| CTS Turbo CTS Turbo is your forced induction specialist for upgrades and tuning options |
| Approved MSF Vendor ![]() Join Date: Jun 2011
Rep Power: 136 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 6
(Thread Starter) | Not Ranked : 0 score We've got our Autotech fuel pumps in stock. All pre-orders have shipped and we still have some left. Check out our online store and enter promo code "mazdaspeed" when you check out for an additional $9.99 off. |
| The Following 7 Users Say Thank You to CTS Turbo For This Useful Post: | AJ713 (09-04-2011), AZSPEED3 (08-30-2011), dizzydtrain (09-02-2011), Docnox (09-27-2011), josurr (10-24-2011), rfinkle2 (08-30-2011), skeeter149 (08-31-2011) |
![]() Join Date: Mar 2010
Rep Power: 152 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 21
| Not Ranked : 0 score Damit I just bought a set last week. Help a brotha out. |
![]() Join Date: Apr 2010 Location: MD
Rep Power: 0 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 553
| Not Ranked : 0 score Now if I could only locate some moniez for internals
__________________ 2008.5 MGM Mazdaspeed 3 GT Cobb AP | cp-e SRI | cp-e TMIC | UR TP | cp-e RMM | JBR SSP | JBR Spherical Shift Knob | JBR RSB | Autotech HPFP | Spin-on |
![]() Join Date: Nov 2010 Location: South Haven, MI
Rep Power: 0 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 2,824
Groans: 75
| Not Ranked : 0 score Stupid buying a house, keeping me from all these great deals!
__________________ Franken Turbo, built motor, meth. DIY parts: Shift Knob, Shift Plate, Shift Bushings, Battery Tray, EBCS, RSB, probably more. "Your signature should just say, I'm the shit." -LynzeC |
![]() Join Date: Jan 2010 Location: Bentleyville, PA
Rep Power: 0 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 359
Groaned at 22 Times in 16 Posts
| Not Ranked : 0 score shit steel city being this weekend and needing to buy a copious amount of drugs/alcohol is really fucking me over...
__________________ ATP GTX3071r// Cobb 3 Port EBCS // 3 Bar MAP // Cobb Accessport Freek Tuned // E85 Mix // JBR 3.5" Intake/TIP // Treadstone TR8C FMIC // Autotech HPFP Internals // Ported IM //C-pe Catted Downpipe // TRZ RMM // Corksport CBE // ISC Coilovers // EBC Slotted Rotors--Redstuff Pads // TWM shifter bushings // Dashhawk v2 // 6000k HIDs Built engine--Manley H Beam Rods--Wiseco Pistons |
![]() Join Date: Nov 2009 Location: Tempe, AZ
Rep Power: 0 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 8,225
Groans: 65
| Not Ranked : 0 score Thanks for the deals. |
| The Following User Says Thank You to AZSPEED3 For This Useful Post: | CTS Turbo (09-06-2011) |
![]() Join Date: Jul 2010 Location: Mass
Rep Power: 0 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 52
| Not Ranked : 0 score Just ordered mine today, but did not see the promo code until after I ordered. |
![]() Join Date: Jul 2010 Location: Phenix City, Alabama
Rep Power: 2996 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 16,814
Groans: 451
| Not Ranked : 0 score Sites down... these guys are great though. Autotech FSI High Pressure Fuel Pump Upgrade Kit: CTS Turbo
__________________ 330whp/381ft/lb No Nitrous Meh 403whp/451ft/lb Dry Shot Last edited by Bucker; 09-02-2011 at 08:04 AM. Reason: MSF Database - Automerged Doublepost |
| The Following User Says Thank You to Bucker For This Useful Post: | CTS Turbo (09-06-2011) |
![]() Join Date: Apr 2011 Location: Weston, FL
Rep Power: 0 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 1,511
Groans: 39
__________________ 2011 MS3 / Fully Bolted / 290whp - 320wtrq ~ Sold 2010 Accord Coupe EX-L V6 ~ Current ~ K&N SRI / 4300k HIDs Last edited by G26; 09-04-2011 at 02:00 AM. | |
![]() Join Date: Feb 2011 Location: Rosemount, MN
Rep Power: 0 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 189
| Not Ranked : 0 score Are these still in stock??
