 Old 05-06-2015, 03:52 PM   #1
Jkelley's Avatar
Posts: 218   (View Stats)
Jkelley is the leader of the worldJkelley is the leader of the worldJkelley is the leader of the worldJkelley is the leader of the worldJkelley is the leader of the worldJkelley is the leader of the worldJkelley is the leader of the worldJkelley is the leader of the worldJkelley is the leader of the worldJkelley is the leader of the worldJkelley is the leader of the world
Default ethanol analyzer
What's the best/ easy to use ethanol analyzer? If I want an exact E35 blend, how would one go about doing that since the pump e85 varies in ethanol and so does pump gas 91. Is there a way to analyze what's in the tank already also?
2008 Mazda Mazdaspeed3 GT (True Red) SOLD
~Mods: ATP GTX3071r IWG, JBR Tru 3.5" WP, UR V2 3" catless DP & TP, Tr8+JBR FMIC, Turbosmart BPV, CP-e HPFP, NGK 6510, Bosch 3bar MAP, Cobb 3-port EBCS, PERM PCV Plate, Damond OCC (1sealed, 1 VTA), Kozmic 1°/Damond 2° EGR Delete, Corksport seals, CP-e RMM 75A, JBR side MM 80A, Cobb AP V2, spin-on oil conversion, KSport Coilovers, SPC Performance Camber Arms, JBR IM/TB TIG, SURE Anchors
~~332whp @5300rpm / 354wtq @4800rpm @ 21psi on 91oct FREEKTUNED
~~380whp @6500rpm / 367wtq @4800rpm @ 20psi on e33 FREEKTUNED
2007 Mazda CX-7 (Burgundy Wine) SOLD
Jkelley is offline   Reply With Quote
 Old 05-06-2015, 03:55 PM   #2
Enki's Avatar
Posts: 7,541   (View Stats)
Enki has disabled reputation
Not sure why you'd want to be that precise; the ecu will compensate for quite a bit more than 5-10% ethanol variance and will show up in the logs/trims as such. From there you can adjust the scalars, assuming your calibration is close to spot on.
Agent_Orange (05-09-2015), Jkelley (05-07-2015), littleloogy (05-06-2015)
 Old 05-07-2015, 11:41 AM   #3
Jkelley's Avatar
Only because I don't even have the basic knowledge about tuning. My car is being tuned by Cobb and they seem quite anal about the percentage of ethanol.
 Old 05-09-2015, 11:30 AM   #4
MSP6's Avatar
Posts: 1,246   (View Stats)
They need to know in order to scale your fuel trims right, as well as to know where your cars knock threshold will be. But, like @Enki; said, as long as you give them what you filled up with, it won't matter if its E35 or E42 or E30.2 etc etc etc etc etc...
Tell them "I filled it from empty to full with 4 gallons of E and 10 of 91/93 whatever. Variances in E % are seasonal more than batch to batch. i.e it will switch from E85ish to E70ish sometime in the fall, then back to E85 sometime in the spring due to cold weather issues with the %. Day to day, week to week its not going to vary a whole lot.
The Following User Says Thank You to MSP6 For This Useful Post:
Jkelley (05-12-2015)
 Old 05-09-2015, 12:53 PM   #5
Fuck sushi rolls
rodrigo's Avatar
Posts: 18,719   (View Stats)
Groans: 356
from someone that analyzes that shit in a lab and its effects i am told 5% difference in purity dont change shit ....
and as i talk to more tuners (5.0 world ) they are all starting to change their "tune" towards that as well , even though couple years ago everyone was about the tester the tester lol
 Old 08-23-2015, 09:02 AM   #6
davychronic's Avatar
Posts: 1,155   (View Stats)
davychronic is the leader of the worlddavychronic is the leader of the worlddavychronic is the leader of the worlddavychronic is the leader of the worlddavychronic is the leader of the worlddavychronic is the leader of the worlddavychronic is the leader of the worlddavychronic is the leader of the worlddavychronic is the leader of the worlddavychronic is the leader of the worlddavychronic is the leader of the world
http://www.zeitronix.com/Products/ECA/ECA.shtml
Install after rail on return to hpfp
06 MS6 GT Titanium Gray II Metallic
davychronic is offline   Reply With Quote
e85 Ethanol Content Analyzer SPEED6 KILLAH MazdaSpeed 3/6 - Fuel, Nitrous & Water Injection 1 06-03-2013 03:46 PM
Gas no ethanol gfather Mazdaspeed3/6 General Discussion 14 06-28-2012 11:28 PM
Ethanol seanmiller09 Mazdaspeed3/6 General Discussion 8 12-13-2010 09:56 PM
Ethanol in gas countzero2k9 2010 MS3 - Troubleshoot/Diagnostics 9 06-22-2010 02:09 PM
Ethanol from almost anything? Coskata opens Lighthouse cellulosic ethanol plant Haltech Automotive News 0 10-18-2009 11:20 AM
Page generated in 0.26168 seconds with 24 queries
