Like Tree73Likes
 Old 12-18-2014, 10:11 PM   #1
h.h.sk1nny's Avatar
Posts: 1,392   (View Stats)
Default Sk1nny finally goes built motor/BT
Alrighty ladies and gentlemen,
My car has just not been doing too hot the last few months. First started noticing oil coming out of my intake a while back. Cleaned everything, installed new pcv and damond occ, still finding oil all over. I finally strapped on some balls and did a compression check on the motor. Ended up having cracked/damaged ringlands. I told my wife I'm never selling the car, so we are left to building the motor!!! I got the get go from the wife, and with some more coaxing got the go on BT too lol. I will order parts here in about 1 week. Car will be getting pulled apart about then as well. Building the motor myself, because I have always wanted too that's why!
Goal:
500awhp ms6
130 traps
Essentially a 10 sec car that needs driver mod lol.
Killer setup for the street
Parts List:
Manley Pistons
Manley H beam rods
Kings Bearings
Arp L19 head/main studs
Engine Gasket kit
New VVT kit
Crower Valve Springs
SP63 transfer case bearing cap
PTE 5858 Vband .82 a/r
Boost Junkyz Manifold
Tial MVR wg
Tr10 intercooler
Corksport Seals
Keyed Crank/Pinned Cams
I already have DSS axle, ported head, 4" HTP intake and other things to help me get there. Super excited for this. Car is getting pulled apart at new years and hopefully it will be fired up by Feb. Getting it tuned Purple Drank style. We finally got a AWD dyno local now, so she will definitely hit the rollers. I will keep you guys updated and pix to follow. She should ready for the 1/4 here come springtime.
Captain KR likes this.
The Following 27 Users Say Thank You to h.h.sk1nny For This Useful Post:
Arnie1229 (01-16-2015), Bleupit80 (08-20-2015), BrandonRKD (12-20-2014), ButtholeRedMS3 (08-10-2015), Captain KR (02-27-2015), Cataphract_40 (12-30-2014), chaser27 (12-29-2014), cmosh07 (06-19-2016), cshunter (12-27-2014), darkstar5440 (12-28-2014), DISIindahead (12-24-2014), Easter Bunny (12-26-2014), England15j (12-18-2014), Fail_6 (02-02-2015), jack_hammer (12-19-2014), Jester2552 (12-19-2014), Jh8909 (12-20-2014), levon.mark (03-14-2015), Mazdazilla6 (12-20-2014), mghtymouse380 (12-19-2014), Micha (12-20-2014), mituc (12-18-2014), ms3blackmica (01-18-2015), mxlplx71 (12-29-2014), pmartz16 (12-15-2015), speed3 britz (12-29-2014), stanley0910 (12-19-2014)
 Old 12-18-2014, 11:26 PM   #2
mituc's Avatar
Posts: 3,528   (View Stats)
Groans: 111
Chose the parts very carefully. Follow the discussion about the head studs, you will see they are not that great, get the L19s instead from the same people that will fix your transfer case.
About the main studs, they should be good just keep in mind that you will not be able to keep the BSD - that if you intend to keep it (I intend to keep it after my build). The OEM main studs would serve you just as well. @England15j can tell you more about this.
2008 Cosmic Blue Mazda 3MPS
self-Versatuned to 22PSI
England15j (12-18-2014), h.h.sk1nny (12-19-2014)
 Old 12-19-2014, 02:54 AM   #3
Jester2552's Avatar
Posts: 126   (View Stats)
Let me know if you need help! I'd love to learn. I'm sure I could drag Sean along too
2007 Black MS3
Tuned by Nishan
The Following User Says Thank You to Jester2552 For This Useful Post:
 Old 12-19-2014, 08:27 AM   #4
h.h.sk1nny's Avatar
Lol, trust me, I have thought long and hard on my parts. Was going to build it to support 800+ hp, but then some common sense kicked in and I realized I will enjoy 500 for quite some time. L19's are on my list, as are arp mains. I already have done the BSD so no worries there. Super stocked about pulling this thing apart. Was gonna get some stage 2 SP63 cams, but decided the stock cams can rev pretty hi already, lets just change out the springs to avoid floating a valve.
