Like Tree10Likes
 Old 11-13-2011, 06:22 PM   #1
silvapain's Avatar
Posts: 6,665   (View Stats)
Groans: 136
Neutral  0 score
Default HOW TO: Remove & Disassemble HPFP Spill Valve
Tools:
1. 10mm socket and ratchet
2. 32mm combination wrench
3. medium-size standard (flat-head) screwdriver
Procedure:
1. Using the 10mm socket and ratchet, remove the two 10mm bolts that hold the shroud on over the TMIC and remove the shroud (if required).
2. Unplug electrical connector to the spill valve on the top of the HPFP.
3. Using the 32mm combination wrench, unscrew the spill valve from the HPFP housing.
4. Using the flat-head screwdriver, carefully pry up between the spill valve base and collar as seen below. Do this in steps, rotating the spill valve as you pry to pull the collar out evenly.
5. Carefully remove the collar, plunger, c-clip, and spring from the spill valve and clean.
Reinstallation:
For reinstallation, simply reassemble the collar, plunger, c-clip, and spring in the order it was pulled out of the spill valve, and press the collar back into the spill valve base. There is no need to press the collar all the way back in; when you screw the spill valve back into the HPFP, you will reseat the collar. Apply a bit of clean engine oil on the spill valve O-ring prior to putting the spill valve back into the HPFP. There is no need for any thread sealant, as the O-ring provides the seal.
NOTE: The electrical connector for the spill valve should be pointing straight towards the radiator when the spill valve is tightened all the way down. This can take a bit of force.
Livingframe and thatfoofez like this.
The Following 55 Users Say Thank You to silvapain For This Useful Post:
1stMS3 (06-27-2015), 802MS3 (12-23-2011), Andjo (07-27-2015), Arnie1229 (03-23-2015), BlueStreak (11-13-2011), burn813 (04-08-2012), Captain KR (11-13-2011), charlesfist (11-21-2011), Ckmazdaspeed3 (04-04-2012), cld12pk2go (11-19-2011), Dahouse702 (07-02-2012), daztdMS6 (01-19-2012), djuosnteisn (11-14-2011), dougefresh_ (12-13-2011), dsb_chicago (01-19-2013), eljefe62 (01-09-2013), Enki (11-13-2011), GLORIFIEDBOZO (11-15-2011), Grab21 (01-24-2012), hnda etr (02-02-2012), ItsNox (08-25-2014), JLee1469 (11-14-2011), kritz (11-14-2011), LatinKraze (12-19-2012), Livingframe (04-14-2015), MD1032 (05-06-2015), meicalnissyen (05-05-2014), Menace1 (12-19-2012), Ms3_Miami (12-11-2012), Nataphen (11-17-2011), p057 (12-26-2011), peo (07-01-2017), phate (11-15-2011), Pointless (09-04-2012), psychophyr (09-04-2013), Raider (11-13-2011), rfinkle2 (11-23-2011), rghispanic88 (11-20-2011), Rokusek (01-14-2013), Sergeant_M (03-18-2014), SJP0tato (12-22-2011), skiptowncat (02-19-2012), spdtrux (12-14-2013), SpeedRebirth (01-07-2015), speed_freak91 (05-14-2014), SpencerC (08-13-2014), Spoolnak (05-27-2014), taf0422 (01-15-2013), tclegg (02-28-2016), Tifosi42 (03-22-2016), TiGraySpeed6 (12-28-2011), Tokay444 (11-22-2013), Vinnie (05-06-2012), WetzMS3 (10-07-2013), [R]usty (07-13-2015)
 Old 11-13-2011, 07:53 PM   #2
Enki's Avatar
Posts: 7,541   (View Stats)
Enki has disabled reputation
Thanks for this, as I have yet to break mine down and fully clean it. I'll be doing that tomorrow for sure.
phate (11-15-2011)
 Old 11-13-2011, 07:56 PM   #3
i8urgti's Avatar
Posts: 1,660   (View Stats)
i8urgti is the leader of the worldi8urgti is the leader of the worldi8urgti is the leader of the worldi8urgti is the leader of the worldi8urgti is the leader of the worldi8urgti is the leader of the worldi8urgti is the leader of the worldi8urgti is the leader of the worldi8urgti is the leader of the worldi8urgti is the leader of the worldi8urgti is the leader of the world
Groans: 267
what justifies needing to be replaced?
