Like Tree40Likes
 Old 12-03-2011, 01:10 PM   #1
Jkelley's Avatar
Posts: 218   (View Stats)
Jkelley is the leader of the worldJkelley is the leader of the worldJkelley is the leader of the worldJkelley is the leader of the worldJkelley is the leader of the worldJkelley is the leader of the worldJkelley is the leader of the worldJkelley is the leader of the worldJkelley is the leader of the worldJkelley is the leader of the worldJkelley is the leader of the world
Default How to e85
Steps? New fuel lines? Bigger injectors?
2008 Mazda Mazdaspeed3 GT (True Red) SOLD
~Mods: ATP GTX3071r IWG, JBR Tru 3.5" WP, UR V2 3" catless DP & TP, Tr8+JBR FMIC, Turbosmart BPV, CP-e HPFP, NGK 6510, Bosch 3bar MAP, Cobb 3-port EBCS, PERM PCV Plate, Damond OCC (1sealed, 1 VTA), Kozmic 1°/Damond 2° EGR Delete, Corksport seals, CP-e RMM 75A, JBR side MM 80A, Cobb AP V2, spin-on oil conversion, KSport Coilovers, SPC Performance Camber Arms, JBR IM/TB TIG, SURE Anchors
~~332whp @5300rpm / 354wtq @4800rpm @ 21psi on 91oct FREEKTUNED
~~380whp @6500rpm / 367wtq @4800rpm @ 20psi on e33 FREEKTUNED
2007 Mazda CX-7 (Burgundy Wine) SOLD
Jkelley is offline   Reply With Quote
 Old 12-03-2011, 01:27 PM   #2
silvapain's Avatar
Posts: 6,665   (View Stats)
Groans: 136
No need for new fuel lines, and bigger injectors aren't available.
Going E85 requires only three things:
1. An upgraded HPFP or internals.
2. A COBB AP and either reading up on E85 diaries on here or working with other guys making tunes on 100% E85 (@phate and myself).
3. A set of brass balls. E85 on this platform is still new and isn't completely sorted out yet. You may run into hardware issues with the HPFP getting clogged or other issues.
This isn't an OTS bolt-on option just yet.
LowFlyin likes this.
The Following 15 Users Say Thank You to silvapain For This Useful Post:
AZSPEED3 (12-03-2011), BobbleHead (11-10-2012), dead-zone (09-08-2012), GLORIFIEDBOZO (12-05-2011), jracer (01-14-2012), kritz (12-03-2011), mazdafreak (06-22-2012), Menace1 (03-23-2013), phate (12-03-2011), sadak (11-03-2013), Speed_j23 (12-03-2011), symkaz (12-03-2011), twincitySPEED6 (03-20-2014), wallenberg (11-08-2012), Z32_MS3 (04-07-2014)
 Old 12-03-2011, 01:42 PM   #3
Eth Fiend
phate's Avatar
Posts: 6,947   (View Stats)
3a should read: If you encounter problems, massive patience required.
But seriously, a tune is probably the most important aspect. If you just up and switch without tuning, you will likely fuck something up. You will lose power, and your car will hate you.
Secondly, if your car has a lot of miles, run some seafoam through the gas for a tank or two before making the switch.
Lastly, there is support here. Us E85'ers want nothing more than to see others who have the desire to succeed. The power gains on E85 are stupid. My recommended mod list goes something like this now: AP, E85, proper tune, who the fuck cares that's solid power already.
