Like Tree8Likes
  • 1 Post By cshunter
  • 1 Post By Enki
  • 1 Post By CWP_MS3
  • 1 Post By g00s3y
  • 3 Post By Enki
  • 1 Post By Enki
 Old 01-11-2016, 11:23 AM   #1
JP90's Avatar
Posts: 84   (View Stats)
JP90 is a jewel in the roughJP90 is a jewel in the roughJP90 is a jewel in the roughJP90 is a jewel in the rough
Groaned at 8 Times in 4 Posts
Default Jumping onto the E85 train
Going to buy upgraded HPFP internals this month. Is there anything I need to know other than what I've read. Sea foaming it once or twice to get all the gunk out. Is there tuning help here for full E85? Anything I need other than internals
JP90 is offline   Reply With Quote
The Following 2 Users Say NO Thank You to JP90 For This Un-useful Post:
MD1032 (01-13-2016), Vansquish (01-12-2016)
 Old 01-11-2016, 11:54 AM   #2
cshunter's Avatar
Posts: 1,312   (View Stats)
Some more reading. A gallon or two, is not gonna need a tune. Anything more will.
If you're looking for a guide on how to tune it yourself, then the info exist, search.
There's precautions you can do to avoid the sticky death. If you dont know what that is, go read.
As far as needing to change anything else, nope. Just the hpfp.
Sent from my SM-G925P using Tapatalk
Koke382 likes this.
2013 CWP That's slow
Previous: MILTUNED E85 K04
 Old 01-11-2016, 12:02 PM   #3
Enki's Avatar
Posts: 7,541   (View Stats)
Enki has disabled reputation
Seafoam doesn't do shit. Read up on the oil and fix threads.
Koke382 likes this.
The Following 5 Users Say Thank You to Enki For This Useful Post:
Atticaz (09-08-2016), MD1032 (01-13-2016), MS3Shadow (01-11-2016), PapaSmurf (01-11-2016), Vansquish (01-12-2016)
 Old 01-11-2016, 12:06 PM   #4
hidin in yo bushes
CWP_MS3's Avatar
Groans: 122
Don't use Rotella and you should be fine. I've been running it for 3 years on Pennzoil Platinum and I've never needed to clean it. If you hear a quick squeak on a cold start, that'd be normal.
Koke382 likes this.
Rich Tuned
330WHP and 363TQ
10-19-13 Moore Automotive
 Old 01-12-2016, 10:48 AM   #5
JP90's Avatar
Not sure what oil has to do with e85. I live close enough to E85 that I will be running full E85. Wasn't sure there was a vast amount of tuning help here on the forums. Or that it is as easy as upgraded HPFP internals to run e85.
The Following 4 Users Say NO Thank You to JP90 For This Un-useful Post:
Enki (01-12-2016), g00s3y (01-12-2016), ms6mil (01-13-2016), Vansquish (01-12-2016)
 Old 01-12-2016, 11:05 AM   #6
g00s3y's Avatar
Posts: 2,127   (View Stats)
Groans: 438
There is a whole thread about it, start reading there.
Your "not sure what oil has to do with e85" shows how little you understand about it.
Koke382 likes this.
Enki (01-12-2016), Vansquish (01-12-2016)
 Old 01-12-2016, 11:19 AM   #7
cshunter's Avatar
Like said above, go read.
Running e85 is as easy as swapping the pump. Tho how long that works for is what you should be asking, or how to prevent the sticky death. Tho thats all covered here already, go read.
Additionally the tuning info is here as well. You could literally make a map, go fill up with corn, flash to that map and you would be good to start tuning today.
Sent from my SP-G24627910574820P
The Following 2 Users Say Thank You to cshunter For This Useful Post:
 Old 01-12-2016, 12:22 PM   #8
Enki's Avatar
Ain't nobody in this section gonna have a spoon for you to eat from bro.
Koke382, Hoyoman and thrisnospork like this.
cshunter (01-12-2016), MS3Shadow (01-12-2016)
 Old 01-12-2016, 12:55 PM   #9
Koke382's Avatar
Posts: 4,361   (View Stats)
Smh
Sent from my LGLS991 using Tapatalk
2007 Mazdaspeed 3 GT
18x8.75 XXR 527 225/40/18r
New fucken miata build:
1993 Red Na6
Some suspension modz yo
Coilovers// Other shit
 Old 01-12-2016, 10:35 PM   #10
JP90's Avatar
No spoon needed I've actually read most of what you have written. Just wanted some confirmation. That's cool though. Lol spoon feeding.
The Following User Says NO Thank You to JP90 For This Un-useful Post:
g00s3y (01-13-2016)
 Old 01-12-2016, 10:41 PM   #11
Police - Grammarhead
Vansquish's Avatar
I'll spoon feed you a little bit, just so that you don't pop your motor.
1. You can run an E85 mix on stock internals, but upgraded ones are a better idea.
2. In order to take advantage of E, you need a tune that accounts for it. Without one, you're not going to get much of a benefit at all.
3. The pump is lubricated by oil. If you use the wrong oil, it will interact with the E85 and cause the pump to operate inefficiently and/or get gummed up.
4. If you intend to run a heavy E85 mix or pure E85 then you probably ought to be looking at some higher-end HPFP internals that are properly chemically-treated.
5. Read the fuck up. You've got a lot to learn.
The Following 5 Users Say Thank You to Vansquish For This Useful Post:
Atticaz (09-08-2016), Enki (01-12-2016), g00s3y (01-13-2016), MS3Shadow (01-12-2016), thrisnospork (01-13-2016)
 Old 01-12-2016, 11:04 PM   #12
Enki's Avatar
Not enough. If you read and comprehended *most* of what *I've* written, you'd know that I boiled E85 on a hotplate while trying to identify where the sticky and black deaths come from (if you even know what those are) and that they only appeared when oil was present.