2006 LPM MS6 GT (totaled)
0-60 mph : 4.2 second (as per DH)
12.83 @ ???MPH 1.67 60ft
2002 Miata Se (convertible whore)
i8urgti is offline   Reply With Quote
The Following User Says Thank You to i8urgti For This Useful Post:
phate (11-15-2011)
 Old 11-13-2011, 07:59 PM   #4
Captain KR's Avatar
Posts: 2,320   (View Stats)
Captain KR is the leader of the worldCaptain KR is the leader of the worldCaptain KR is the leader of the worldCaptain KR is the leader of the worldCaptain KR is the leader of the worldCaptain KR is the leader of the worldCaptain KR is the leader of the worldCaptain KR is the leader of the worldCaptain KR is the leader of the worldCaptain KR is the leader of the worldCaptain KR is the leader of the world
Groans: 391
Groaned at 75 Times in 49 Posts
Great write up another great addition to the how to section.
moore automitive 4/13/13 515whp 511 tq
Mason Dixon Raceway 11.289 @125 1.845 60'
Killah Built
Powered By Purple Drank
Captain KR is offline   Reply With Quote
 Old 11-13-2011, 08:14 PM   #5
silvapain's Avatar
Groans: 136
There's no replacement necessary; I have to take mine apart and clean it frequently due to going to 100% E85.
James3Malnar likes this.
i8urgti (11-14-2011)
 Old 11-13-2011, 08:24 PM   #6
Enki's Avatar
If it's clean and doesn't work, it's probably a bad coil and thus would need replacing.
i8urgti (11-14-2011), kritz (11-14-2011), silvapain (11-13-2011)
 Old 11-13-2011, 08:28 PM   #7
silvapain's Avatar
Groans: 136
I have found that smacking it with a mini maglite with judicious aggression will free it up if it sticks.
The Following 5 Users Say Thank You to silvapain For This Useful Post:
atvfreek (11-19-2011), djuosnteisn (11-14-2011), littleloogy (01-11-2014), rfinkle2 (05-28-2013), Sergeant_M (03-18-2014)
 Old 11-14-2011, 09:39 AM   #8
Captain
djuosnteisn's Avatar
Posts: 11,480   (View Stats)
If a lil beating doesn't work... I'd try a gas can and matches.
500awhp 440awtq uncorrected
Check out the hair Salon:
www.permtuning.com
atvfreek (11-19-2011), rigor (11-20-2011), silvapain (11-14-2011), spoonher (12-14-2011), thehead (11-20-2011)
 Old 11-14-2011, 09:50 AM   #9
Thanks for the write-up.
kritz (11-14-2011), silvapain (11-14-2011)
 Old 11-14-2011, 09:51 AM   #10
silvapain's Avatar
Groans: 136
Glad I could copy something out of the shop manual for you.
Just messing with you Finkle.
Tapadatass
atvfreek (11-19-2011), rfinkle2 (11-14-2011)
 Old 11-14-2011, 09:51 AM   #11
Fatguy729's Avatar
Posts: 1,685   (View Stats)
Groans: 82
if e85 causes your fuel system to gum up, can't you just run a tank of gas to disolve that shit?
 Old 11-14-2011, 09:53 AM   #12
silvapain's Avatar
Groans: 136
By the way, the spill valve solenoid coil operates at 12VDC, so you can test the solenoid by wiring it up to the battery to test. The polarity does not matter.
Thanks to @phate for that information.
Tapadatass
jmhinkle (06-13-2014), phate (11-15-2011), rfinkle2 (05-28-2013)
 Old 11-14-2011, 09:55 AM   #13
silvapain's Avatar
Groans: 136
I wouldn't switch back and forth. The only hydrolocked engine I've heard of due to E85 testing was the result of an injector sticking open after the guy switched back to pump gas after running E85. That may be anecdotal, but I don't want to take that chance.
Tapadatass
phate (11-15-2011)
 Old 11-14-2011, 10:27 AM   #14
Enki's Avatar
if you are going to switch back, it would be best to do it in stages over time IMO. 100%, 75%, 50%, 25%, pump.
This way, if there ARE irregularities with fuel flow, you should have a lot of time to catch it before it becomes something serious.
kritz (11-14-2011), phate (11-15-2011)
 Old 11-14-2011, 10:33 AM   #15
Captain
Tapadatass
Is this really in the service manual? I've never seen it if it is..... i thought the service manual treated the hpfp as a "black box".
www.permtuning.com
i8urgti (11-15-2011), phate (11-15-2011), rfinkle2 (05-28-2013)
 Old 11-14-2011, 10:44 AM   #16
silvapain's Avatar
Groans: 136
The manual does treat the entire HPFP as one part. It states that if the spill valve fails, then replace the entire pump.
My comment is a joke in reference to Finkle's call out thread from the weekend.
Tapadatass
atvfreek (11-19-2011), djuosnteisn (11-14-2011), phate (11-15-2011)
 Old 11-14-2011, 11:02 AM   #17
Captain
Tapadatass
Gotchya....
<----- doesn't follow finkle drama lol.
www.permtuning.com
phate (11-15-2011)
 Old 11-15-2011, 10:43 PM   #18
Eth Fiend
phate's Avatar
Posts: 6,947   (View Stats)
From way back when I first took mine apart, lol:
http://www.youtube.com/watch?v=Fx0uA...ature=youtu.be
IDK why that won't embed. It just wants to be a link, I guess.