Definitely man! I am sure I could use an extra hand. Any local nator guys are welcome to help out with the fun
Last edited by h.h.sk1nny; 12-19-2014 at 08:27 AM. Reason: MSF Database - Automerged Doublepost
The Following User Says Thank You to h.h.sk1nny For This Useful Post:
 Old 12-19-2014, 09:26 AM   #5
stanley0910's Avatar
Posts: 364   (View Stats)
stanley0910 is the leader of the worldstanley0910 is the leader of the worldstanley0910 is the leader of the worldstanley0910 is the leader of the worldstanley0910 is the leader of the worldstanley0910 is the leader of the worldstanley0910 is the leader of the worldstanley0910 is the leader of the worldstanley0910 is the leader of the worldstanley0910 is the leader of the worldstanley0910 is the leader of the world
Man can't wait to see the results!
Need more parts.
stanley0910 is offline   Reply With Quote
The Following User Says Thank You to stanley0910 For This Useful Post:
h.h.sk1nny (12-20-2014)
 Old 12-19-2014, 10:18 AM   #6
2.0t03speed's Avatar
Posts: 1,302   (View Stats)
Can't wait to get this thing tuned!!
The Following 2 Users Say Thank You to 2.0t03speed For This Useful Post:
Bleupit80 (09-05-2015), h.h.sk1nny (12-19-2014)
 Old 12-23-2014, 11:53 PM   #7
maddocx240's Avatar
Posts: 823   (View Stats)
e85? meth? or both?
The Following User Says Thank You to maddocx240 For This Useful Post:
h.h.sk1nny (12-26-2014)
 Old 12-26-2014, 08:35 PM   #8
h.h.sk1nny's Avatar
e85? meth? or both?
I think I will just run meth. We will see where it gets me. Looks like 26-27psi makes some damn good power on Evos. Hopefully I get close to what they are pullin
The Following 2 Users Say Thank You to h.h.sk1nny For This Useful Post:
2.0t03speed (12-28-2014), maddocx240 (12-27-2014)
 Old 12-28-2014, 11:12 PM   #9
darkstar5440's Avatar
Posts: 477   (View Stats)
You should check out kings bearing that sp63 starting selling, im def going that route on the next build. Also did you look into going dual vband instead of T3? JMF intake manifold wouldn't be a bad idea either for that HP goal especially with meth because your gonna need to spray alot to make 500+
Good luck with the build!
OMWTFYB
The Following User Says Thank You to darkstar5440 For This Useful Post:
h.h.sk1nny (12-29-2014)
 Old 12-29-2014, 09:19 AM   #10
h.h.sk1nny's Avatar
SP63 is sending me some kings bearings. I'm sure they are nice. I thought about dual v band but did not know or think there was advantage with it besides how easy it would be to install. Really any? I still have time as I am waiting on a call from Boost Junkyz and I don't think edge has shipped my turbo out yet. I know 500 is a hefty order with meth, we will see how close. If not, I will start thinking about a new im and 6th port lol
Edit: Just got off the phone with Eric from edge and he will be shipping me a dual vband 5858 lol. Guess I'm going vband
darkstar5440 (12-29-2014)
 Old 12-29-2014, 11:19 AM   #11
Jeff getting 500 with meth isn't hard i've done it on multiple cars now. Only takes around 1000cc of meth to get there. Throw in one d14 or go direct port and call it a day. I've got one car with a gtx3071 on 30psi w/ 4 d05's(overkill) his idc is only 70% lolol. Also have another car with a BWs360 and a single D14 making over 500
The Following 7 Users Say Thank You to 2.0t03speed For This Useful Post:
Bleupit80 (09-05-2015), darkstar5440 (12-29-2014), h.h.sk1nny (12-29-2014), impossible (07-03-2015), mghtymouse380 (12-30-2014), Micha (01-08-2015), mxlplx71 (12-29-2014)
 Old 12-29-2014, 09:43 PM   #12
I believe the vband flows better and also is much easier to deal with.