-06 MS6
-Corn fed 07 MS3 - Sold
The Following 19 Users Say Thank You to phate For This Useful Post:
ABolewski (03-03-2013), atvfreek (12-03-2011), AZSPEED3 (12-03-2011), Bucker (12-03-2011), danieldolina70 (06-16-2012), Downmented (12-21-2011), Familyguy427 (02-07-2013), GLORIFIEDBOZO (12-05-2011), jracer (01-14-2012), kritz (12-03-2011), mazdafreak (06-22-2012), Menace1 (03-23-2013), ms6mil (06-19-2013), NinjaT1985 (12-03-2011), sadak (11-03-2013), SamiChicago (10-09-2013), silvapain (12-03-2011), Speed_j23 (12-03-2011), Twofer (02-15-2013)
 Old 12-03-2011, 03:36 PM   #4
kritz's Avatar
Posts: 7,290   (View Stats)
Groans: 95
Be forewarned that this equation applies e85+MS3=Moar power.
Nator is what it does.
The Following 3 Users Say Thank You to kritz For This Useful Post:
Bucker (12-03-2011), danieldolina70 (06-16-2012), LiEast (12-03-2011)
 Old 12-03-2011, 04:28 PM   #5
Jkelley's Avatar
So with my setup listed with the mods I have, I just need to retune?
Thanks for all your input guys... Also, with my mods.. Would I just fill her up with e85? Or do I go half and half or what?
Last edited by Jkelley; 12-03-2011 at 04:28 PM. Reason: MSF Database - Automerged Doublepost
 Old 12-03-2011, 04:29 PM   #6
Bucker's Avatar
Posts: 2,856   (View Stats)
Groans: 451
Yessir!
403whp/451ft/lb Dry Shot
 Old 12-03-2011, 04:44 PM   #7
Jkelley's Avatar
Originally Posted by Bucker View Post
Yessir!
Fill up fully on e85 for my very first time? Or mix? Sorry I didn't know which one you were saying yes to
TX06Speed6 likes this.
 Old 12-03-2011, 04:46 PM   #8
Bucker's Avatar
Groans: 451
Neutral  -1 score
Haha, replied via email.
My only hesitation before anyone jumps in is ensuring they know potential side effects
Before just filling it up a MAF scale should be done. 100% e85 will move your fueling like 30%, so thats a big change.
 Old 12-03-2011, 06:02 PM   #9
Jkelley's Avatar
Wow.. And you can clean your hfpf correct? Like with sea foam?
 Old 12-03-2011, 06:14 PM   #10
MSFer87's Avatar
Posts: 1,162   (View Stats)
Groans: 83
Dude just do yourself a favor right now or prepare to rebuild your HPFP a couple times. Go ahead and read this (at least the majority so you have a rough idea what your getting yourself into) E85 Discussion - HPFP lubrication and Flow issues and congrats for considering this you are among a minority.
The Following 2 Users Say Thank You to MSFer87 For This Useful Post:
kritz (12-03-2011), silvapain (12-03-2011)
 Old 12-03-2011, 07:40 PM   #11
silvapain's Avatar
Groans: 136
Agreed on the side effects. Especially the issues we've been having lately with spill valves, and there is always the potential for a stuck injector.
My MAF had to be scaled up roughly 39%.
sharkyboost likes this.
Bucker (12-04-2011)
 Old 12-03-2011, 07:45 PM   #12
LiEast's Avatar
Posts: 582   (View Stats)
LiEast is the leader of the worldLiEast is the leader of the worldLiEast is the leader of the worldLiEast is the leader of the worldLiEast is the leader of the worldLiEast is the leader of the worldLiEast is the leader of the worldLiEast is the leader of the worldLiEast is the leader of the worldLiEast is the leader of the worldLiEast is the leader of the world
Any. One run into a problem of running out of gas and not being able to find E85? I've been looking around and last week this deff would have happened to me lol
2008 RED MS3 GT>>>T3 GT35R .82 A/R>>>Tial 44 EWG dumping>>>SteedSpeed T3 Mani>>>Built Motor
PERM!
