| MazdaSpeed 3/6 - E85 Fueling Learn more about feeding your car corn |
![]() | | #441 | ![]() |
| jbr makes fall-a-parts. ![]() Join Date: Jan 2011 Location: Cambridge Ontario Canada
Rep Power: 13536 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 25,744
Groans: 793
| Not Ranked : 0 score
__________________ ![]() Inb4 85% silicone core. It's better than aluminum. What's you buddy's ex wife trap? I <3 SP63, but that port job though... "The coolant must be evaporating." Bye Felicia "Exclusivity" - CP-enis Demodded. The Seals |
| The Following 2 Users Say Thank You to Tokay444 For This Useful Post: | kabobulate (09-09-2013), silvapain (09-09-2013) |
![]() | | #442 | ![]() |
![]() Join Date: Dec 2011 Location: Clarksville TN
Rep Power: 0 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 585
| Not Ranked : 0 score I guess we'll find out when I can make it down there. Sent from my SAMSUNG-SGH-I337 using Tapatalk 2
__________________ 2006 Black Cherry Mica Mazdaspeed 6 GT Cobb AP 50/50 FREEKTune/Cobb 3port EBCS/C-PE Nano Intake/C-PE TIP/C-PE TMIC/HKS SQ3 BOV/Auto Tech HPFP/M2 DP/Custom CB/Denso ITV 22's/JBR RMM/Sure SSP/Sure Shifter Bushings/Custom EGR Kit/TB&IM TIG/MD Stage2 OCC/Koni Yellow S&S/H&R LS/Stoptech Blanks/EBC Red/Techna-Fit SS Brake Lines/ |
![]() | | #443 | ![]() |
![]() Join Date: Sep 2012
Rep Power: 0 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 50
| Not Ranked : 0 score Any updates on this looking forward to seeing results |
![]() | | #444 | ![]() |
(Thread Starter) | Not Ranked : 0 score I'm on the RP but it's too soon to say for sure. So far, so good. I'll have a final answer tomorrow most likely, with regular updates after that, so long as it doesn't shit the bed.
__________________ |
| The Following 3 Users Say Thank You to Enki For This Useful Post: |
![]() | | #445 | ![]() |
(Thread Starter) | Not Ranked : 0 score Pressure dropped off halfway through my morning trip; I will say, however, that while cruising on the freeway the engine was "kicking" quite a bit and AFRs were stable, so I take that as a sign that the pressure was trying to come back. Also, the moment I got home, pressure started to return and at some point was even at target. While it doesn't last long, I hold hope for my next oil change removing more of the old oil which is what I'm thinking is the cause of the current issues. That said, I'll be pulling the spill valve this afternoon to see if that is the only issue (which I'm hoping is the case). If it isn't, I'll be going back to 50/50 until sometime after next oil change (which will be in the next couple months, and will be RP again).
| The Following 2 Users Say Thank You to Enki For This Useful Post: | Constantin (09-24-2013), El_Diablo (09-22-2013) |
![]() | | #446 | ![]() |
(Thread Starter) | Not Ranked : 0 score IT'S ALIVE! Spill valve had a little sticky. 5 minutes and back at full gumption; 1/4 tank down, let's see how far this goes.
| The Following User Says Thank You to Enki For This Useful Post: | El_Diablo (09-22-2013) |
![]() | | #447 | ![]() |
![]() Join Date: Jan 2013 Location: OC, CA
Rep Power: 0 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 633
| Not Ranked : 0 score Dunno if this has been discussed, but came across this. Willing to give it a try. |
| The Following 3 Users Say Thank You to He Hate Me For This Useful Post: |
![]() | | #448 | ![]() |
(Thread Starter) | Not Ranked : 0 score I can try that with RP too; I'm basically invested in doing the next 2 or so oil changes with it.