__________________ New: 2012 Mazda MX5 Miata True Red |
| Not Ranked : 0 score Promo code not working +1 hey guys need to get this ordered ASAP @CTS Turbo
![]() Join Date: Dec 2009 Location: layton, UT
Rep Power: 0 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 122
| Not Ranked : 0 score bump... still in stock?
__________________ In progress: Engine: Built long block by Keefover. Keyed crank,keyed cams/VVT,Crower 65lb valve springs,Wiseco pistons,Manley H beam rods,AFI t3 stock location mani,Comp turbo CT4x 53-56,Kozmic 6th port PI with 2200cc bosch injectors,N2MB WOT box,Relentless ported intake mani,Kozmic oil feed line,Custom oil return line,Ramfab 3.5" intake,Ramfab alum. crash bar,Ramfab IC piping,TR10 IC,Saiko Michi and JBR dual custom catch can setup, Guardian angel v3 with 4bar map sensor,Dual Deatschwerks in-tank fuel hat with bigger pickup,-6an nylon braided fuel lines,Fuel labs FPR,SP63 3 port EBCS,Mishimoto oil cooler, HKS SSQV1,BSD,Autotech FP internals,CPE injector seals EGR delete,TB coolant bypass delete,M2 Ebay DP Suspenion/Bracing: Sonic tuning CO's revalved by Feal Suspension, QA1 600lb rear springs, 750lb front Swift springs,AWR front and rear sway bar endlinks,Whiteline RSB,SPC front adjustable ball joints,GT spec ladder brace,SU rear interior brace,NRG harness bar. Drivetrain:SS brake lines,SS clutch line,Carbotech ax6 F&R, Southbend STG 3 endurance clutch and flywheel,SU rear diff mount,SU front rear diff mount,SP63 TC caps,DSS rear axles,AWR Trilogy mounts 70A,Hubcentric centering rings,2" brake ducting F&R,TWM STS stg 1 with bushing kit Interior:Redline custom shift boot,Redline custom steering wheel cover,Redline custom ebrake handle cover Bride Stradia V.2 rep seats,Corbeau seat brackets,JBR heavy shift knob,Custom LED gauge cluster,Custom Steering column dual gauge pod,AEM wideband failsafe,AEM oil pressure gauge,Schrothe Rallye 4 harnesses,Escort 9500ix with mirror mount and hard wired with external controller,DIY ipod adapter. Exterior: STI front lip,Enkei PF01SS 17x9 +48 wrapped in Bridgestone Potenza RE-71R's 245/45/17,Full clear bra,Muteki SR48 blue locking lug nuts,RHO side plate mount,Smoked side markers, Shark fin antenna |
| Not Ranked : 0 score Ordered mine have to go to the last screen of paypal for the code to take off!! It works tho
![]() Join Date: Feb 2009 Location: Atlanta Ga
Rep Power: 0 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 1,123
| Not Ranked : 0 score still in stock, if so im surprised people should be yanking these up |
Groans: 39
| Neutral : +1 score Ordered some last night also, great deal, much better than $399! They will come back into work on Monday, and be like wtf all these mazdas buying up the internals.
__________________ 2011 MS3 / Fully Bolted / 290whp - 320wtrq ~ Sold 2010 Accord Coupe EX-L V6 ~ Current ~ K&N SRI / 4300k HIDs |
| Not Ranked : 0 score @G26 Have you gotten shipping info yet?