LiEast is offline   Reply With Quote
 Old 12-03-2011, 07:53 PM   #13
JLee1469's Avatar
Posts: 1,195   (View Stats)
JLee1469 is the leader of the worldJLee1469 is the leader of the worldJLee1469 is the leader of the worldJLee1469 is the leader of the worldJLee1469 is the leader of the worldJLee1469 is the leader of the worldJLee1469 is the leader of the worldJLee1469 is the leader of the worldJLee1469 is the leader of the worldJLee1469 is the leader of the worldJLee1469 is the leader of the world
Groaned at 27 Times in 21 Posts
Yeah some prerequisite steps would be to have access to an E85 pump and/or have storage capabilities for it. Also make sure your car has no other issues whether it be CELs or anything mechanical. New set of tires wouldn't hurt either because you will lose traction in 3rd and possibly 4th.
JLee1469 is offline   Reply With Quote
The Following User Says Thank You to JLee1469 For This Useful Post:
Bucker (12-04-2011)
 Old 12-03-2011, 07:58 PM   #14
racingred's Avatar
Posts: 154   (View Stats)
racingred has a reputation beyond reputeracingred has a reputation beyond reputeracingred has a reputation beyond reputeracingred has a reputation beyond reputeracingred has a reputation beyond reputeracingred has a reputation beyond reputeracingred has a reputation beyond reputeracingred has a reputation beyond reputeracingred has a reputation beyond reputeracingred has a reputation beyond reputeracingred has a reputation beyond repute
I tell you...with all the work that I keenly follow by phate and the others, once the kinks are stored out, I will be jumping on. The only thing, us floridians need more E85! This involves something more than a gas tank at one or two gas stations that these stupid ass civics keep on gobbling up.
The Nut likes this.
2008 MAZDASPEED 3 METRO GREY SOLD
2009 BMW 335i STOCK FOR NOW
racingred is offline   Reply With Quote
The Following User Says Thank You to racingred For This Useful Post:
chuckms6 (01-14-2012)
 Old 12-03-2011, 08:11 PM   #15
Speed_j23's Avatar
Posts: 611   (View Stats)
Speed_j23 is the leader of the worldSpeed_j23 is the leader of the worldSpeed_j23 is the leader of the worldSpeed_j23 is the leader of the worldSpeed_j23 is the leader of the worldSpeed_j23 is the leader of the worldSpeed_j23 is the leader of the worldSpeed_j23 is the leader of the worldSpeed_j23 is the leader of the worldSpeed_j23 is the leader of the worldSpeed_j23 is the leader of the world
You should run at least one can of seafoam in tha gas tank prior to filling up the first tank and you should have a new map ready to flash when you fill up. If your planning to do 100% then you just go straight E-85 there's no need to slightly go up.
New: 06 WWP MS6
Old: 06 LPM MS6
Speed_j23 is offline   Reply With Quote
The Following 2 Users Say Thank You to Speed_j23 For This Useful Post:
Bucker (12-04-2011), phate (12-03-2011)
 Old 12-04-2011, 09:57 AM   #16
Jkelley's Avatar
Should I just do 1 can and gas tank? Sorry, I ask, because awhile a go I had a 2000 camaro that I seafoamed with 80k miles on it.. But I put half a can in engine oil crankcase, 1 in gas tank, and use the cleaner to clean out the TB. Needless to say it worked great but a couple weeks later, I predict that some of the gunk in the engine was loose and it got stuck underneath a lifter arm and caused my car to loose drastic power Nd make a clicking noise. After 10 mins of driving, it would loosen up and drive normal again, but I'd have to go through this a couple of times a week. Well now I'm the 2nd owner of the 08 ms3 I have now and it just made 62k. I don want the same problem.. But if I'm just to clean out the gas take, then I don't forsee that problem happening
 Old 12-04-2011, 10:10 AM   #17
Jkelley's Avatar
Sorry to double post. I prepare to just tune on a 50% e85 and 50% 91 for reliability purposes.
The Following 2 Users Say Thank You to Jkelley For This Useful Post:
Bucker (12-04-2011), SLOWHATCH (03-23-2013)
 Old 12-04-2011, 11:04 AM   #18
Speed_j23's Avatar
Yeah the seafoam in the gas tank is to clean out the gunk in the fuel system prior to E-85. After you finish the tank of seafoam you might want to pull your hpfp clean it and lube it before your first fill up. I didn't do that last step since I'm only running a 50/50 mix.
