Other Platforms
> Ford Focus ST Ecoboost - General Discussion
Ford Focus ST Ecoboost - General Discussion Discussion of Ford Ecoboost Engines
Like Tree4Likes
  • 3 Post By 4DRHTRD
  • 1 Post By 4DRHTRD
 Old 06-11-2013, 07:39 AM   #1
4DRHTRD's Avatar
Posts: 176   (View Stats)
Default E85 in a Ecoboost Flex? YES!
I copied dj's fueling system and it worked!
I finished the install of the auxiliary fuel system this week. I've been chasing wiring gremlins but finally got it working correctly yesterday.
Details on the fuel system:
Walbro 255 pump, Magnafuel boost referenced FPR feeding 6x40lb injectors and a 1 gallon fuel cell.
50/50 E85/E10 91 octane in the main tank with E85 in the auxiliary 1 gallon tank.
I've installed a 3 bar map when we changed out the intake as well.
Torrie and I have been doing tune/log revisions and the car keeps getting faster and faster, Torrie feels there a ton more to be gotten out of the car now.
I can no longer floor it in first gear from a stop, the car just overpowers the stock tires...
Once we get the tune dialed in for this setup I am going to get a dyno done, then install the NEW TURBOS which I pick up this week. I plan to have a dyno done after the turbos are installed with no tuning changes to see the difference in boost.
BTW, it's 106+++ right now in Phoenix so we're doing all this when it's hot as heck out, if the car can survive this then when it's cold it should just be CRAZY.
Looks like I'll be needing to pick up some new tires soon....
Just a side note, the car can handle part throttle boosting via it's own fuel system with the E85 mix, it's only at WOT that the car has to close the throttle blade as it goes lean. This platform is very smart about saving itself from lean conditions. 10 years ago I would have blown 3 motors with the fueling issues I've been having as I sorted through the wiring/fueling gremlins this week.
Car is MUCH faster than this video now, I'll do a 0-60 and 1/4 mile pull with Torque once we're done with tuning revisions
Mike B
Love cars but wrestling comes first!
World's quickest and fastest Ecoboost Flex
http://www.youtube.com/watch?v=XT_zwVaXHwg
2011 Ford Flex Tuxedo Black Titanium EB 12.4@109 on Motor/12.38@113 on nitrous
Megan Coilovers, Custom fuel system, E85, custom cutout, lots of fun.
2013 Ford F-150 Ecoboost FX4
4DRHTRD is offline   Reply With Quote
The Following 12 Users Say Thank You to 4DRHTRD For This Useful Post:
atvfreek (06-11-2013), BobtailedSnail (06-12-2013), cshunter (06-11-2013), Downmented (06-11-2013), helmetface (06-11-2013), killer-ms3 (06-11-2013), maisonvi (06-11-2013), Monotonous ONE (06-11-2013), Realgib3 (06-11-2013), Roddiy (06-11-2013), sidekick (06-13-2013), spals (06-12-2013)
 Old 06-11-2013, 07:41 AM   #2
Downmented's Avatar
Posts: 3,040   (View Stats)
Groans: 493
Good work, post some pics.
700HP CLUB
11.479@124mph
#DIX
 Old 06-11-2013, 07:45 AM   #3
4DRHTRD's Avatar
Lot's of pictures here:
Moar power soon - 3.5L EB adding 6 injectors
Finished install:
Mike B
 Old 06-11-2013, 08:27 AM   #4
atvfreek's Avatar
Posts: 7,787   (View Stats)
Does the stock HPFP internals handle the load, or is there an aftermarket product for it?
2010 Speed3-PTE5858
Freek built/Freektuned
510hp420tq
11.321@129.93
Lex (06-11-2013)
 Old 06-11-2013, 08:49 AM   #5
Realgib3's Avatar
Posts: 2,443   (View Stats)
Great job on this project! I think you're only like the 3rd person running a secondary fuel cell for the extra injectors too, and obviously the first Flex I've ever seen modded this extensively.
Again, great job.
