kit just made it 10x easier to do so.
4447= 37 lbs/min
4747= 43 lbs/min
4947= 47 lbs/min
5147= 53 lbs/min
5152= ?? lbs/min
5347= 54 lbs/min
5356= 50 lbs/min
5362= 52 lbs/min
5558= 54 lbs/min
5562= 57 lbs/min
5565= 59 lbs/min
5857= 58 lbs/min
6062= 65 lbs/min
6065= 66 lbs/min
Those are entry level PTE's which I wouldn't think anyone would use for these builds. They come standard with E-covers and no vband in/out option for turbine housing iirc.
5858 = HTA3076 with slightly better spool and as much if not more top end
6262 = HTA3582
6266 = HTA 3586
6466 = league of its own (HTA3794 with much quicker spool and slightly less top end)
6766 = Super 94 HTA
6870 = Super 99 HTZ
Last edited by Realgib3; 03-07-2014 at 09:43 AM. Reason: MSF Database - Automerged Doublepost
The Following 12 Users Say Thank You to Realgib3 For This Useful Post:
802MS3 (03-13-2014), ABolewski (03-09-2014), Downmented (03-08-2014), EdgeAutosport.com (03-07-2014), hatchedspeed3 (03-07-2014), Justin@Freektune (03-09-2014), Mauro_Penguin (03-07-2014), Micha (03-07-2014), ms3blackmica (03-07-2014), PapaSmurf (03-07-2014), rfinkle2 (03-07-2014), SamiChicago (06-25-2014)
 Old 03-07-2014, 10:47 AM   #28
Nishan
On the money!
 Old 03-07-2014, 12:06 PM   #29
RichieRichness's Avatar
Posts: 3,314   (View Stats)
Groans: 35
Is the v-band hotside stainless like the Tial?
 Old 03-07-2014, 12:19 PM   #30
Misfit_S3's Avatar
I ended up going with the 5858 ball bearing so I have room to grow once I do a motor build. It seemed to be what I was looking for and it's as easy as a quick turbo swap if I want to go larger in the future. Can't wait until everything shows up. Pieces have slowly been trickling in.
The Following 2 Users Say Thank You to Misfit_S3 For This Useful Post:
Realgib3 (03-07-2014), SamiChicago (06-25-2014)
 Old 03-07-2014, 12:34 PM   #31
PapaSmurf's Avatar
Posts: 8,236   (View Stats)
whoever buys this and doesnt get a 6466 is wack! haha jk
This is honestly probably one of the best "kits" for the platform right now, along with being one of the cheapest options.
My new set up is basically this kit, subtracting a few items that I already had on the car that were made custom before it was an option to buy. Ill probably have to eventually buy the Kozmic downpipe, just want to make 100% sur emy current downpipe wont work.
860whp/677wtq
2.7 V6 Ecoboost
The Following 5 Users Say Thank You to PapaSmurf For This Useful Post:
Easter Bunny (03-07-2014), EdgeAutosport.com (03-07-2014), Misfit_S3 (03-07-2014), Realgib3 (03-07-2014), rfinkle2 (03-07-2014)
 Old 03-07-2014, 12:47 PM   #32
Realgib3's Avatar
Yep, outside of the custom DP I made, this is exactly what I'm running as well. And +1 for us 6466 guys.
The Following 4 Users Say Thank You to Realgib3 For This Useful Post:
EdgeAutosport.com (03-07-2014), killer-ms3 (03-10-2014), ms3blackmica (03-08-2014), PapaSmurf (03-08-2014)
 Old 03-08-2014, 11:24 PM   #33
Nishan
Wait till you hear it at full tilt.
You're going to think that a 747 just took off above your head.
Justin@Freektune likes this.
The Following 7 Users Say Thank You to ms3blackmica For This Useful Post:
Easter Bunny (03-11-2014), Justin@Freektune (03-09-2014), killer-ms3 (03-10-2014), LumberJack (03-08-2014), Micha (05-31-2014), Realgib3 (03-09-2014), SLOWHATCH (03-16-2014)
 Old 03-07-2014, 12:55 PM   #34
Misfit_S3's Avatar
Thanks @PapaSmurf; Now you've got me rethinking my turbo choice. Fuck it... 8285 and call it a day. Lmao
Hanzodurrr (03-07-2014), PapaSmurf (03-08-2014)
 Old 03-07-2014, 12:56 PM   #35
Hanzodurrr's Avatar
I'll be here with my 5558 looking like a little baby back bitch. Fml
Note 2 Tappin
BLEW UP AUG 2014
EdgeAutosport.com (03-07-2014), mr_mazda329 (03-12-2014)
 Old 03-07-2014, 02:15 PM   #36
SC08Speed3's Avatar
Posts: 298   (View Stats)
SC08Speed3 is the leader of the worldSC08Speed3 is the leader of the worldSC08Speed3 is the leader of the worldSC08Speed3 is the leader of the worldSC08Speed3 is the leader of the worldSC08Speed3 is the leader of the worldSC08Speed3 is the leader of the worldSC08Speed3 is the leader of the worldSC08Speed3 is the leader of the worldSC08Speed3 is the leader of the worldSC08Speed3 is the leader of the world
Is this turbo set-up rotated so just about any FMIC set-up can be run? or does it require some type of custom solution?
08 MGM Speed 3=SURE Rmm/ShortCut/Anchors/Return,COBB AP/SF/TIP,TurboSmart B.O.V,BC Coilovers/SWIFT Springs,SPC R.C.A, M2 DP, CNT CBE, Autotech Internals, SSP EGR Delete, DDM 6K
SC08Speed3 is offline   Reply With Quote
 Old 03-07-2014, 02:39 PM   #37
Misfit_S3's Avatar
I can't speak for this kit on a whole but I ordered some couplers to make it meet up with the cp-e hot side pipe for my FMIC. It's going to be some trial and error since its new to the market.
EdgeAutosport.com (03-07-2014), SC08Speed3 (03-10-2014)
 Old 03-07-2014, 04:14 PM   #38
Someday, Someday.
If its not installed and new in box we can do an exchange...
Its not rotated but due to the geometry of the precision turbo being different than the garrett based ATP turbos, there will probably need to be some different coupler combos to get it to fit with some intercooler setups.
darkstar5440 (03-12-2014), Easter Bunny (03-11-2014), SC08Speed3 (03-10-2014)
 Old 03-07-2014, 07:38 PM   #39
swsmailman's Avatar
Dang, no box, sitting on kitchen table, will be installed tomorrow though hahaha.
 Old 03-08-2014, 11:56 AM   #40
2012FailWheelDrive's Avatar
Posts: 327   (View Stats)
When you get it figured out post up some pics.
"under construction"
Kozmic Motorsports Precision V-band Downpipe at EdgeAutosport EdgeAutosport.com EdgeAutosport.com 22 02-17-2014 04:36 PM
Page generated in 0.91460 seconds with 40 queries
