| Stratified Automotive Controls We offer Vehicle Specific Street, Remote E-tuning, Dyno Services for Mazdaspeed 3 and Mazdaspeed 6 vehicles using the COBB AccessPort and VersaTuner. We specialize in control systems, engine management, instrumentation and turbocharging and offer a variety of products and services, from standalone ECUs to build-consulting services. |
(Thread Starter) | Not Ranked : 0 score ************************************** UPDATED JAN 21 2013 **************************************Decided to update and revamp this post with some fairly thorough diagrams for both Gen1 and Gen2. I have also included a good method to mount the nozzle in the charge piping without tapping a hard pipe. I will leave the original post content and images below but all you need are the 2 diagrams and information below. I have also added this writeup to our Blog The octane and cooling benefits of installing a WMI kit on the MazdaSpeed and other vehicles is well documented. However one of the toughest parts of the installation is installing the fluid tank in a tight engine bay. The vehicles however come with a perfectly good and methanol safe tank for windshield washer fluid (washer fluid contains methanol). On top of this they have a low level light – a huge bonus. While tapping the stock tank is an option, there is another option for using this tank without tapping it – drawing through the OEM washer pump. The 2007-09 and 2010-13 vehicles have a different setup for this so we have created 2 diagrams attached below to show the two different setups. In both cases the windshield washers will continue working. However for the Gen2 (2010-13) cars the more complicated setup means that when activating the front washer, fluid will also be sent to the back and vice-versa. This can be a nuisance and if you don’t need the rear washer you can always just cap the line going to the rear washer. Now you no longer have to run lines inside the car or add another tank and can enjoy the benefits of WMI if these were holding you back! ![]() ![]() ************************************************** ***** Well, as I found out, we get really shitty gas here on the west coast. 94 octane knocks like a bitch in 4th gear and up and I got fed up with it. So I decided install meth/water injection to keep the motor clean, knock at bay, and BATs happy with a top mount. I wanted to keep it all in the engine bay and modify as little as possible. No need to add a tank in the trunk or run lines from a pump in the tank. As you will see in the pictures below, the install included the following: 1. Tapped stock cold pipe and a Devil's own D05 nozzle, tight 90 degree turn, and check valve. The DO 90 degree turn makes all the difference here because you don't want to be hitting the hood with a tall nozzle such as the one from snow performance. 2. The pump was mounted where the horn is. A longer bolt is used to hold the pump in place with the horn behind it. Twin zap straps fit perfectly through the frame rail openings and the seemingly useless little bracket behind the driver side bumper offers another support. Make sure you pad your pump properly if it touches anything as it will vibrate and make noise. 3. The meth source. I used the stock windshield reservoir. At first I was going to tap it, but I quickly realized that water comes out if you unplug the stock washer pump. So I used a T to draw meth right through the pump. Everything works great and no tapping needed! I ran the hose in front of the bumper and covered it in wire loom to keep the color black. 4. The electronics. I got a sweet deal on a used Snow performance stage 2 kit. So I had a controller with a built in map sensor. I mounted it on the driver strut tower ... might move this but for now it does the trick. Power comes from an accessory fuse where an add-a-fuse was added. Make sure the source turns on with key on and off when key is off. 5. Finally for the boost source used a T from the BOV. Make sure all connections are sound, no chance for electrical shorts, and use zap straps to brace loose hoses and wires. After fiddling with the onset and full flow settings, I must say I love WI. Knock is down by at least 2 degrees and BATs fall to even below ambient! Heatsoak is much less of an issue and power is always there. Now I need a fuel pump as I am always running in "cold weather" Last edited by Lex; 01-21-2013 at 01:16 PM. |