As far as the meth i wasnt saying 500 isnt feasible. I made 560 on meth with the same turbo. What I was trying to say is the stock intake manifold even with vcts delete and ported does not distribute the fuel evenly. I suggested the JMF as a safer route considering all the money you've dumped already.
I assume you are spraying pre TB right?
OMWTFYB
Last edited by darkstar5440; 12-29-2014 at 09:43 PM. Reason: MSF Database - Automerged Doublepost
The Following 2 Users Say Thank You to darkstar5440 For This Useful Post:
amggilly305 (07-28-2015), h.h.sk1nny (12-29-2014)
 Old 12-29-2014, 10:22 PM   #13
h.h.sk1nny's Avatar
Got ya. I will see how this goes and yes pre TB
darkstar5440 (01-01-2015)
 Old 01-07-2015, 10:18 PM   #14
h.h.sk1nny's Avatar
Well, got some good work done on pulling the motor. Super busy with other things too though. Plan is to have motor pulled by the weekend. On Tues, have block dropped off for cleaning, boaring and honing. Also plan to have my crank and cams shipped off to SP63 the same day. Tial MVR showed up the other day and my 5858 came yesterday. Waiting for more stuff to show up before I throw pix up. The more I hear about the 5858 the more I get excited. Maybe we will shoot for 550awhp lol.
The Following 4 Users Say Thank You to h.h.sk1nny For This Useful Post:
cshunter (01-08-2015), England15j (01-07-2015), Jester2552 (01-08-2015), SpeedRebirth (01-07-2015)
 Old 01-09-2015, 11:48 PM   #15
h.h.sk1nny's Avatar
Just spent 3 more hours on the car (total 6hours so far). All I have left is to pull the axles, pull the transfer case, motor/tranny mounts and hoist her out!!! It has gone a lot easier and quicker than expected! Fine!!! Here are a few pix of what has arrived so far, not much sorry lol.
BLKSTIG (01-11-2015), stanley0910 (01-12-2015)
 Old 01-13-2015, 09:51 PM   #16
h.h.sk1nny's Avatar
Got the motor pulled sat night at midnight. I ended up pulling the motor/trans and transfer case all at once. Crower springs are here and my TR10 showed up today. That thing is huge lol. Motor is all stripped down except for the damn oil pump. Can't get the drive gear off to get to the last bolt lol. I was expecting to seen damaged ringlands, but they were all good. Looks like some of the piston rings were just worn. Even after 115k miles on the car, you can still see some of the factory honing lines. Stand by for pix.
The Following 3 Users Say Thank You to h.h.sk1nny For This Useful Post:
Code Monkey (01-13-2015), Easter Bunny (01-17-2015), Mauro_Penguin (01-14-2015)
 Old 01-13-2015, 09:58 PM   #17
jeopardy98's Avatar
Posts: 1,920   (View Stats)
jeopardy98 is the leader of the worldjeopardy98 is the leader of the worldjeopardy98 is the leader of the worldjeopardy98 is the leader of the worldjeopardy98 is the leader of the worldjeopardy98 is the leader of the worldjeopardy98 is the leader of the worldjeopardy98 is the leader of the worldjeopardy98 is the leader of the worldjeopardy98 is the leader of the worldjeopardy98 is the leader of the world
Hit that oil pump bolt with the impact. I had the same problem because I pulled the chain and pulley first. Impact zipped it right off.