Now I have put seafoam in through the brake booster line twice and haven't had any problems, however that's a different topic.
New: 06 WWP MS6
Old: 06 LPM MS6
 Old 12-04-2011, 02:28 PM   #19
Jkelley's Avatar
Okay, I plan to seafoam the fuel tank once before my 50/50 mix, but I'm extremely hesitant to do crankcase in oil for 50-100 miles (sometimes i think it does more harm then good when breaking up all that gunk in the motor).
The Following User Says Thank You to Jkelley For This Useful Post:
Bucker (12-04-2011)
 Old 12-04-2011, 04:03 PM   #20
Speed_j23's Avatar
Check the how to section there's a great Write up on how to do it via the brake booster line. It's no suppose to stay in there that long you just put it it and drive the car like you stole it until there's no more white smoke coming out the exhaust; then it's time for an oil change. That's how I do it. I'm gonna probably do it again before my next oil change; btw i'm at 92K.
New: 06 WWP MS6
Old: 06 LPM MS6
 Old 12-04-2011, 10:33 PM   #21
Enki's Avatar
Posts: 7,541   (View Stats)
Enki has disabled reputation
If my experience is any indication, seafoam won't do shit to help with issues, but 50/50 mix will.
Edit: Disregard above; 50/50 doesn't clean shit.
littleloogy (01-06-2014)
 Old 12-21-2011, 10:01 AM   #22
Cdone's Avatar
Posts: 34   (View Stats)
Cdone is on a distinguished road
Groaned at 17 Times in 4 Posts
E85 is no joke Ive had it tuned on all my cars at least once or twice. And they all require generally the same attention. Either injectors, fuel rail, or retarding the timing. Just need to know the flow rate and stoich. And the gains are amazing.QUOTE=phate;1149460]3a should read: If you encounter problems, massive patience required.
Lastly, there is support here. Us E85'ers want nothing more than to see others who have the desire to succeed. The power gains on E85 are stupid. My recommended mod list goes something like this now: AP, E85, proper tune, who the fuck cares that's solid power already.[/QUOTE]
kritz likes this.
MODS:Cobb Ap stg 2 custom tune//Autotech internals//ETS TMIC// forge bpv//Cobb Sri//AMSOIL FILTER//HTP tip//3" cat less TBE//ngk ix//su boost//trz rmm.OIL CATCH// 9/5 e85
Appearance://20% tint// GUN METAL rims// blacked out tails and headlights//mud flaps//ez lip//red caliber//TIEN s tech
Cdone is offline   Reply With Quote
 Old 02-10-2012, 04:52 PM   #23
2k4_8's Avatar
Posts: 684   (View Stats)
2k4_8 is the leader of the world2k4_8 is the leader of the world2k4_8 is the leader of the world2k4_8 is the leader of the world2k4_8 is the leader of the world2k4_8 is the leader of the world2k4_8 is the leader of the world2k4_8 is the leader of the world2k4_8 is the leader of the world2k4_8 is the leader of the world2k4_8 is the leader of the world
Groans: 64
Groaned at 18 Times in 6 Posts
e85 discussion is mainly here...so here I am. I simply want to do this right. I am ordering AT FP internals, an AP, and a JBR RMM all at the same time. I want to switch to e47 and get a tune put on the car. I have read of all the gunk that is flushed into the HPFP and such. Being as my car has under 14k miles on it, will this likely be an issue? I will still run a can of sea foam, but I would rather not have to pull and rebuild the FP to clean it. Sorry, I have been around a while, but this concept is still new to the forum and even more new to me. I am somewhat leery of this, but I will have someone competent tune it so that I don't fuck anything up. I have a local E station, although there is only one in the area. One of my concerns is that I may have to occasionally fill with 91 if I go on a trip or something....and I read that switching back and forth is bad (it didn't say if that was just 100% E back to 91 or if it's ok if just just mix. Don't hesitate to point me somewhere where all this is readily available...I'm just fine with reading, just haven't found exactly what I need yet.