| The Following 48 Users Say Thank You to Lex For This Useful Post: | 802MS3 (04-08-2009), Abilor (05-24-2011), ABolewski (02-26-2013), Addikted To Boost (10-27-2014), aggierandy (03-30-2013), Awal (06-16-2015), Axel907 (11-28-2012), AZSPEED3 (11-25-2012), badams118 (04-08-2009), BeeZaa (01-15-2011), bioevolve (04-08-2009), breakfstincluded (04-13-2014), Brian MP5T (09-02-2014), bstover17 (02-26-2013), charlesfist (01-29-2013), Crossbow (04-08-2009), Darthspeed3 (11-12-2013), Dmurray06 (08-18-2012), Dr. Speed (01-05-2013), forcedinduktion (11-22-2012), FreeFlyFreak (01-12-2011), fywdyl (01-07-2013), He Hate Me (11-29-2013), impossible (03-12-2017), JacksonMS30 (03-02-2011), KevMS6 (01-21-2013), KILLER_VIZ (01-06-2013), ktms3 (11-21-2012), lnumbp (10-13-2014), magicka (01-21-2013), Matt (01-15-2011), Menace1 (03-31-2013), Micha (11-22-2012), mituc (01-05-2013), paveltol (08-17-2012), phillyb (04-06-2009), Pointless (11-22-2012), Scatt Nasty (04-07-2009), SleeperHatch (02-04-2013), SofaKingAwesome (01-22-2013), speeda (03-01-2013), SpeedRebirth (04-11-2015), spheed3 (04-08-2009), therapist510 (03-02-2013), Tomas (01-21-2013), warlord (01-21-2013), x09MS3GT (09-23-2012), zoom1&zoom2 (05-07-2009) |
![]() Join Date: Apr 2008 Location: Salt Lake City, UT
Rep Power: 0 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 179
Groaned at 126 Times in 71 Posts
| Not Ranked : 0 score That's a nice set up. I was thinking of putting the pump on the other side because i thought it is supposed to be closer to the reservoir. Also, with my FMIC, I had to relocate the ambient temp sensor where your pump is now. I am sure I could find some other place for it, tho.
__________________ 2011 WRX | Cobb AP | Cobb DP | SPT CBE | AEM CAI Whiteline F/R Sways | SPT SSK | TWM M1 Abrams |
(Thread Starter) | Not Ranked : 0 score The other side has the reservoir in the way so it was more difficult to locate there. I am sure there are many ways to go about it, but I found this setup to work well for me and stay compact. |
![]() Join Date: Jan 2009 Location: Chicago,IL
Rep Power: 0 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 67
| Not Ranked : 0 score I like that setup a lot very similar to what I had in mind. Good work.
__________________ Black Mica 08.5 GT I'm parting out. Buy my stuff: http://www.mazdaspeedforum.org/forum/foru...ing-out-59908/ |
![]() Join Date: Aug 2008
Rep Power: 0 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 49
| Not Ranked : 0 score This may be a DUMB question and I just don't know any better ... but using the stock windshield washer res. for the meth is a good idea but I'm assuming you don't want to wash your windows with it. What do you do in that case? |
(Thread Starter) | Not Ranked : 0 score Why not? It's a good cleaner. I don't use 100% meth. |
| The Following User Says Thank You to Lex For This Useful Post: | Pointless (11-25-2012) |
| Not Ranked : 0 score It's not hard on things like the rubber/seals ... or the windshield washer fluid pump? I'm sure it's not rated for meth. |
(Thread Starter) | Not Ranked : 0 score Of course it is. A lot of washer fluids contain methanol. There is a list on this forum that is a sticky that tells you what brands contain what meth percentage. |
![]() Join Date: Jan 2009 Location: PHX/SV AZ
Rep Power: 0 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 772
Groans: 94
Groaned at 43 Times in 33 Posts
| Not Ranked : 0 score nice setup. stock bpv FTL
__________________ 321 HP/348TQ-- 13.940 @ 106 /3kft ASL |
| Not Ranked : 0 score What size T did you use for the stock washer line tap? ... I'm doing mine this weekend and I think thats the only part I don't have yet. |
(Thread Starter) | Not Ranked : 0 score I used the same size nipple as the washed pump. |
| Not Ranked : 0 score you don't remember the size though do you? ... so I don't have to take my shiz apart first to find it out. |
| Not Ranked : 0 score Lex, Did you have an issue with the nozzle (90* part) hitting the inside of the hood? I installed mine as deep as it'll go and it seems to be tearing up the rubber stuck to the inside of the plastic hood piece. |
| Not Ranked : 0 score Subd for reference!
__________________ 2010 Speed3-PTE5858 Freek built/Freektuned 510hp420tq 11.321@129.93 |
![]() Join Date: Nov 2010 Location: SoCal- Simi Valley
Rep Power: 128 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 11
| Not Ranked : 0 score LEX, You think 94 octane is shit try 91 piss gas in Cali. I like this idea and wondered how the setup has been for you? How long before you need to refill your reservoir? Are you running increased boost and if so what PSI at WOT?