Bone Stock 2012 BM Non-Tech for 2500 miles. (250 whp/265 wtq Moore Auto). Currently: K04/Cobb AP/AT internals/Magnaflow CBE/M2 DP/Cobb SRI/HTP TIP/CS boost tubes/CS recirc hose/TS BPV/SU TMIC/GS EBCS/JBR EGR delete/Coolant bypass/Thermal TB gasket/NGK 6510's/JBR SSP/JBR Knob/JBR 88 RMM/JBR SSB/DDM 35w 5000k HIDs/PAC Gateway iPod integration and Sirius. (301whp/360wtq Moore Auto). Finklefied Hypnotic tune. 14.1@106 Mason Dixon- Driver mod needed.
jeopardy98 is offline   Reply With Quote
The Following User Says Thank You to jeopardy98 For This Useful Post:
h.h.sk1nny (01-14-2015)
 Old 01-14-2015, 10:46 PM   #18
h.h.sk1nny's Avatar
More stuff arrived today!!!! Got the cp-e safe seals and my cs seals showed up. CP-E's are getting sent back. I ended up finding the perfect size box for sending my crank and cams off to SP63. Took a picture of my 6 puck with 18k miles on it. Pretty much stop and go traffic, no commuting. Not much left of it. The tabs that hold the material are just starting to get scuffs. My boost junkyz manifold will be getting shipped out Friday at the latest, with free two day shipping. Can't be more happy about the customer service they have provided. Good group of guys over there. Add a new disc to my list!!! Here are a few pix for you guys and gals
2.0t03speed likes this.
The Following 8 Users Say Thank You to h.h.sk1nny For This Useful Post:
2.0t03speed (01-15-2015), BLKSTIG (01-14-2015), Code Monkey (01-16-2015), England15j (01-15-2015), ItsNox (01-15-2015), Jester2552 (01-14-2015), Micha (01-17-2015), mituc (01-15-2015)
 Old 01-15-2015, 04:58 PM   #19
CorkSport Vincent's Avatar
Posts: 163   (View Stats)
CorkSport Vincent is the leader of the worldCorkSport Vincent is the leader of the worldCorkSport Vincent is the leader of the worldCorkSport Vincent is the leader of the worldCorkSport Vincent is the leader of the worldCorkSport Vincent is the leader of the worldCorkSport Vincent is the leader of the worldCorkSport Vincent is the leader of the worldCorkSport Vincent is the leader of the worldCorkSport Vincent is the leader of the worldCorkSport Vincent is the leader of the world
Just wanting to clarify what you said, Did you say that you could not get aftermarket mainstuds to work with the Balance Shafts still installed?
I maybe reading this wrong.
CorkSport Vincent is offline   Reply With Quote
The Following User Says Thank You to CorkSport Vincent For This Useful Post:
mituc (01-15-2015)
 Old 01-15-2015, 05:03 PM   #20
England15j's Avatar
Posts: 1,910   (View Stats)
Oem main studs are shorter and have the clearance required to install the BS aftermarket arp studs would have to be cut down as they are longer and would interfere with the BS.
Pic is borrowed from @Reedy; build thread showing arp studs trimmed down for BS install
lito37 likes this.
The Following 3 Users Say Thank You to England15j For This Useful Post:
BLKSTIG (01-15-2015), Easter Bunny (01-17-2015), mituc (01-15-2015)
 Old 01-16-2015, 07:12 PM   #21
h.h.sk1nny's Avatar
Got some pix of my manifold from Daniel at boost junkyz!!! It will get here Tues!!! Mine is the middle on
The Following 6 Users Say Thank You to h.h.sk1nny For This Useful Post:
BLKSTIG (01-17-2015), Code Monkey (01-16-2015), magicka (01-17-2015), sho (01-18-2015), Snyeed (01-17-2015), SpeedRebirth (01-16-2015)
 Old 01-17-2015, 12:54 AM   #22
BLKSTIG's Avatar
Posts: 507   (View Stats)
the sex
The Following User Says Thank You to BLKSTIG For This Useful Post:
h.h.sk1nny (01-22-2015)
 Old 01-17-2015, 10:28 AM   #23
Reedy's Avatar
Posts: 391   (View Stats)
Reedy is the leader of the worldReedy is the leader of the worldReedy is the leader of the worldReedy is the leader of the worldReedy is the leader of the worldReedy is the leader of the worldReedy is the leader of the worldReedy is the leader of the worldReedy is the leader of the worldReedy is the leader of the worldReedy is the leader of the world
Attachment 188098
Yea we just faced them off in a lathe. Not sure how much material needs to be removed but we cut them down to whatever the stock size is.