Vansquish likes this.
Atticaz (09-08-2016), g00s3y (01-13-2016), Vansquish (01-12-2016)
 Old 01-13-2016, 05:17 AM   #13
g00s3y's Avatar
Groans: 438
Ah, since you only read "most" of what was written, you must have missed the tons of posts talking about full e85 working this platform.
Or did you just read the first page/last page, and then decide to ask your already answered question?
 Old 01-13-2016, 05:19 AM   #14
hidin in yo bushes
CWP_MS3's Avatar
Groans: 122
Full E85 sounds nice, but without PI I wouldn't want it. Too much hassle to have less power.
Rich Tuned
330WHP and 363TQ
 Old 01-13-2016, 06:54 AM   #15
Enki's Avatar
For now...If we can get the upgraded injectors going.
 Old 01-13-2016, 07:15 AM   #16
hidin in yo bushes
CWP_MS3's Avatar
Groans: 122
Yup. That shit is killing us.
Rich Tuned
330WHP and 363TQ
 Old 01-13-2016, 11:34 PM   #17
Vulcan's Avatar
Posts: 16   (View Stats)
Vulcan is just really niceVulcan is just really niceVulcan is just really niceVulcan is just really niceVulcan is just really nice
Going to jump on the E train too, 50/50 mix or so. From the other threads, looks like Pennzoil Plantium or Royal Purple Dexos is the way to go.
Does it make more sense to get the Euro blend PP that comes in 5w40? Still on the K04 @ 60,000 miles, dont have an oil restrictor bolt in and the T6 has been saving me for now (or so I was lead to believe when "T6, T6, T6" was pounded into my Brownie ass many moons ago)- so I'm hesitant to switch off the heavier weight oil. Need my K04 to last another year or two before thinking about BT.
A) RP 5w-30 Dexos
B) PP 5w-30 (also dexos??)
C) PP 5w-40 euro blend
D) A or B and order oil restrictor bolt?
Vulcan is offline   Reply With Quote
 Old 01-14-2016, 12:47 AM   #18
Enki's Avatar
If you can get your hands on legit Euro oil, you should try out the Shell Helix Ultra; that's supposedly Dexos too.
Otherwise, you're pretty much fine on 50/50 and T6 so long as you don't go over ~E45 or so.
Vulcan (01-14-2016)
 Old 01-14-2016, 04:59 AM   #19
hidin in yo bushes
CWP_MS3's Avatar
Groans: 122
Ha, well going E85 and pushing it harder isn't exactly going to help your cause, but then again it could fail staying stock. Might as well live a little.
To my knowledge pus don't need an oil restriction bolt. When Rich and I began tuning, one of the first things he did was bump my idle.
Rich Tuned
330WHP and 363TQ
The Following 2 Users Say Thank You to CWP_MS3 For This Useful Post:
Enki (01-14-2016), Vulcan (01-14-2016)
 Old 01-14-2016, 11:29 AM   #20
Vulcan's Avatar
Unfortunately there is no Shell Helix Ultra - I just saw the Euro blend PP 5w-40 on Amazon /w prime shipping. I guess its a possibility I could start using it and then they stop offering it.
Are you using 5w-30 PP CWP? Its my understanding that also is a dexos blend (so it might be preforming for you just as well as the purple stuff for the other guys?).
 Old 01-14-2016, 11:33 AM   #21
Enki's Avatar
I'm on RP Dexos. Shell Helix oil does exist, just not in the states.
 Old 01-14-2016, 11:38 AM   #22
hidin in yo bushes
CWP_MS3's Avatar
Groans: 122
Yup, I run Pennzoil Platinum 5w30 and change it every 2500-3000 miles (max) even though it generally looks half way decent at that mileage. It begins to smell a little like fuel so I opt to swap it out sooner than most.
Rich Tuned
330WHP and 363TQ
 Old 01-15-2016, 07:02 PM   #23
Hoyoman's Avatar
Posts: 302   (View Stats)
Hoyoman is the leader of the worldHoyoman is the leader of the worldHoyoman is the leader of the worldHoyoman is the leader of the worldHoyoman is the leader of the worldHoyoman is the leader of the worldHoyoman is the leader of the worldHoyoman is the leader of the worldHoyoman is the leader of the worldHoyoman is the leader of the worldHoyoman is the leader of the world
Groans: 43
Groaned at 6 Times in 3 Posts
Go right ahead since you've read everything and still haven't got a clue let us know how it goes
2012 black mica MS3 ; 3.5 HTP/ Catless DP/ AT HPFP/ APV2/ FMIC/ GFB BOv/ 3" CBE/ RMM/ XXR 530(18x9 +33)/ NT05 245/40/18/ 3bar map/ 3 port EBCS/ bnrs3/ DO stg2 dvc30/ REAR swaybar/ EBC Yellow/ CS Inj seals/ PNP IM/ Manley H-Beam/ Manley platinum piston 87.5/ soon...... PI+ BNRs6+ 44mm TIAL+ ACT 6 puck
E35 meth d012 26psi 420/451 self tuned/built
Hoyoman is offline   Reply With Quote
Thinking of jumping from Si to MS3 mtdang Gen2 MS3 General Discussion 69 04-12-2013 08:44 PM
Car bucking/jumping bmixon25 2010 MS3 - Troubleshoot/Diagnostics 18 01-16-2013 06:31 PM
Maybe Jumping Ship? troubled81 Mazdaspeed3/6 General Discussion 13 04-02-2012 05:32 PM
Page generated in 0.44274 seconds with 28 queries