__________________ 08 Speed3 -AP Tri-Point Tune, CS intake, CS TMIC, Autotech internals, Cobb DP, JBR RSB w/ Tri-point endlinks, Koni Yellows, H&R Springs, JBR short shift, JBR OCC, Bose Delete 85 Mazda RX7 -3rd gen motor, single turbo, built by Rotary Shack 04 BMW 745Li 1997 Mustang Cobra Vert- WMS intake, Shorty headers, Bassani CBE, Bassani X-pipe, Steeda rear lower control arms, Steeda shifter |
The setup worked great while I had the top mount. Now with an FMIC I moved the nozzle to the silicone tube going to the throttle body. Works just as well and cools the intake charge to ambient temps. I have a D03 nozzle now. I am running 18-19psi on the K04 depending on ambient temps. No reason to push that little thing any further. Reservoir lasts quite a while - especially since I have a Canadian MS3 that has a bigger windshield washer reservoir. It also has the advantage of having a low level light so I never have to guess about the level and just fill up when I see the light. | |
| The Following User Says Thank You to Lex For This Useful Post: | Pointless (11-22-2012) |
| gonads and strife ![]() Join Date: Jul 2009
Rep Power: 241 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 210
![]() Join Date: Sep 2011 Location: Frankfort, Kentucky
![]() | | #19 | ![]() |
![]() Join Date: Sep 2009 Location: Colorado
Rep Power: 0 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 483
| Not Ranked : 0 score Why not tap the pipe on the side instead of the top. Then you don't have to worry about the 90 degree piece or hitting the hood. Mine is tapped on the back side of the pipe. I'm using it as the extra boost source for my Synapse BPV atm but will be using it for meth in the near future.
__________________ 2011 Mustang GT Premium 5.0 2009 True Red Mazdaspeed3 - Sold Cobb SRI | Cobb TIP | Cobb AP | CP-E DP | SU TMIC | Denso ITV22 | PTP HPFP | Synapse Synchronic BPV | Saikou Michi OCC | SU 90A RMM | SU Side Mounts | TWM Stage 2 STS w/Bushings | Dashhawk |
![]() | | #20 | ![]() |
![]() Join Date: Jan 2010 Location: Orinda, CA 94563
Rep Power: 0 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 73
| Not Ranked : 0 score I would run this setup but am concerned about accidentally spraying methanol (no mix) all over my windshield/paint.....
__________________ -~-2008 MS3 cosmic blue mica-~- Orinda, CA 94563 |
![]() | | #21 | ![]() |
![]() Join Date: Oct 2011 Location: Calgary, Alberta
Rep Power: 0 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 212
| Not Ranked : 0 score thank you Lex gave me a better picture of why to use the window fluid tank!
__________________ 2010 MS3: Cobb AP, Cobb FMIC, Auto tech internals, UR TBE with V2 Catless DP, NGK plugs, Ksport Kontrol pro coilover with spc camber arms, Tanabe Front Strut Bar, JBR RMM, JBR Return, JBR knob, JBR RSB, Sure Short Cut, GFB BPV, SURE ID300, Sure Anchors, and HTP 3" TIH 18 x 9 +22 Work VSXX, Extreme Vision 3000k HID kit. Stratified Tune In garage:JBR Stage 2 OCC, AEM Meth Kit To BE ORDERED:BNR S3 or GTX 2867r, 3 Bar Map, Stratified EBC, JBR Trans Mount |
![]() | | #22 | ![]() |
![]() Join Date: Nov 2010 Location: Murrieta, CA
Rep Power: 1393 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 14,136
| Not Ranked : 0 score Hells yea! Sent from my EVO using Tapatalk 2
__________________ 2009 CWP Speed3 |
![]() | | #23 | ![]() |
| Fuckin a, flashback
| The Following 2 Users Say Thank You to Haltech For This Useful Post: | btstarcher (11-25-2012), TWOptSL0W (11-22-2012) |
![]() | | #24 | ![]() |
(Thread Starter) | Not Ranked : 0 score Lol, yes flashback! Surprised more people aren't using the stock tank. It works on gen1 and gen2 but the gen2 pump system is different so you have to add a check valve and be a little sneaky. I should do a writeup and update this.