England15j likes this.
Reedy is offline   Reply With Quote
The Following User Says Thank You to Reedy For This Useful Post:
England15j (01-17-2015)
 Old 01-17-2015, 11:01 AM   #24
Snyeed's Avatar
Posts: 743   (View Stats)
Groaned at 8 Times in 4 Posts
Love the build, what are you doing for a dp?
417whp 428tq 12.037@117.2mph
 Old 01-17-2015, 11:19 AM   #25
h.h.sk1nny's Avatar
Been rockin with the ebay dp for almost 4 years now, no need to replace it
blackmicamps6 (01-17-2015), Snyeed (01-17-2015)
 Old 01-17-2015, 11:39 AM   #26
Snyeed's Avatar
So the mani puts the turbo in stock location then, eBay vband dp works no problem.
Good to know!
 Old 01-17-2015, 01:59 PM   #27
h.h.sk1nny's Avatar
Good to know!
That's what I'm hoping lol. But yeah, should work just fine. The dp has a little wiggle room, I don't think there will be an issue
 Old 01-18-2015, 12:19 PM   #28
Nishan
ms3blackmica's Avatar
Posts: 5,635   (View Stats)
You will definitely want a JMF intake manifold, no doubt about it.
You're going to have to push real hard on that stock manifold to make 500 AWHP to where it really is not safe or reliable especially since you'll be giving the motor hell with track abuse.
Great build Sk1nny glad to see you'll finally be making nasty power and racing.
www.tunedbynishan.com
The Following 5 Users Say Thank You to ms3blackmica For This Useful Post:
amggilly305 (07-28-2015), ButtholeRedMS3 (08-10-2015), Easter Bunny (01-18-2015), h.h.sk1nny (01-18-2015), SpeedRebirth (01-18-2015)
 Old 01-18-2015, 04:44 PM   #29
h.h.sk1nny's Avatar
Thanks mang!! I'm going to see how far the stock IM can take me safely. If I need to step up to a jmf, then so be it. Hopefully there will be some more options out there if and when we get to that point. Cannot wait to tear it up at Firebird Raceway this year. Finally should smoke my buddies bolted and sc'd srt8 jeep lol. His last run of the season he got kicked off the track for no cage. I'm down!!!
BLKSTIG (01-18-2015), ButtholeRedMS3 (08-10-2015), ms3blackmica (01-18-2015)
 Old 01-22-2015, 11:18 AM   #30
Cataphract_40's Avatar
Posts: 1,730   (View Stats)
Groans: 30
Boost Junkyz got banned - anyone know why?
I hope it's not for deceptive practices or something, I was this close to buying one of their manis...
2008 GT MS3 - 307 WHP/338 WTQ
1995 Miata
 Old 01-22-2015, 05:29 PM   #31
Attachment 188098
Gotcha, the picture clears up what he meant.
England15j (01-22-2015)
 Old 01-22-2015, 06:48 PM   #32
h.h.sk1nny's Avatar
I would guess he does/has not paid vendor fees or something. Dan is a super cool guy. I have spoken/text with him quite a few times now. He never hesitates to give me a call/text back. They were really busy at the shop when building my manifold and took longer than expected. He ended up doing 2 day shipping for me for free!
Cataphract_40 (01-23-2015), ItsNox (01-26-2015), sho (01-22-2015)
 Old 01-29-2015, 10:17 PM   #33
h.h.sk1nny's Avatar
Okay!!! Finally got some more sexyness photos taken for you kids!! Got my box of parts from Pablo today!!! Now I can drop the pistons off at the machine shop so they can bore/final hone on my block. Still send my injectors to injector RX. After that, just need my cams and crank returned to me. Got my boost junkyz manifold and it is built right!! I have seen many manifolds. From turbo xs, to racebuilt and fullrace. It is built stout like the racebuilt was, and quality of the welds and collector like the fullrace was. I found one issue with this manifold and turbo though. As you can see in two photos, the compressor housing is extremely close to the block side of the manifold; no room for the stud where it bolts on. I Have two ways to fix this. 1: Weld up the head where the egr is and just hack off the end of the manifold. Or 2: Flip the compressor housing so it aims down and I run my IC piping under the car. I am aiming at the later, that way I don't hack on a brand spanking new manifold. Got all my odds and end parts here too. Hoping to start reassembly here as soon as I get my parts back from SP63.
