 Old 11-09-2015, 09:28 AM   #1
SPEEDO90's Avatar
Posts: 79   (View Stats)
SPEEDO90 is a jewel in the roughSPEEDO90 is a jewel in the roughSPEEDO90 is a jewel in the roughSPEEDO90 is a jewel in the rough
Groaned at 9 Times in 5 Posts
Default help!
getting lean code on my ms3 after switch back to 93 from full E85 tune! car is acting funny =( could it be that it will go back to normal once all the e85 is flushed out of the tank? i flashed back to factory map btw PLEASE HELP IM FREKING OUT no ZZB MADA GODS PLEASE!!!
SPEEDO90 is offline   Reply With Quote
 Old 11-09-2015, 09:40 AM   #2
littleloogy's Avatar
Posts: 4,005   (View Stats)
Default How to e85
How much 93 did you put in your tank when you topped it off?
Edit: You really should step down slowly from the E Train. Use @Enki; fuel mix sheets and reflash with the scalers of a 30% E mix. Then the next fill up you should be able to go back to stock.
 Old 11-09-2015, 09:43 AM   #3
SPEEDO90's Avatar
i put about 8 gallons of 93. but i was already empty on full E85 i had one line and gas light light was on
 Old 11-09-2015, 09:46 AM   #4
Yeah you still had at least 4 gallons of E in your tank. you now have higher concentration of E then your fuel trims can handle. You need to reflash to at least a 30% mix. And then you will be okay.
 Old 11-09-2015, 09:49 AM   #5
SPEEDO90's Avatar
shit man thats the problem..... i have no AP now so im stuck running my car like this until empty............. will that be okay if i just drive like a granny? no WOT?
 Old 11-09-2015, 09:54 AM   #6
created your own thread.
 Old 11-09-2015, 09:56 AM   #7
Gr8Speed's Avatar
Posts: 5,702   (View Stats)
Top the damn tank off when you get down to 3/4 tank. Then when you do it again. It'll work itself out. No, driving like a granny will not make your fuel scalar change. Lean is lean.
SPEEDO90 (11-09-2015)
 Old 11-09-2015, 09:59 AM   #8
SPEEDO90's Avatar
thanks man i will do that im sorry for posting here. i hope i dont zzb driving around like this
 Old 11-09-2015, 10:03 AM   #9
You done fucked up, that a lot of E for a stock tune. Drive it like miss daisy would want you to... Or
You can pump the fuel out of your tank into a fuel jug, then replace the fuel with more fresh 93. That will dilute it. The more you dilute the richer your trims will get.
Or you can put on a smaller intake. That will make you run richer....
Or put your boxers in your AirBox, that will also help.
You moved a bunch of posts and made me look like a jackass in the other one lol. Well played Sir...
Last edited by littleloogy; 11-09-2015 at 10:03 AM. Reason: MSF Database - Automerged Doublepost
 Old 11-09-2015, 10:09 AM   #10
SPEEDO90's Avatar
How did i make you look like a Jack ass you are helping me and know what your talking about! Should i have created my own thread? No one has used that one since 2014 lol
 Old 11-09-2015, 10:11 AM   #11
A mod moved your posts to a new thread. I was giving him a hard time because it looked like I bumped a 2 year old thread lol. That comment was not meant for you, hints the quote.
 Old 11-09-2015, 10:18 AM   #12
SPEEDO90's Avatar
Ahhh got it hahaha
Page generated in 0.32926 seconds with 22 queries