Groans: 39
__________________ 2011 MS3 / Fully Bolted / 290whp - 320wtrq ~ Sold 2010 Accord Coupe EX-L V6 ~ Current ~ K&N SRI / 4300k HIDs | |
| Not Ranked : 0 score Np
![]() | | #19 | ![]() |
| Not Ranked : 0 score Damn now I can't wait to have $$ for an AP been reading soooooo much
![]() | | #20 | ![]() |
![]() Join Date: Apr 2011 Location: Dallas, Texas
Rep Power: 0 ![]() ![]() ![]() ![]() ![]() Thanks: 19
| Not Ranked : 0 score Your online store link is not working... I want to order but cannot.
__________________ 2011 Velocity Red Mica Mazda Speed3 w/Tech package. Stage 1 Cobb AP, Corksport counter weight, SURE SRI, Corksport adjustable shiftplate, Ultimate Racing ABE (purely for the sound), Corksport springs, Black 18x8 Konig Deception wheels. |
![]() | | #21 | ![]() |
Groans: 451
__________________ 330whp/381ft/lb No Nitrous Meh 403whp/451ft/lb Dry Shot Last edited by Bucker; 09-05-2011 at 09:11 PM. Reason: MSF Database - Automerged Doublepost | |
![]() | | #22 | ![]() |
Groans: 39
| Not Ranked : 0 score Awesome service, autotechs shipped today.
| The Following User Says Thank You to G26 For This Useful Post: | CTS Turbo (09-06-2011) |
![]() | | #23 | ![]() |
![]() Join Date: Dec 2008 Location: Boston
Rep Power: 0 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 43
Groaned at 4 Times in 1 Post
| Not Ranked : 0 score I preordered these at the end of July (just got them in last week and installed over the weekend). Clay from CTS Turbo was extremely responsive to emails. He kept me up to date all the way through, thanks again! |
![]() | | #24 | ![]() |
(Thread Starter) | Not Ranked : 0 score Thanks for all the orders, guys! All pumps ordered over the long weekend shipped out today and tracking was sent to y'alls paypal accounts. Pumps are still in stock but going rather quick. Promo code does work but it won't show a discount until you proceed to paypal. If you have any issues with the promo code - just go ahead with the order and send me an email to nik@ctsturbo.com and I'll refund you the difference. Cheers, Nik |
| The Following User Says Thank You to CTS Turbo For This Useful Post: | Bucker (09-06-2011) |
![]() | | #25 | ![]() |
| Not Ranked : 0 score these work for 06 speed6s correct? im positive the pumps r the same jst makin sure
![]() | | #26 | ![]() |
![]() Join Date: Jul 2011 Location: Clarksville, TN
Rep Power: 0 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 27,279
![]() | | #27 | ![]() |
| Not Ranked : 0 score promo code does work but it doesnt work untill u check out with paypal. just ordered mne today excited to have it in the mailbox
![]() | | #28 | ![]() |
(Thread Starter) | Not Ranked : 0 score Thanks for the order. Pumps are still in stock, shipping daily. Also, if you guys are interested in ATP Turbo's products for your cars - shoot me an email: nik@ctsturbo.com |
![]() | | #29 | ![]() |
![]() | | #30 | ![]() |
(Thread Starter) | Not Ranked : 0 score Pumps are still in stock; more shipped out within last couple days so check your trackers, y'all. Holla! |
![]() | | #31 | ![]() |
| Banned ![]() Join Date: Nov 2009 Location: Los angeles,Ca
Rep Power: 0 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 65
Groaned at 14 Times in 6 Posts
| Not Ranked : 0 score Just ordered i hope they come in gods speed. |
![]() | | #32 | ![]() |
![]() | | #33 | ![]() |
![]() Join Date: Jul 2010 Location: Chicago IL
Rep Power: 0 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 135
Groaned at 7 Times in 3 Posts
| Not Ranked : 0 score just placed my order can't wait! |
![]() | | #34 | ![]() |
![]() Join Date: May 2011 Location: Chicago Illinois
Rep Power: 0 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 508
| Not Ranked : 0 score i bought my autotechs from cts turbo couple months back, great guys to do business with.