4DRHTRD (06-11-2013)
 Old 06-11-2013, 08:59 AM   #6
4DRHTRD's Avatar
There are no mods for our DI system yet, the stock fuel system will handle up to about 75% throttle and then can't keep up. I'm spraying at 23% duty cycle on 40lb injectors with a base 50psi of fuel pressure right now. I may end up dropping base fuel pressure to force a higher duty cycle on the injectors eventually. We'll see where everything lines up once the new upgraded stock turbos are installed.
BTW, the ECU on this car is SMART! Car is constantly in closed loop and shoots for a commanded AFR, as I spray the auxiliary system it removes fuel from the stock fueling system automagically to hit the .78 lambda we're commanding. If the car see's the car going lean via AFR OR fuel pressure it closes the throttle to compensate. I'm pretty sure I would have popped the motor many times this week if it weren't for the intelligence of this car.
Mike B
The Following 2 Users Say Thank You to 4DRHTRD For This Useful Post:
atvfreek (06-11-2013), Roddiy (06-11-2013)
 Old 06-11-2013, 09:10 AM   #7
ms3rick's Avatar
Posts: 2,959   (View Stats)
fuckin sick
Sold:
2010 MS3 siLver.
Official 60-100mph Times
Official Video battles
Official Youtube Channels
The Following User Says Thank You to ms3rick For This Useful Post:
 Old 06-11-2013, 01:11 PM   #8
Roddiy's Avatar
Posts: 5,388   (View Stats)
Groans: 279
That's awesome, but what really excites me is that ECU intelligence you've been talking about, that's fucking great.
2010 LSM Speed3
#BakeryTuned
 Old 06-11-2013, 11:40 PM   #9
4DRHTRD's Avatar
Still working on tune revisions but here's a decent pull with the Flex
Mike B
The Following 3 Users Say Thank You to 4DRHTRD For This Useful Post:
BobtailedSnail (06-12-2013), CosmicArkie (06-12-2013), killer-ms3 (06-12-2013)
 Old 06-12-2013, 07:00 AM   #10
ms3rick's Avatar
That thing flys
Sold:
2010 MS3 siLver.
 Old 06-13-2013, 04:05 PM   #11
DevilSpeed's Avatar
Posts: 710   (View Stats)
DevilSpeed is the leader of the worldDevilSpeed is the leader of the worldDevilSpeed is the leader of the worldDevilSpeed is the leader of the worldDevilSpeed is the leader of the worldDevilSpeed is the leader of the worldDevilSpeed is the leader of the worldDevilSpeed is the leader of the worldDevilSpeed is the leader of the worldDevilSpeed is the leader of the worldDevilSpeed is the leader of the world
Holy shit dude lol
DevilSpeed is offline   Reply With Quote
 Old 06-13-2013, 05:19 PM   #12
sidekick's Avatar
Posts: 3,093   (View Stats)
I'm on mobile, but I'll watch the videos later. good shit man, glad to see you went through with it and it's working well.
When you say you overpower the tires, are you spinning all 4? That's sick. Haha. That ECU sounds pretty slick too.
 Old 06-13-2013, 09:48 PM   #13
4DRHTRD's Avatar
No, the car is basically FWD and when it spins it throws power to the rears. If it puts too much power to the rear it closes the throttle body and opens the wastegate to remove all power and save the AWD system. If it does that it noses down then waits 2-3 seconds and then goes full tilt again.
Next mod after the new turbos are installed will have to be an EBC with a gear or MPH based boost level. I'm going to have to figure a way to reduce the boost in first so I can get traction and not have that happen.
sidekick likes this.
Mike B
Building my Flex Ecoboost V6- already in the 12's 4DRHTRD Ford Focus ST Ecoboost - General Discussion 30 11-28-2012 06:53 AM
Review: 2010 Ford Flex EcoBoost turns it up to 11 Haltech Automotive News 0 10-12-2009 10:20 AM
First Drive: 2010 Ford Flex EcoBoost delivers more than just a better engine Haltech Automotive News 0 07-21-2009 10:20 AM
Detroit 2009: Ford debuts 3.6L EcoBoost V6 in Flex Haltech Automotive News 1 01-11-2009 11:53 AM
Page generated in 0.37017 seconds with 27 queries