| The Following 2 Users Say Thank You to Enki For This Useful Post: | El_Diablo (09-22-2013), He Hate Me (09-22-2013) |
![]() | | #449 | ![]() |
| Not Ranked : 0 score Interested to see results of that, to see if it's even worth trying this ULX110. Because it could separate it when it's new but after some cycle through the engine it could break down and allow the E85 to blend with it. So definitely interested to see how some RP unused mixes (or doesn't) with E85. Finding this ULX110 looks to be a challenge in the U.S as wel... |
![]() | | #450 | ![]() |
| Not Ranked : 0 score Found a contact in the U.S ULX110 USA Manufacturer Coolant Control Inc. 5353 Spring Grove Avenue Cincinnati, Ohio 45217 U.S.A. Toll-Free Phone: 1-800 535 3885 |
![]() | | #451 | ![]() |
![]() Join Date: May 2009 Location: Memphis, IN
Rep Power: 0 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 1,249
But if it allows us to run 100% e85 it might be a trade off Sent from my SCH-I605 using Tapatalk 2
__________________ 2006 MS6 Titanium Grey BSD, Custom 3" SRI, 3" HTP TIP, Custom 2.5" Single Exit Exhaust, Nator Sytle Downpipe, E40 Selftune, AutoTechs, Ghetto Mod'ed Stock BPV, VTCS Delete, IM PnP & AWR RMM3 Tuned with | |
![]() | | #452 | ![]() |
| Not Ranked : 0 score I've also read the same things of RP breaking down pretty fast. I've seen a lot of people say it's good for a few runs down the track and it's broken down pretty fast. Nevertheless, I'd like to see you mix some fresh RP and E85, and shake it and see how bad(or good)it "dilutes" begin with @Enki. I have a feeling that any unused oil will separate E85, but it's finding an oil that works for a decent amount of time and how well it works inside the HPFP. Last edited by He Hate Me; 09-22-2013 at 11:14 PM. |
![]() | | #453 | ![]() |
(Thread Starter) | Not Ranked : 0 score This UOA seems to be decent-ish: Royal Purple 5W30 UOA I'll know more for sure when I do my first UOA though; I've asked for two kits, so depending on the results from the first test, I may be changing the oil sooner/later.
| The Following User Says Thank You to Enki For This Useful Post: | El_Diablo (09-23-2013) |
![]() | | #454 | ![]() |
![]() Join Date: Dec 2011 Location: Wooster Oh, 44691
Rep Power: 0 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 17,721
Groans: 769
| Not Ranked : 0 score There are so many different types of RP that you really cant just say they all suck. Which version are you using currently @Enki;?
__________________ 2011 Mazdaspeed 3- AccessPORT V2, Autotech HPFP Internals, 3 Bar MAP Sensor, 3" Catless Downpipe, CPE Stage 2 RMM, CPE TMM, Custom Saikou Michi OCC, CXR FMIC, Devils Own DVC-30, Forge V2 BPV, 3.5" HTP Intake, JBR TIG's, MME Shifter Bushings, NGK LTR7IX-11's, PNP Intake, SPEEDPERF6MANC3 Valve Cover Breather 2004 Mazdaspeed Miata #3142- Stock, but not for long. ![]() Equal rights for all, special privileges for none. ~ Thomas Jefferson |
![]() | | #455 | ![]() |
(Thread Starter) | Not Ranked : 0 score As stated in the other thread:
![]() | | #456 | ![]() |
Groans: 769
| Not Ranked : 0 score I believe that is their HPS series which might hold up a little better over the long haul.
![]() | | #457 | ![]() |
(Thread Starter) | Not Ranked : 0 score We will see. I've ordered test kit(s) from Blackstone.
![]() | | #458 | ![]() |
(Thread Starter) | Not Ranked : 0 score So went out for lunch today, about 40 minutes round trip. Pressure fell out on the way back, but did the same thing it did the previous time; it fought to come back, so I'm pretty sure it's just the spill valve again. I'll go clean it a little later and see what's up, but I'll probably go back to 50/50 until sometime after the next oil change before I continue testing it, or until the scraper gets built. If it is just spill valve again (likely), then it's already a huge ass leap forward on this problem.
![]() | | #459 | ![]() |
![]() | | #460 | ![]() |
![]() Join Date: May 2014
Rep Power: 0 ![]() Thanks: 0
| Not Ranked : 0 score Any news in this issue? Started having the p0091 code and car won't boost and hpfp reading is at 60psi at idle. Wondering if anyone has came up with a fix, mods are stage 2 ots with cat less downpipe, tih, auto tech internals, cai, Cbe, turbo smart bpv, fmic. Any help would be appreciated |
![]() | | #461 | ![]() |
(Thread Starter) | Not Ranked : 0 score Epic first post brah.