__________________ 2013 Velocity red Mazdaspeed 3 tech. BT 2011 Velocity red Mazdaspeed 3-SOLD. FreeKtuned fitty fitty |
![]() | | #35 | ![]() |
![]() Join Date: Jun 2009
| Not Ranked : 0 score Bump. Are pump internals still in stock? Is promo still available?
![]() | | #36 | ![]() |
| The Following User Says Thank You to CTS Turbo For This Useful Post: | AZSPEED3 (11-18-2011) |
![]() | | #37 | ![]() |
| Not Ranked : 0 score Thanks for prompt shipment. Got it today.
![]() | | #38 | ![]() |
![]() Join Date: Feb 2011 Location: Cheyenne, Wy
Rep Power: 0 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 2,031
| Not Ranked : 0 score Just got off the phone with Clay and he was extremely helpfuly. he is overnighting my internals for me and said they have alot in stock still with more on back order.
__________________ 2008 Silver Mazda 6s (AEM cai and jdm cbe) sold feb 2011 2008 Black Ms3 SOLD Vibrant CBE/custom straight test pipe/SURE AEROS SRI/short shifter/jbr chrome molly 88 duro dogbone rmm/rally armor mudflaps/MOTORCRAFT trans fluid/EBC Redstuff front pads/JBR short shift weight/JBR adjustable short shift plate @30%/autotech internals/MD OCC/ Prosport Evo Boost gauge with Vent Pod/NGK one step colder plugs AP Dizzy Tuned by BUCKER CorkSport Interior LED Kit 2015 STi Limited in Lightning Red Stock bottom end died at 18K hard canyon miles. Current Mods after build Forged High Performance CP Pistons, CP Rings, King Race Bearings, Manley H Beam Rods, 20g Turbo with 8cm Hotside, Cobb Performance Fuel Regulator, DW300c Intake pump, 1000cc Injectors, Cobb intake, Nameless 3" divorced catless DP, 3" MagnaFlow catback, Grimmspeed EBCS, SPT lower shift bushings, SPT short shifter, Diode Dynamics Boomerang kit, AP v3 Tuned by Justin@FreekTune [11:46 AM] wdawson4: now here is where i get expensive it takes atleast 250,000 to pound my butthole i cant sell that for cheap |
| The Following User Says Thank You to Ferg For This Useful Post: | Bucker (02-29-2012) |
![]() | | #39 | ![]() |
![]() Join Date: Feb 2011 Location: Princeton, WV
Rep Power: 0 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 1,469
Groaned at 61 Times in 40 Posts
| Not Ranked : 0 score Order placed! |
![]() | | #40 | ![]() |
![]() Join Date: Nov 2010 Location: Miami, Florida
Rep Power: 0 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 2,290
Groans: 43
| Not Ranked : 0 score Got mine coming! Ordered yesterday, shipped out today. THANKS!
__________________ [SIGPIC][/SIGPIC] “From a business standpoint, the Boss 302 shouldn’t have happened. But it happened. My dream for the car was that it would make a lot of money for a guy street racing. It should be a car that winds up on YouTube doing something illegal. I’ve been waiting 20-plus years to launch a car like this.”-Jim Farley |
LinkBack to this Thread: http://www.mazdaspeedforum.org/forum/forum/f563/cts-turbo-autotech-promo-90330/ | ||||
| CTS Turbo Autotech Promo Mazdaspeed Forums - Bookmarking.usrs0.com | This thread | Refback | 08-02-2015 10:29 AM | |
| Autotech Internals | PapaSmurf | 2010 MS3 - Fuel, Nitrous & Water Injection | 240 | 07-25-2012 10:59 AM |
| CTS Turbo - Autotech Internals NOW IN STOCK!! | Z3roFlaw | MazdaSpeed 3/6 - Fuel, Nitrous & Water Injection | 18 | 11-20-2011 05:23 AM |
| Anyone want in on Autotech internals? | OneBAMFpog | 2010 MS3 - Fuel, Nitrous & Water Injection | 545 | 09-30-2011 09:49 AM |