The Following 10 Users Say Thank You to h.h.sk1nny For This Useful Post:
BLKSTIG (01-30-2015), ButtholeRedMS3 (08-10-2015), Captain KR (01-29-2015), Cataphract_40 (01-31-2015), ItsNox (01-30-2015), Jester2552 (03-01-2015), Mazdazilla6 (03-15-2015), ms3blackmica (01-29-2015), RE-ACTIONENGSPEED3 (01-30-2015), SpeedRebirth (01-30-2015)
 Old 01-30-2015, 07:05 PM   #34
h.h.sk1nny's Avatar
Dropped off the pistons today. My block should be ready for pickup next Fri. Shipping injectors off tomorrow
 Old 02-26-2015, 11:50 PM   #35
h.h.sk1nny's Avatar
Dayyyuuummm Gina!!!! Been almost 1 month since an update. Finally got my keyed crank and pinned cams from sp63 today. Got home from work, put the kid to bed and started assembling the short block. Finish @ 11:30 PM. Now I just need some head action. Going to check valve bucket clearances, that should be a pain.
The Following 7 Users Say Thank You to h.h.sk1nny For This Useful Post:
BLKSTIG (02-27-2015), ButtholeRedMS3 (08-10-2015), Captain KR (02-27-2015), darkstar5440 (03-01-2015), ItsNox (02-27-2015), ms3blackmica (02-27-2015), taf0422 (02-27-2015)
 Old 02-27-2015, 07:00 AM   #36
shaneski's Avatar
Posts: 505   (View Stats)
Nice set up, Love the number plates
 Old 03-12-2015, 08:45 AM   #37
Jdraps13's Avatar
Posts: 703   (View Stats)
Jdraps13 is the leader of the worldJdraps13 is the leader of the worldJdraps13 is the leader of the worldJdraps13 is the leader of the worldJdraps13 is the leader of the worldJdraps13 is the leader of the worldJdraps13 is the leader of the worldJdraps13 is the leader of the worldJdraps13 is the leader of the worldJdraps13 is the leader of the worldJdraps13 is the leader of the world
Groaned at 18 Times in 5 Posts
Anyone have photos of dumptube with ewg on this setup
Jdraps13 is offline   Reply With Quote
 Old 03-12-2015, 11:12 PM   #38
h.h.sk1nny's Avatar
Patiently waiting for my timing chain!!! Never ceases to amaze me at how much USPS blows ballsack!!!
BLKSTIG (03-12-2015), Darksun280 (03-19-2015), rkwill (05-25-2015)
 Old 03-12-2015, 11:57 PM   #39
BLKSTIG's Avatar
I love this build!
 Old 03-14-2015, 05:34 PM   #40
levon.mark's Avatar
Posts: 268   (View Stats)
Groaned at 9 Times in 4 Posts
I was thinking about going with that same exact turbo setup and manifold, i just need to find someone locally to make me a downpipe.
YEEMARKS
Old Time in S3:
12.4 @ 111
The Following 4 Users Say Thank You to levon.mark For This Useful Post:
BLKSTIG (03-14-2015), England15j (03-15-2015), Erick13Speed3 (03-15-2015), h.h.sk1nny (03-15-2015)
Built motor and BNR V2 MattyP617 2010 MS3 - Big Turbo Builds 9 03-05-2015 08:57 PM
built motor blackms3_71 Mazdaspeed3/6 General Discussion 11 01-31-2013 08:19 AM
Built Motor is Done..... yoichi MazdaSpeed 6 - Engine, Transmission & Driveline 107 12-14-2009 10:52 AM
Page generated in 0.64757 seconds with 38 queries