| The Following 2 Users Say Thank You to Enki For This Useful Post: | Easter Bunny (06-07-2014), udntknw (06-07-2014) |
![]() | | #462 | ![]() |
![]() Join Date: Aug 2013 Location: Baltimore, MD
Rep Power: 0 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 32
I've seen the "stage 2 OTS" map short the capacitor and cause HPFP issues. If that's your problem good luck finding a replacement. | |
![]() | | #463 | ![]() |
![]() Join Date: Dec 2010 Location: Humble, TX
Rep Power: 0 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 1,643
| Not Ranked : 0 score 60psi at idle is pretty much the pressure from the in-tank fuel pump. Sounds like you might need to pull the hpfp internals and examine
__________________ 2011 Speed3-BT and shit ![]() "There is a war going on for your mind. If you are thinking, you are winning. Resistance is victory. Defeat is impossible. Your weapons are already in hand. Reach within you and find the means by which to gain your freedom. Fight with tools. Your fate,and that of everyone you know, depends on it." TEAM LBN BEERS -- FYCN TEAM MUMFORD -- FYCN |
![]() | | #464 | ![]() |
| Not Ranked : 0 score Ended up taking it all apart and cleaning the spill valve, and hpfp and no more problems. Thanks for the help though |
| The Following User Says Thank You to fullboostms3 For This Useful Post: | himurax13 (06-09-2014) |
![]() | | #465 | ![]() |
![]() Join Date: Jan 2013 Location: McKinney, TX
Rep Power: 0 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 2,778
| Not Ranked : 0 score I did not read all 12 pages because I don't feel like it. But just glancing on Mobil 1's website I found this QA:
__________________ 3rd rebuild on the way...maybe... | |
![]() | | #466 | ![]() |
![]() Join Date: Jun 2011 Location: australia
Rep Power: 1125 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 4,310
Groaned at 8 Times in 4 Posts
| Not Ranked : 0 score http://www.nulon.com.au/products/Ful.../#.VEl6g8szHqB Found this here in Australia, looks like it has potential... Meets the desox requirements and also states that it's ethanol happy! Also comes in a 6L bottle (engine takes 5.7)
__________________ OLD: GT3071 IWG | Autotech HPFP | Cobb AP | tune | Catted DP |HDi FMIC | CPE 4" TIP + 3.25" MAF | Grimmspeed EBCS | RX8 S2 Rims | JBR 80a Trilogy | Forge V2 BPVNEW: HTP full 3" | catted DP | Autotech HPFP | COBB AP |
![]() | | #467 | ![]() |
(Thread Starter) | Not Ranked : 0 score My original testing and my current local full corn tester refute that statement completely.
__________________ | |
| The Following 2 Users Say Thank You to Enki For This Useful Post: | OverBoosted (10-24-2014), wolly6973 (10-23-2014) |
![]() | | #468 | ![]() |
![]() Join Date: Feb 2012 Location: Australia
Rep Power: 0 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 250
Groaned at 7 Times in 3 Posts
| Not Ranked : 0 score I wonder if an oils ability to withstand fuel dilution in a crankcase might make it even more prone to adding to black death/sticky problems in an MZR fuel pump. We see this with Rotella.
__________________ - 2008 Gen1 MS3 Cobb AP ~ Autotech HPFP Internals ~ HTP 3" Intake ~ Custom Testpipe ~ Cobb RSB ~ Sticky Tires. Self tuned on E85 |
LinkBack to this Thread: http://www.mazdaspeedforum.org/forum/forum/f567/resolving-hpfp-corn-woes-black-death-sticking-107141/ | ||||
| E85 issues with injectors? - Page 3 - Scion FR-S Forum | Subaru BRZ Forum | Toyota 86 GT 86 Forum | AS1 Forum - FT86CLUB | This thread | Refback | 09-12-2014 09:25 PM | |
| Quel est le meilleur carburant? - Mazda 3 Quebec | This thread | Refback | 05-26-2014 10:29 AM | |
| /v/ - Vehicles | This thread | Refback | 03-05-2014 09:35 PM | |
| HOW TO: Remove & Disassemble HPFP Spill Valve | silvapain | MazdaSpeed 3/6 - E85 Fueling | 139 | 04-09-2018 04:02 AM |
| Spill valve spring mod | Enki | MazdaSpeed 3/6 - E85 Fueling | 15 | 02-02-2014 11:01 AM |
| HOWTO: Spill Valve SST | Enki | MazdaSpeed 3/6 - E85 Fueling | 9 | 02-17-2012 09:07 AM |
| hpfp woes | 37HSSV | 2010 MS3 - Engine, Transmission & Driveline | 5 | 11-14-2011 09:00 AM |
| HPFP Woes | 37HSSV | 2010 MS3 - Troubleshoot/Diagnostics | 9 | 11-13-2011 03:44 PM |
