E-Tuners / Custom Hardparts
Like Tree3Likes
  • 1 Post By sidekick
  • 2 Post By Lex
 Old 06-01-2014, 07:26 PM   #1
timmcc02's Avatar
Posts: 253   (View Stats)
timmcc02 is the leader of the worldtimmcc02 is the leader of the worldtimmcc02 is the leader of the worldtimmcc02 is the leader of the worldtimmcc02 is the leader of the worldtimmcc02 is the leader of the worldtimmcc02 is the leader of the worldtimmcc02 is the leader of the worldtimmcc02 is the leader of the worldtimmcc02 is the leader of the worldtimmcc02 is the leader of the world
Groaned at 9 Times in 3 Posts
Default The difference is in the tune!
Just finished my E85 tune with Alex. The car feels like a beast. I am convinced that the ko4 in my circumstances can not put out any more torque than what im at currently. Anyways the tuning process was quite long as I decided after tuning on 91 to also tune for E85 and then retuning when I upgraded the intake. Also I had a switch in wheels and tires which is why the attached VD has different tire sizes. I strongly recommend Stratified tuning for your tuning needs. By the way @Lex; I believe my buddy Bryan is gonna contact you for a tune on his ST. The VD I believe is a OTS map on 91 compared to my final E85 tune.
timmcc02 is offline   Reply With Quote
The Following 5 Users Say Thank You to timmcc02 For This Useful Post:
Agent_Orange (06-01-2014), BackRoads (06-02-2014), Lex (06-02-2014), Mike@Stratified (06-01-2014), [R]usty (06-01-2014)
 Old 06-01-2014, 07:30 PM   #2
Agent_Orange's Avatar
Posts: 3,575   (View Stats)
Groans: 665
I'm seeing about the same numbers on a 25% mix.
What % eth are you running?
Lex (06-02-2014)
 Old 06-01-2014, 07:36 PM   #3
timmcc02's Avatar
5 gallons per fill up, which is about 5gal e85to 9 gal 91
The Following User Says Thank You to timmcc02 For This Useful Post:
Lex (06-02-2014)
 Old 06-01-2014, 08:06 PM   #4
Groans: 665
So about 37% then.
Interesting. I've been thinking about increasing my mix to edge out some more gains, but I'm not so sure it's justified.
@Lex; is this typical of MBT for this kind of setup?
Lex (06-02-2014)
 Old 06-01-2014, 08:09 PM   #5
timmcc02's Avatar
Originally Posted by Agent_Orange View Post
So about 37% then.
I guess it all just depends on fuel quality really and how hard you want to push your settup
 Old 06-01-2014, 10:42 PM   #6
sidekick's Avatar
Posts: 3,093   (View Stats)
So about 37% then.
If you have the IDC headroom and don't mind a little worse gas mileage, I don't see why not. The higher ethanol content will mean even better combustion chamber cooling, which definitely shouldn't hurt. Ethanol also carries oxygen, so in theory, you'd be getting more oxygen into the combustion chamber as well. It's hard to say how much you'd get out of a little more, but it's worth a shot. Worst case scenario, you don't see any gains, because the K04 is maxed out and you end up dropping back down to your current E mix.
doctavus likes this.
Lex (06-02-2014)
 Old 06-02-2014, 09:50 AM   #7
There's just a little big of buffer left timing wise in the tune. As you approach MBT your gains from timing are minimal so it's good to leave a little bit of headroom if you hit the sweet spot with the tune.
Also I generally recommend 4 gallons of E85 per tank for a gen2 but when 91 fuel is the base fuel it doesn't hurt to add a little more since knock can still play a role.
sidekick and lookback like this.
Agent_Orange (06-03-2014)
TIG Difference?? Cheeto MazdaSpeed 6 - Engine, Transmission & Driveline 4 03-15-2013 03:21 PM
cobb ap: is safe tune quicker than stage 0 tune? Fusion_MS3 2010 MS3 - ECU Computer Tuning 14 12-16-2012 02:27 AM
Hypertech Tune.. Can't feel any difference? Snapple415 2010 MS3 - ECU Computer Tuning 69 08-24-2012 08:34 PM
Anyone fine tune there shifter and tune out a second gear grind? stevessvt MazdaSpeed 3 - Engine, Transmission & Driveline 15 10-21-2009 12:06 AM
Page generated in 0.28570 seconds with 24 queries