-06 MS6
-Corn fed 07 MS3 - Sold
rfinkle2 (11-19-2011)
 Old 11-15-2011, 10:51 PM   #19
Eth Fiend
phate's Avatar
You can twist the solenoid within the nut. You can take it out, as well. There is never any reason to do this, but here are some pics:
As promised, this is the spill valve solenoid taken even further apart. This pic shows the normal position of the solenoid in the background. The foreground picture shows how it pushes out just a little bit.
That little groove in the foreground solenoid is where the split ring lock sits. The split ring lock simply keeps the solenoid from pushing back through the sleeve. You can sorta see how the two halves should sit in that groove here:
Once the two lock halves are out, you just push the solenoid back through the sleeve (towards the connector end):
And that's about it. This is the sleeve. You can see where the O-ring on the solenoid sits:
Nothing spectacular, but I thought the overall design of the spill valve and solenoid is pretty neat.
From here: E85 Discussion - HPFP lubrication and Flow issues
-06 MS6
The Following 5 Users Say Thank You to phate For This Useful Post:
cld12pk2go (11-19-2011), djuosnteisn (11-16-2011), rfinkle2 (11-23-2011), rob ms6gt (04-05-2015), Vinnie (05-06-2012)
 Old 11-19-2011, 10:47 AM   #20
Eth/Meth Junkie
cld12pk2go's Avatar
Posts: 2,998   (View Stats)
Nice.
I was previously mis-understanding Phate's instructions, but this pic straightened me out and I cleaned mine up fully this morning as I had been having 2-3 excursions to RV lift pressure during pulls where as this used to be ~0 when targeting 1750PSI.
TBD if the issue is resolved.
Edit: On a side note, when did I go Orange?
phate (11-19-2011)
 Old 11-19-2011, 01:15 PM   #21
@cld12pk2go (I see your plaid request was declined) .. about a week ago.
Congratulations... it is long deserved.
phate (11-19-2011)
 Old 11-19-2011, 11:05 PM   #22
Eth/Meth Junkie
cld12pk2go's Avatar
Yeah, plaid would have ruled.
rfinkle2 (11-21-2011)
 Old 11-20-2011, 12:02 PM   #23
Etipp98's Avatar
Posts: 1,947   (View Stats)
Groaned at 7 Times in 4 Posts
Got mine apart and didnt even need cleaning oh well. I have piece of mind atleast now.
phate (11-20-2011)
 Old 11-20-2011, 04:35 PM   #24
silvapain's Avatar
Groans: 136
I pull my spill valve often as it sticks due to E85. Mine never has any signs of buildup or debris.
Tapadatass
 Old 11-20-2011, 04:39 PM   #25
laxplayermjd's Avatar
Posts: 779   (View Stats)
laxplayermjd is the leader of the worldlaxplayermjd is the leader of the worldlaxplayermjd is the leader of the worldlaxplayermjd is the leader of the worldlaxplayermjd is the leader of the worldlaxplayermjd is the leader of the worldlaxplayermjd is the leader of the worldlaxplayermjd is the leader of the worldlaxplayermjd is the leader of the worldlaxplayermjd is the leader of the worldlaxplayermjd is the leader of the world
what ever happened about running that inline fuel filter before the pump? i think it was phate but i havent seen anyone after him?
2007 Speed 6 Liquid Platinum Metallic, DIY Duplicolor Graphite Wheel Paint, Clutchmasters FX100, Stock again with 91 ots tune
laxplayermjd is offline   Reply With Quote
 Old 11-20-2011, 04:46 PM   #26
Eth Fiend
phate's Avatar
It hasn't been effective. @silvapain and I spoke about this briefly over the weekend, and we agree that it is likely the O-Ring in the 18mm nut that holds the internals. That's the O-Ring that seals the internals main piston shaft.
If you look at glorifiedbozo's thread, he hasn't had a single issue - so I think it's simply the condition of the O-Ring before we ever make the switch. The buildup was shown in a mass spec reading to contain oil additives...which have to come from oil...since the fuel system only has gas/E85, lol. I've seen straight gas cars with some black residue, but it is so easily dissolved in gas that it doesn't cause a problem. The Ethanol does not dissolve it as easily, hence the problem.
-06 MS6
djuosnteisn (01-15-2013), silvapain (11-20-2011)
 Old 11-20-2011, 04:47 PM   #27
silvapain's Avatar
Groans: 136
I have never run an inline filter on E85 FWIW.
Like @phate said, we believe it's oil seeping past the O-ring that goes around the pump piston. It's only building up on E85 because oil isn't miscible in alcohol.