![]() | | #25 | ![]() |
![]() Join Date: Dec 2011 Location: Virginia
Rep Power: 0 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 715
Groans: 30
| Not Ranked : 0 score hows that write up going lol @Lex;
__________________ Stance will make her dance, but boost will make her sploosh
2014 Mustang GT | |
| The Following User Says Thank You to BlckMs3 For This Useful Post: | Lex (11-27-2012) |
![]() | | #26 | ![]() |
![]() Join Date: Nov 2012 Location: Toronto, Canada
Rep Power: 0 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 24
| Not Ranked : 0 score I've been running the same meth setup as Lex for the past two years and I haven't had any problems yet. It's great when I see the low washer fluid light come on and I still have enough fluid to last me to the gas station to do a quick refill. |
![]() | | #27 | ![]() |
(Thread Starter) | Not Ranked : 0 score I will put something together soon but not for another week or 2 as I'm traveling and swamped this week. Essentially you pull through the OEM washer pump (the lowest one) for Gen1 and for Gen2 it's a bit more involved but the same principles apply.
![]() | | #28 | ![]() |
![]() Join Date: Apr 2012 Location: QC , Canada
Rep Power: 0 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 6,450
Groans: 104
__________________ . MS3 2012 CWP • Cobb AP • HTP 3" INTAKE • CorkSport RP - TMIC - TMM • Autotech HPFP • GFB BPV • CP-E RMM • MishiMoto OCC • Denso ITV22 • Devil's Own WMI DVC-30 Stage 2 | |
![]() | | #29 | ![]() |
![]() Join Date: Sep 2011 Location: SCOTLAND
Rep Power: 0 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 469
| Not Ranked : 0 score 3. The meth source. I used the stock windshield reservoir. At first I was going to tap it, but I quickly realized that water comes out if you unplug the stock washer pump. So I used a T to draw meth right through the pump. Everything works great and no tapping needed! I ran the hose in front of the bumper and covered it in wire loom to keep the color black. lex / or anyone .... Can this method be used on the 6? Looking to install soon and don't want any drama's
__________________ Cpe tmic&sri, 3" HTP tip, 3" ebay downpipe, BNR stage1, Autotech internals, Snow stage 2 meth with Aqaumist jet/parts, GoFastBits Respons BOV, Grimmspeed ebcs 3-port, Turbinetech diff mount, Cpe diff brace, Whiteline rarb, Bilstein B8's, Eibach springs, NGK iridium IX plugs, Corksport Mods, JBR mods... 324whp 361lb/ft Tuned with by |
| The Following User Says Thank You to KevMS6 For This Useful Post: | atvfreek (01-05-2013) |
![]() | | #30 | ![]() |
![]() Join Date: Dec 2011 Location: Wooster Oh, 44691
Rep Power: 0 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 17,721
Groans: 769
| Not Ranked : 0 score 2011 MAZDA Mazda3 Parts - Online Mazda Parts Looks like there are two washer tank sizes on the MS3.... anyone know what the actual tank capacities are for these?
__________________ 2011 Mazdaspeed 3- AccessPORT V2, Autotech HPFP Internals, 3 Bar MAP Sensor, 3" Catless Downpipe, CPE Stage 2 RMM, CPE TMM, Custom Saikou Michi OCC, CXR FMIC, Devils Own DVC-30, Forge V2 BPV, 3.5" HTP Intake, JBR TIG's, MME Shifter Bushings, NGK LTR7IX-11's, PNP Intake, SPEEDPERF6MANC3 Valve Cover Breather 2004 Mazdaspeed Miata #3142- Stock, but not for long. ![]() Equal rights for all, special privileges for none. ~ Thomas Jefferson |
![]() | | #31 | ![]() |
![]() Join Date: Nov 2011 Location: Alberta, Canada
Rep Power: 0 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 621
| Not Ranked : 0 score That's awesome that the washer tank is bigger in the Canadian MS3 ... This is how I'll do it if I ever do WMI.
__________________ | 2012 CWP | Cobb AP + AT Internals | HTP 3" Intake | 91oct + DO WMI (D07, 50/50) + 3gal E85 | UR Test Pipe | cp-e TMIC | JBR Trilogy, OCC, EGR Block, SSB | TBC Bypass | Freektuned - 313/351 - Stock DP |
![]() | | #32 | ![]() |
Groans: 769
| Not Ranked : 0 score Did you buy your MS3 new as a canadian unit? If so you should empty the tank for me and measure how much it takes to fill it back up. ![]() I can try to measure mine when I get home later today.