Game plan is as follows. Get parts next week. Install RMM, seafoam in tank and also seafoam motor at the same time since I will be due for an oil change. Install FP internals and marry AP, do maf cal. on next tank of fuel and start on an e-tune, get dyno tuned...plan for new tires? Is that pretty much how this all works?
TL;DR;NCE: See 2 lines above ---^
COBB AP, CPE STAGE 2 RMM, CS SRI/TIP, AT HPFP INTERNALS, CNT CATTED DP, CP-E TRITON, JBR RSB, SWIFT SPRINGS, CS CAMBER ARMS
2k4_8 is offline   Reply With Quote
 Old 02-10-2012, 05:29 PM   #24
Eth Fiend
phate's Avatar
Mixes typically don't have the problems we see with full E85, while still gaining a ton of power. I don't think you have much to worry about. I've switched back and forth between 93 and straight E85 numerous times without issue, so I'm not sure who's spreading that bad information
You pretty much have the process down - My process for E-Tuning mix cars is:
1) set up base map with scaled MAF curve for E85 and lots of other fun tweaks
2) MAF cal
3) POWA!!!!! from E-Tuning over a few revisions until street tuning becomes a liability.
4) Dyno time for more POWA!!!! safely
-06 MS6
Speed_j23 (02-10-2012), Twofer (02-15-2013)
 Old 02-10-2012, 06:19 PM   #25
2k4_8's Avatar
Groans: 64
2) MAF cal
Good, I am glad to know I am not running in blind...thanks for the response. I'll try to find that post or thread I read that on though.
 Old 06-01-2012, 10:05 PM   #26
buckeyepost's Avatar
Posts: 295   (View Stats)
buckeyepost has a reputation beyond reputebuckeyepost has a reputation beyond reputebuckeyepost has a reputation beyond reputebuckeyepost has a reputation beyond reputebuckeyepost has a reputation beyond reputebuckeyepost has a reputation beyond reputebuckeyepost has a reputation beyond reputebuckeyepost has a reputation beyond reputebuckeyepost has a reputation beyond reputebuckeyepost has a reputation beyond reputebuckeyepost has a reputation beyond repute
I want on the sauce too... reeeeal bad! I'm all itchy...
07 MS3 GT {DD} \\ 295whp 328wtq (pre E mix) \\ Cobb AP {Stage 2} \\ MS CAI & CBE \\ ATP DP/MP {catless} \\ Corksport TMIC \\ SURE TIH \\ TurboSmart Kompact BPV \\ AutoTech FP internals \\ Denso ITV22's \\ SU RMM \\ Ralco STS\\ Hawk HPS pads \\ StopTech rotors \\ Sensen dampers \\ Moog swaybar links \\ DashHawk \\ 225/45 Kuhmo Ecsta XS's on 18x7.5 Momo S-five's \\ 205/60-16 Dunlop Winter Sport 3D's on steelies
1:3 E85 mix Dizzy tuned by Boost_creep
...... sold :-(
buckeyepost is offline   Reply With Quote
 Old 06-01-2012, 10:47 PM   #27
Enki's Avatar
Neutral  +1 score
I think the itching has more to do with hygiene and less to do with corn.
Just sayin'.
buckeyepost (06-03-2012), phate (06-08-2012)
 Old 06-16-2012, 12:41 PM   #28
Cdone's Avatar
What is the max ppl have increased their timing? Right now I'm increased only 1degree. Obviously knock isn't an issue, but I want to make more power and have experience tuning for corn before, and was able to increase ten degrees on my ion redline/cobalt ss.
 Old 06-16-2012, 12:51 PM   #29
Enki's Avatar
Um...Lol?