Tapadatass
djuosnteisn (11-21-2011), phate (11-21-2011)
 Old 11-21-2011, 02:06 AM   #28
Enki's Avatar
There's two orings, and I doubt any of it is leaking past; if anything, fuel is pushing the oil out. I'm willing to bet that the residue is from coating the internals with oil before assembly; then again it is 2 am and my head is spinning.
 Old 11-21-2011, 09:19 AM   #29
Eth Fiend
phate's Avatar
No, I have reassembled my internals NUMEROUS times without oil (totally dry) and I still get the problem.
-06 MS6
 Old 11-21-2011, 03:43 PM   #30
if you guys think its the o ring, wouldnt it continue to happen over and over?
 Old 11-21-2011, 06:35 PM   #31
Eth Fiend
phate's Avatar
It does happen over and over, lol. I still deal with it.
I talked to Mazdaspeed Motorsports today, and they cannot get just the O-Ring or just the 18mm nut with the O-Ring in it. So it's a $300 venture to get a complete stock pump and test a brand new O-Ring. I'm willing to bet it would fix it, though.
-06 MS6
 Old 11-21-2011, 07:29 PM   #32
Enki's Avatar
There's got to be a source for a similar oring for what we need.
phate (11-21-2011)
 Old 11-21-2011, 08:12 PM   #33
i should be able to find one, im a tech so i have lots of spare o rings, ill just have to wait till xmas so ill have a spare stock pump i can take apart then search. If i find one that fits itll be easy as cake to order
The Following 2 Users Say Thank You to laxplayermjd For This Useful Post:
Enki (11-21-2011), rfinkle2 (11-22-2011)
 Old 11-21-2011, 08:33 PM   #34
Enki's Avatar
Lax, when Phate sends me his spare nut, I'll try to coax a ring out of mine with a pick or something and mic everything (including the piston/nut) to get you the info you need.
Livingframe likes this.
 Old 11-21-2011, 10:07 PM   #35
jroc's Avatar
Posts: 1,482   (View Stats)
was bored, took mine apart and cleaned it....everything was coated in a black soot like material. 81k miles on the odometer, never cleaned. just tossing that out there.
also, only took about 20 minutes from wrenching off to back on. that included some texts and facebooking and checking this to see how it went back together
JDMFresh.com 1990 Mazda Miata
The Following User Says Thank You to jroc For This Useful Post:
phate (11-21-2011)
 Old 11-21-2011, 10:27 PM   #36
Eth Fiend
phate's Avatar
Are you running ethanol? I can't keep track anymore, haha.
-06 MS6
 Old 11-21-2011, 11:25 PM   #37
Enki's Avatar
He's on 91, but looking to go to corn.
phate (11-21-2011)
 Old 11-22-2011, 05:27 AM   #38
silvapain's Avatar
Groans: 136
It comes out very easily with a jewelers screwdriver. I've pulled mine out before to inspect it.
It's not a normal toroidal O-ring. The edges are flattened, where the cross-section is square not circular.
Tapadatass
Enki (11-22-2011), rfinkle2 (11-22-2011)
 Old 11-22-2011, 07:09 AM   #39
Maybe you guys know of this place, maybe not:
Everything under the sun here (should have different material o-rings etc.)
McMaster-Carr
good service, pricing, and will allow you to order industrial supplies in low (e.g. 1) quantities.
Enki (11-22-2011), phate (11-22-2011), turboKart (02-07-2013)
 Old 11-22-2011, 07:12 AM   #40
silvapain's Avatar
Groans: 136
I'm a hooker for McMaster-Carr. Best online catalog software I've ever seen.
Tapadatass
phate (11-22-2011), rfinkle2 (11-22-2011), turboKart (02-12-2013)
LinkBack to this Thread: http://www.mazdaspeedforum.org/forum/forum/f567/how-remove-disassemble-hpfp-spill-valve-96970/
engine tappping (sorry i know its been done before).... ? Mazda MPS Owners Club This thread Refback 02-25-2015 04:24 PM
engine tappping (sorry i know its been done before).... This thread Refback 02-27-2014 09:26 AM
speed3 wont accelerate past 4k - Page 4 - DFW Mazdas This thread Refback 05-10-2013 03:25 PM
My project: Non-boosted DISI motor - Page 7 - Mazda3 Forums : The #1 Mazda 3 Forum This thread Refback 12-06-2012 02:45 PM
Okay, WTF was this? - Page 5 - Mazda 6 Forums : Mazda 6 Forum / Mazda Atenza Forum This thread Refback 05-12-2012 02:31 PM
How do you disassemble a forge? red07 MazdaSpeed 3/6 - Troubleshoot/Diagnostics 9 03-29-2009 10:28 AM
Cleanup on I-80: Oreo spill snarls traffic in IL Haltech Automotive News 0 05-19-2008 11:10 AM
Page generated in 0.60675 seconds with 31 queries