![]() | | #33 | ![]() |
Groans: 104
| Not Ranked : 0 score I can put almost a gallon of WW in it.
![]() | | #34 | ![]() |
(Thread Starter) | Not Ranked : 0 score Yes it works on all speeds. The gen 2 requires an extra check valve. I will get some diagrams up hopefully within a week just have been too busy.
![]() | | #35 | ![]() |
![]() Join Date: Oct 2011 Location: South Charleston, WV
Rep Power: 0 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 3,955
Groans: 228
| Not Ranked : 0 score I would definitely be interested in a write up for 2nd gen because I was going to start to piece together a kit and just bought a 2.5 gallon reservoir and I am thinking I might have went overboard lol.
__________________ 2010 MAZDASPEED 3 COBB ACCESSPORT V3 // COBB FMIC // AUTOTECH INTERNALS // HTP 3" GOLD INTAKE // JBR 88 DURO RMM // JBR EGR DELETE // SURE ANCHORS // SURE COUNTERSHIFT // SURE SHORTCUT // TB PERFORMANCE TRACTION BAR V 2.0 // TB PERFORMANCE CHASSIS BRACE JBR BOOST TUBES // JBR BYPASS HOSE // DDM TUNING 5k HID // GFB RESPONS BPV // PROSPORT BOOST GAUGE // CNT CATLESS DP // ZOOM ZOOM BOX // JL Audio 10w3 // HEADLIGHT ARMOR YELLOW FOGS |
![]() | | #36 | ![]() |
Sent from your couch
__________________ 2010 Speed3-PTE5858 Freek built/Freektuned 510hp420tq 11.321@129.93 | |
| The Following User Says Thank You to atvfreek For This Useful Post: | KevMS6 (01-05-2013) |
![]() | | #37 | ![]() |
Groans: 769
| Not Ranked : 0 score I thought knowing was half the battle? ![]() I know I can fill my washer tank with nearly all of a gallon of washer fluid when its near empty. Anyone else care to comment or grab actual numbers?
![]() | | #38 | ![]() |
For reference I only use a custom reservoir I made that is 1.5qts. It last me a couple weeks of spirited driving and that is with a d10 nozzle. (Or one nator rd rage excursion) I don't have meth kick on until 11psi or so. So the washer reservoir should last quite a while. Only reason I wasn't sure if I wanted to run 100% meth. I probably wouldn't run more than 50/50 through the washer tank. Sent from your couch
![]() | | #39 | ![]() |
| Not Ranked : 0 score Thanks for great info ![]() Snow performance stage 2 does not come supplied with check valve or solenoid - some says not required, other say its a must. What do you guys suggest?
![]() | | #40 | ![]() |
| Not Ranked : 0 score I would run either or. I personally wouldn't trust the meth kit with out one. Sent from your couch
| The Following User Says NO Thank You to atvfreek For This Un-useful Post: | ckMS3 (01-07-2013) |
LinkBack to this Thread: http://www.mazdaspeedforum.org/forum/forum/f600/stratified-meth-kit-install-using-stock-washer-25050/ | ||||
| Water/Meth - Mazda 3 Quebec | This thread | Refback | 07-16-2013 01:08 PM | |
| W/M pour un DD ? - Forced Induction - Club Civic Quebec :: Forum | This thread | Refback | 02-26-2013 10:45 AM | |
| Meth Kit - How to Tap the stock WWF reservoir | This thread | Refback | 01-21-2013 08:33 PM | |
| EGR Delete = Bad Ass Meth Install?? | jhershorin | MazdaSpeed 3/6 - Fuel, Nitrous & Water Injection | 23 | 02-21-2009 09:52 AM |
| SUPER's Labonte Water/Meth Install | superskaterxes | MazdaSpeed 3/6 - Fuel, Nitrous & Water Injection | 14 | 02-19-2009 10:22 AM |
| Dont be dumb with meth install | wassup61 | MazdaSpeed 3/6 - Fuel, Nitrous & Water Injection | 7 | 02-05-2009 02:52 PM |
| Meth kit install questions | Stan-O | MazdaSpeed 3/6 - Fuel, Nitrous & Water Injection | 2 | 01-24-2009 08:21 AM |
| Mazda3Mods Meth Install | Buildabong | MazdaSpeed 3/6 - Fuel, Nitrous & Water Injection | 35 | 01-19-2009 07:38 AM |