It's different every car. Either get an e-tune, pro tune or man up and find MBT yourself.
The Following 5 Users Say Thank You to Enki For This Useful Post:
atvfreek (06-17-2012), Black Metal (06-16-2012), m249saw (06-16-2012), phate (06-16-2012), Speed_j23 (06-16-2012)
 Old 06-17-2012, 05:18 PM   #30
Cdone's Avatar
Mbt? Manual boost tuning idk
The Following User Says Thank You to Cdone For This Useful Post:
3dpilot (06-18-2012)
 Old 06-17-2012, 05:19 PM   #31
silvapain's Avatar
Groans: 136
Originally Posted by Cdone View Post
Mbt?
Mui big testicles.
Tapadatass
The Following 4 Users Say Thank You to silvapain For This Useful Post:
atvfreek (06-17-2012), DoMiNic (06-19-2013), Easter Bunny (08-17-2012), xhymer (06-22-2012)
 Old 06-17-2012, 05:21 PM   #32
Cdone's Avatar
^thought so..
 Old 06-22-2012, 11:16 AM   #33
shadesofgray19's Avatar
Posts: 794   (View Stats)
Now that ATR has a scaler we should use that instead of adjusting MAF cal for E85 correct? I'm running equivalent E20 and changed and increased my MAF by 6%. I think I should undo that and just use the scalers.
 Old 06-22-2012, 03:12 PM   #34
Speeden6's Avatar
Posts: 598   (View Stats)
Speeden6 is the leader of the worldSpeeden6 is the leader of the worldSpeeden6 is the leader of the worldSpeeden6 is the leader of the worldSpeeden6 is the leader of the worldSpeeden6 is the leader of the worldSpeeden6 is the leader of the worldSpeeden6 is the leader of the worldSpeeden6 is the leader of the worldSpeeden6 is the leader of the worldSpeeden6 is the leader of the world
well, i am slowly stepping into the E85 ring, figure ill go there before I go BT and see if it makes me happy.
Seafoamed a couple tanks (higher millage car) new HPFP internals (autotechs about a month old) and have a light tune. just started with 3 Gallons on top of 91 oct full tank to see what if anything it does for me.
any words of advice asside form above and waching fuel rail and pressures? should I ease into E85 by running it a couple times 3 gal to full tank or go straight 50/50? its more spendy out here than 91OCT and hard to get so i dont want to rely on full E85.
If i go 50/50 with VS 3gal to the tank what is the difference? really noticeable?
2007 MS6 -
CPE TMIC, CS HPFP Internals, CS Stage 2 Intake and Inlet, Turbo Smart 50/50 BPV / BOV, Catless DP
2006 Acura TL Fully bolted and Running Nitrous! 330WHP SOLD
SOLD 1992 Corrado VR6
268 Cams, air intake, cat back, upgrade plugs and wires, coilovers.
SOLD
2001 Audi Allroad
SOLD
2006 MS6 -
CAI, TIP, ETS TMIC, AutoTech Internals, TBE catless, E85 30%,
19PSI, Cobb AP, RMM, K04, HKS SSQ4 VTA,
TUNED BY LEX FOR 330 AWHP / 380 TQ
Custom tune by
The habits we form today are the ones that Define us tomorrow
Speeden6 is offline   Reply With Quote
 Old 06-22-2012, 03:35 PM   #35
kritz's Avatar
Groans: 95
Yes, there will be a difference as long as the tune you will load has moar timing added like 18>19.5 degrees or so. The torque will spin your tires in 3rd with no effort at all and fourth is a monster. Enjoy
 Old 06-22-2012, 08:25 PM   #36
silvapain's Avatar
Groans: 136
We still don't have a ton of data with different mixes and mod combos, but it seems that big gains can be had up until about 50/50 or so, then the incremental benefits drop off. For example, the gains going from E50 to E85 aren't as big as going from E25 to E50.
