TSB's and Recalls for MS3 If possible please sticky! Also feel free to move this if you feel it is better suited elsewhere. ***NEW*** TSB thanks to Dadasracecar (added 4/8/08) Click link below for Cam Driven Fuel Pump TSB NHTSA Recall Campaign Number: 07V295000 Component: ENGINE AND ENGINE COOLING Details: ON CERTAIN PASSENGER VEHICLES, THE NO. 4 LEFT SIDE ENGINE MOUNT BOLT MAY LOOSEN IF A SUDDEN RAPID ACCELERATION IS REPEATEDLY PERFORMED. Consequence: IF THE VEHICLE IS CONTINUOUSLY DRIVEN UNDER SUCH CONDITION, THE NO. 4 ENGINE MOUNT BOLT MAY LOOSEN AND PULL OUT OR BREAK, ALLOWING THE TRANSMISSION TO BE OUT OF POSITION. IN EXTREME CASES, THE DRIVE SHAFT MAY BECOME DETACHED. IF THIS OCCURS THE VEHICLE WILL LOSE POWER AND WILL COME TO A STOP, INCREASING THE RISK OF A CRASH. Corrective Action: DEALERS WILL INSPECT AND REPLACE THE NO. 4 ENGINE MOUNT BOLT WITH A MODIFIED ONE, AND, IF NECESSARY, REPLACE THE NO. 4 ENGINE MOUNT RUBBER AND BRACKET WITH NEW ONES FREE OF CHARGE. THE RECALLBEGAN ON JULY 13, 2007. OWNERS MAY CONTACT MAZDA AT 800-222-5500 . Units Potentially Affected: 5700 Recall Initiated By: ODI Date added to NHTSA datbase: 07/10/2007 NHTSA Recall Campaign Number: 07V052000 Component: EQUIPMENT Details: ON CERTAIN PASSENGER VEHICLES EQUIPPED WITH OPTIONAL ACCESSORY ALL WEATHER FLOOR MATS, THERE IS INSUFFICIENT CLEARANCE BETWEEN THE FLOOR MAT AND ACCELERATOR PEDAL. Consequence: IN THIS SITUATION IT IS POSSIBLE THAT THE ACCELERATOR PEDAL MIGHT GET STUCK BEHIND THE FLOOR MAT, WHICH MAY PREVENT THE VEHICLE FROM PROPERLY DECELERATING WHEN THE ACCELERATOR IS RELEASED INCREASING THE RISK OF A CRASH. Corrective Action: OWNERS WILL BE INSTRUCTED TO RETURN THE FLOOR MATS TO DEALERS AND WILL BE SHIPPED A NEW FLOOR MAT FREE OF CHARGE. THE RECALL BEGAN ON MARCH 7, 2007. OWNERS MAY CONTACT MAZDA AT 1-800-222-5500. Units Potentially Affected: 1700 Recall Initiated By: MFR Date added to NHTSA datbase: 02/15/2007 SERVICE BULLETIN:09012007 NHTSA ITEM NUMBER:10023192 MFG Bulletin Date: 20070901 Component: ELECTRICAL SYSTEM:WIRING:INTERIOR/UNDER DASH Bulletin Summary: MIL ILLUMINATION (DTC P2006) VOLUNTARY EMISSION RECALL CAMPAIGN 4807H AND OBD-II COMPLIANCE VOLUNTARY EMISSION RECALL CAMPAIGN 4907H. *NJ Date added to datbase: 20071101 SERVICE BULLETIN:0101007 NHTSA ITEM NUMBER:10021521 MFG Bulletin Date: 20070301 Component: ENGINE AND ENGINE COOLING:ENGINE Bulletin Summary: MIL COMES ON WITH DTC P2006 (VARIABLE SWIRL CONTROL SYSTEM SHUTTER VALVE STUCK CLOSED). *KB Date added to datbase: 20070514 SERVICE BULLETIN:0102206 NHTSA ITEM NUMBER:10023313 MFG Bulletin Date: 20070907 Component: SUSPENSION:FRONT Bulletin Summary: FRONT CRANKSHAFT BOLT SERVICE WARNING. *NJ Date added to datbase: 20071114 MTOL - 5636 Dealer Repair Information Symptom and Conditions Some customers may experience a chattering noise when passing over bumps and/or driving on a rough roads,that may be confused as a dash rattle at the base of the windshield. Condition may be the result of a stick slips noise that occurs between the cowl grill and the windshield. Repair Procedure When you encounter a customer with this concern replace the insulator pads on the 8 hooks of the cowl grill with improved part as listed. Part No. L206-50-794 Qty. 8 (4 per side) |
New Recall Got a call this afternoon from my dealer about a recall. Something to do with Door latch/lock re-enforcement??? Going in tomorow afternoon to get it done. I'll post more info after the work has been done. |
hmmmmmmmmmmmm |
They said it should take about an hour to complete and the "parts" just came in today. So I'm not sure if they are going to replace somehting or what but they wanted me in their ASAP to get it done. |
Quote:
Yeah so I'm not sure what the dealership was smoking. I get there and ask exactly what the recall is.......its for the locks. Its the whole If someone kicks your doors the right way they will unlock thing. I was like ok get it fixed than. They take my car into the bay and come out 5 mins later and say yeah your vehicle does not need the recall. Not a happy camper right now about them wasting my time along with having to leave work early to bring my car in. |
I thought they fixed that with the older models..... sucks you had to waste your time. Dealers are morons. |
mitchells also works very well :) |
Missing the VVT and CDFP TSB here. |
How serious is the motor mount loosening? Does this happen very often? |
Im going in to a dealer cross state to look at an MS3. Would they know which recalls have been fixed in the car? It's an Acura dealer, so they don't sell Mazdas often. |
I'm glad the recall 07V2295000 is on here because my 07 Speed 3 for some odd reason never had this reall performed before I bought it, and low and behold last night the bolt snaps, of course it has to be Sat night when it breaks so now I have to tow the car in tomorrow morning but I'm going to raise hell for the fact it was a certified used car through mazda without having the recall performed. I am not a happy camper but thanks to you guys I can seriously talk to my dealer about some lingering questions I now have about their service work / certification there. |
axle clicking tsb..............anyone???? |
I just bought a 2008 MS3 and i was wondering after reading this thread if your in cali area if you could suggest a dealer to get the recalls checked and or fixed |
hmmm, seeing all this and reading the thread about how everyone is having there motor blowing up is kinda making me think twice:thinking::thinking: about getting one.... |
Quote:
Quote:
i should get one of those... then i can save money and buy a real turbo car... like a supra evo, or sti... yeah thanks for the idea... ass, I'm new on the site ans still have to read more about the ms3, so if i read more good then bad then i will get one. so far the stuff im reading is making me want to learn more about the ms3 |
Quote:
some unsolicited advice: if you are going for easy big power, choose a dif platform. if you want the best/fastest daily driver, the ms3 is for you. even though my car will never be 400+hp, its still fast as fuck and i couldnt be happier. |
Quote:
I'm not going for big easy power. i have driven 2 ms3 and liked them and there's no way in hell i would want a fwd car to have 400+ hp, it would lose all it's fun. i had a focus that had a bunch of cosworth stuff and had 228 wph on a mild tune and it was good enough for me but i was t boned and decided i would look into a turbo car that's fun to drive. the only reason i said "real turbo cars" was due to the reason that they have been around longer than the speed3. i'm not intentionally putting the speed3 down it's a good step forward in to the turbo game for the 5 door car. i was just in a bad mood, im currently looking at a silver speed3 bone stock except or some wheels. not sure what kind has no center cap's |
I just brought my car in for some warranty work. My driver's side seatbelt latch was squeaking when I went over bumps, apparently there's a TSB for this. When I drop the car off again to get the work done I'll get more info about the TSB. There's also a TSB for Bose radio's eating CD's. My dealer said not to use MP3 CD's in my MP3-capable Bose CD-Changer because "they get stuck." Sounds like BS to me. I told him whenever I'm playing a burned CD, I can't change discs, even though the lights illuminate, nothing happens. However, the CDs will change if using a store-bought CD. I'll keep everyone posted on what I find. |
Quote:
Drive shaft TSB Hey the Drive shaft TSB seems to be only for the regular mazda3 but I think that is occurring with my mazdaspeed3 did any one get this done on their MS3. I would like to know thanks |
Quote:
mine is clicking too |
whats it sound like if its clicking? and how do you know? my car has like a clicking sound coming from the back of the car like everytime i go over bumps and shit. |
Quote:
Quote:
Quote:
You need a Proctologist not a Mechanic! |
Quote:
thats how many started atleast |
Quote:
Quote:
Quote:
that exactly right. If I go reverse and forward I can repeat all the time. I have check all my suspension, sway bar and endlinks and I can't find nothing odd. it has to be it. thanks for the help guys. I schedule it for service on friday will see how it goes. |
Quote:
Quote:
Quote:
Just told them there was clicking from drivers side front during load changes, that I could only hear it with the window down, and that it sounded like a bad CV joint. They checked it out, ordered a new axle. Replaced under warranty. |
Quote:
Thanks for the help. |
Quote:
As far as the dealer is concerned........ In other words everything else is removed for visits, and I would remove the SRI too if I was going in for any warranty work engine related. You have........ TT front mount, catch can, forge bpv cobb sri, bc coils and rims LOL... good luck, depends on your dealer really, I would consult the Good dealer and Bad dealer lists on the forum to see if there is a "good" dealer in your area. |
Quote:
Quote:
The STIG is Michael Schumacher. Quote:
Quote:
Quote:
:firedevil:so if i take my car to the mazda dealer and tell them these are the recalls can you fix them even if nothing wrong that i know of can they charge you for this? and or does ne of these recalls must be screwing with my car before they will fix it? |
| All times are GMT -7. The time now is 10:36 PM. |