Tapadatass
 Old 06-23-2012, 02:02 PM   #37
NoTraction's Avatar
Posts: 117   (View Stats)
NoTraction has a reputation beyond reputeNoTraction has a reputation beyond reputeNoTraction has a reputation beyond reputeNoTraction has a reputation beyond reputeNoTraction has a reputation beyond reputeNoTraction has a reputation beyond reputeNoTraction has a reputation beyond reputeNoTraction has a reputation beyond reputeNoTraction has a reputation beyond reputeNoTraction has a reputation beyond reputeNoTraction has a reputation beyond repute
Groaned at 8 Times in 4 Posts
Soon I will Join the e85 Crew!!! After I donate though and make some moar MONEY
GARAGE: 10' GTI(FS), 14' BRZ, 95' corolla, Z750s, klr250
07 Mazdaspeed3 #2 SOLD
HT tuner, RMM, CS SRI, Exhaust
Things I miss: Both my Speed3's of the past, Fz1, 2zz Mr2-s
Turbo s2k wanted...but in the mean time
NoTraction is offline   Reply With Quote
 Old 06-23-2012, 09:34 PM   #38
sallyspeed3's Avatar
Posts: 638   (View Stats)
sallyspeed3 is the leader of the worldsallyspeed3 is the leader of the worldsallyspeed3 is the leader of the worldsallyspeed3 is the leader of the worldsallyspeed3 is the leader of the worldsallyspeed3 is the leader of the worldsallyspeed3 is the leader of the worldsallyspeed3 is the leader of the worldsallyspeed3 is the leader of the worldsallyspeed3 is the leader of the worldsallyspeed3 is the leader of the world
Just joined the wagon. Put in 4 gallons which should put me between E30 and E40? Bucker will be tuning me and I can't wait. I filled up 3 containers with 4 gallons each and got the blue sta-bil ethanol treatment. Should be set for about a month before I need to get some more.
2008 Cosmic Blue Mazdaspeed 3 GT - COBB AP DIZZYTUNED for 30% E85//JBR Whale Penis//COBB TIP//COBB DP//COBB STS//COBB Knob//COBB shift weight//COBB Piping TR8L Core//Magnaflow CBE//Turbosmart BPV//PTP internals//SU RMM//TRZ tranny mount//Koni + H&R springs//Tinted 35% front, 20% rear//Lamin-X head-light & tail-light film//ASA GT1 18x8//Hankook Ventus V12 225/40//
sallyspeed3 is offline   Reply With Quote
 Old 06-24-2012, 08:22 PM   #39
Speeden6's Avatar
just finished my first full take of E85 mix (only 3 gal to a full tank). put on a map that would give me some 2-3 KR readings and now i get barely a blirp of 0.3 or 0.7 which has to be just engine bay noise.
tomorrow i am filling her up again with 4 Gal of E85 first then throwing in the 91 OCT for the rest and going to a more aggressive map. then going to work out the kinks and go FMIC and 50/50 mix. i have no problem being a guinea pig if people want me to run logs on my MS6 and share. have 92K mils and Mods Below. im gonna break 300 AWHP before the summer is over on bolt ons and E85 if it kills me!
2007 MS6 -
SOLD
2001 Audi Allroad
SOLD
2006 MS6 -
Custom tune by
 Old 06-25-2012, 04:22 PM   #40
Eth Fiend
phate's Avatar
Bolt ons beyond intake and downpipe are a waste with a K04 on E85, once properly tuned. Just go 5050, tune, and call it a day.
dead-zone likes this.
-06 MS6
Enki (06-25-2012), shawn. (06-26-2012)
LinkBack to this Thread: http://www.mazdaspeedforum.org/forum/forum/f567/how-e85-98590/
How to e85 mazdaspeed - 1Q5A This thread Refback 10-02-2014 07:27 AM
how to make a mazdaspeed 6 run on E85 This thread Refback 04-23-2013 10:54 AM
Page generated in 0.57293 seconds with 37 queries
